Emax
Internal SCSI ZIP Alternative ?
2011-07-31 by maradiostar
Hi
I have an EMAX I Upgraded in HD keyboard but the internal HD died.
I've read here that it's possible to change the HD for an internal SCSI ZIP, but it's quit expensive right know...I can found more cheaper Jaz or Syquest SCSI internal drives...does it works on EMAX I instead of the Internal Zip Drive ?
I have also see that HXC floppy disk emulator...could I use it instead of my internal HD ? same fonction ?
Sorry for my really bad english...
Much respect ;)
Best regards
Pedro
Re: [emax] Internal SCSI ZIP Alternative ?
2011-07-31 by jammie.emma@...
syquest 135mb flyer will fit and you can still get the disks there is a member on site who sells sounds on the 135 media
  To: emax@yahoogroups.com
  Sent: Sunday, July 31, 2011 4:18 PM
  Subject: [emax] Internal SCSI ZIP Alternative ?
  Hi
  Much respect ;)
  Best regards
  Pedro
  No virus found in this incoming message.
  Checked by AVG - www.avg.com
  Version: 9.0.901 / Virus Database: 271.1.1/3799 - Release Date: 07/30/11 19:34:00
Re: Internal SCSI ZIP Alternative ?
Great...
should be enough power consumption ? I'll (of course) disable the internal HD...right ?
DO I need a special cable to connecte the Emax scsi internal cable to the syquest or internal Zip ?
is it easy to fix inside the Emax ?
Thanks a lot ...
Pedro
>   ----- Original Message -----
>   From: maradiostar
>   Hi
>   Much respect ;)
>   Best regards
>   Pedro
Re: [emax] Re: Internal SCSI ZIP Alternative ?
same cable you need to drill new holes in mounting plat so that you can center the drive thats about it uses same floppy power connector set it to 0 scsi id and you are away
  Sent: Sunday, July 31, 2011 8:00 PM
  Subject: [emax] Re: Internal SCSI ZIP Alternative ?
  Great...
  Thanks a lot ...
  Pedro
  > From: maradiostar
  > Hi
  > Much respect ;)
  > Best regards
  > Pedro
  Version: 9.0.901 / Virus Database: 271.1.1/3800 - Release Date: 07/31/11 07:41:00
So I need to use the floppy disk power connector or can I use the one used by my old HD ?
Great thanks a lot for your help.
Pedro
>   From: maradiostar
>   Great...
>   Thanks a lot ...
>   Pedro
>   > From: maradiostar
>   > Hi
>   > Much respect ;)
>   > Best regards
>   > Pedro
you can use the harddrive1 if you do the slim floppy conversion you can just about fit both with out doing any thing to the opening
some people just use velcro tape to fix the drives
  Sent: Sunday, July 31, 2011 9:31 PM
  Pedro
  > From: maradiostar
  > Great...
  > Thanks a lot ...
  > Pedro
  > > From: maradiostar
  > > Hi
  > > Much respect ;)
  > > Best regards
  > > Pedro
2011-08-01 by maradiostar
Where I can found this slim Floppy ?
>   From: maradiostar
>   Pedro
>   > From: maradiostar
>   > Great...
>   > Thanks a lot ...
>   > Pedro
>   > > From: maradiostar
>   > > Hi
>   > > Much respect ;)
>   > > Best regards
>   > > Pedro
