This is an Emax II 2201. 1MB of RAM.
Looks like it was left in storage for a long time.
Bad power switch- bypassed for testing, will replace.
Screwy display- reseated all ICs and we get the good display.
So far so good...
The Floppy drive is failing (CRC errors), so I can put in a slim floppy.
There is no HD- but I have a CF drive for it.
I hear some whistling noises as the floppy is chunking away in the
headphone outputs.
It may need some work on the PS then or re-cap it.... I can do that too.
It did boot, and I loaded in an Emax 1 disk after several attempts and
CRC errors on 3 disks.... I hear sounds in the headphones when I press
keys.
Some of the keys I have to press hard to get a response.
So here are the questions:
1) For the key presses- perhaps some cleaning needs to be performed?
I've never had to do this on my Baldwin IKE / Emax 1, as it was well
kept.
Any tips in relation to the cleaning process?
It has 3 broken keys, so I would assume during cleaning process that
would be the best time to replace them, correct?
2) It doesn't appear to have the Stereo upgrade.
Any way I can get this updated to Stereo?
3) I know without the Expander board I certainly cant get above 2MB.
If I get the ICs to make it 2MB on the main board will it see it, or
are new PALs required?
Just trying to figure out my options.
Or should I just wait again for something better to come along and
part this one out.
Any help is appreciated.
Ted
Mono sampling.
On May 7, 2010, at 8:08 AM, Ted Summers wrote:
I dunno. but I will find out.... :-)
So to be clear on what the options are:
1) If it is mono, is there an update to stereo?
2) If it has an expansion board, I can get an eeprom to update to 8M,
correct?
(ie by using the workaround used to fix scrambled megs posted to the
group shortly ago..burn a new EEPROM and socket it).
Ted
On Fri, May 7, 2010 at 6:02 AM, Everett <evy_newt@...> wrote:
Congrats! Which model did you get? I see a lot of helpful posts coming
out of this purchase regardless :)
Everett
