take a look at the samsung sfd321b
you can change the ready signal and drive select and other things.
it has solder pads you just need to desolder and re solder.
I got one working for an akai s950 which is possibly the worst
to find a compatible drive.
On Mon, Feb 15, 2010 at 11:55 PM, jamesulibarri <jamesulibarri@...>wrote:
> I will take 6 months to get the drive from you Rich. Forget it. Me and
> plenty of others have been down that road a few. Pass!!
> --- In emax@yahoogroups.com <emax%40yahoogroups.com>, "Rish" <rish@...>
> wrote:
> > We do sell a replacement for the Ell and it does work 100% with all dual
> drive Ell units, It however does not work in the upper bay as a one drive
> setup nor does it work with any HD models. If your friend is still having
> problems with his Ell and his setup is indeed a dual drive model we would
> not stop offering support, that's just not anything we would do for any
> reason.
> > Rich at Route 66
> > ----- Original Message -----
> > From: s*
> > To: Emax List
> > Sent: Monday, March 16, 2009 2:57 PM
> > Subject: [emax] Emax floppy drives
> > I have been scouring the Internet today looking for lists of compatible
> emax
> > drives. I am hoping to head to an electronics surplus store here in
> Toronto
> > after work. I see that these models are compatible:
> > Mitsubishi Full Height 3.5" MF353B - 12 UJ or MF353BA - 12U
> > And some early NEC's
> > The drive that is currently in my Emax II was originally pulled from a
> > friend's EIII Keyboard (He killed my floppy a long time ago) and it is a
> > Sony.
> > Does the TEAC FD235HF-A529 work in the Emax II as well?
> > I read that a floppy drive from a Mac Classic might work so, I tried
> taking
> > apart a friend's dead Mac SE to use it's floppy drive, only to find that
> > it's not the same type of ribbon cable.
> > I would try route66 but, my friend ordered a drive for his Emulator II
> from
> > there and has never been able to get it to work and they stopped offering
> > him support apparently so, I want to avoid any hassle like that if
> > possible.
> > Any suggestions on what floppies will work is greatly appreciated.
> > Thanks,
> > -s*
> > [Non-text portions of this message have been removed]
