Something I forgot in the communication specs:
- The 31.25 kbaud communication is 1 startbit, 8 databits, 1 stopbit,
no parity
- The 500 kbaud communication is 1 startbit, 8 databits, 1 stopbit,
odd parity
///E-Synthesist
--- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote:
> O yes, the protocol.
> It's really simple in fact. It's based on MMA as it has been
> described in the MIDI SYSEX v3.0 docs of Emu.
> It's just that the "Get Bank" and "Send Bank" SYSEX commands were
> missing in that document. Here they are:
> 1/ To send a bank from Emax to Host Computer:
> - the host should send F0 18 02 09 F7 at 31.25kbaud to the Emax
> (Request to Send Bank Fast)
> - the Emax will respond with F0 18 02 0F F7 at 31.25kbaud (Accept
> Bank Fast)
> - then Emax switches to 500kbaud, and the host computer should do
> so too.
> - from that point on the communication is exactly the same as the
> one described for Send Sample Fast: the host should send an initial
> ACK (F0 7E 0C 7F 00 F7) and then the data dump starts. The Emax
sends
> MMA data packets (127 bytes containing 120 data bytes), and each
> packet should be ACKed by the host (F0 7E 0C 7F pp F7 with pp =
> packet number looping from 0x00 to 0xFF, then back to 0x00 again
and
> so on).
> - in total 4609 of these packet transmissions + ACKs should be
done.
> 2/ To send a bank from Host Computer to Emax:
> - the host should send F0 18 02 0F F7 at 31.25kbaud to the Emax
> (Accept Bank Fast)
> - the Emax will immediately switch to 500kbaud and the host
> computer should do so too
> - the Emax will send an ACK (if everything goes well) i.e. F0 7E
0C
> 7F 00 F7
> - then the host should start sending MMA packets, which will be
> ACKed by the Emax one after another (packets 00=0x00 to 127=0xFF
and
> then again from 0x00)
> That's about it.
> To find this out, I simply tried the first undocumented SYSEX code
> (09) and I immediately had luck ! It seemed to be the command I was
> looking for.
> Sniffing the communication between my Mac (Sound Designer for Emax)
> and the Emax confirms that this is the protocol that should be used.
> Of course I want to add the RS422 load/unload features to EMXP, and
> was hoping to be able to use the standard Windows C serial
> communication library of Microsoft.
> If some of you succeed in creating hardware for the RS422 it would
be
> great that this library can be used. If some special hardware
> specific library must be used I can get in trouble with freeware
> licensing for EMXP... unless that library would be completely free
> also.
> PS: the fact that the host must initiate the communication at 31.25
> kbaud and then has to switch to 500kbaud is something to think
about
> when using external clocking. I suppose and hope that even this
31.25
> kbaud is clocked by the Emax to the Mac, so that the host doesn't
> have to change from internal clocking to external clocking all the
> time.
> ///E-Synthesist
> --- In emax@yahoogroups.com, tu@ wrote:
> > If the Emax bank dump protocol uses the same format as the MMA
SDS
> data packet then each
> > packet only requires 127 bytes. That should not be too difficult
to
> buffer.
> > If each packet requires a Ack/Nak reply then there is a built in
> flow control mechanism and no
> > RTS/CTS hardware flow control is required.
> > Esynthesist, would it be possible for you to reveal a bit more
> detail about the bank dump protocol?
> > What goes in the headers etc?
> > /Tristan
> > Sunday, November 23, 2008, 9:01:15 PM, you wrote:
> > esynthesist wrote:
> > > Oops. I'm getting depressed finding out that my s/h USD50 old
Mac
> is
> > >equipped with two (!) serial ports capable of what one (!) new
> USD399
> > >one can do. And for that 50 dollars the Mac package also
includes
> a
> > >computer with screen, keyboard, harddisk and floppy drive :-)
> > >(ok, the Quatech will have more *serial* features, but still...)
> > yeah.... modern computers move on from old tech, but then when
you
> need
> > the simple old features of the old tech, they're no longer a
> standard
> > item, and you pay $$
> > >So I guess the next step is custom building one, e.g. with
> > >experimental/evaluation boards or from scratch.
> > >Not my piece of cake...
> > Well, I did some investigating, and got the basic RS232 adapter
> test
> > code up and working with serial loopback on my dev board, and
read
> > through the manual about setting up the avr USART for synchronous
> > communication, which looks really simple... (though will have to
> build
> > some buffer circuits, and then do more testing running it in
> loopback,
> > while being externally clocked form the emax, before I can say
> it'll
> > even be approaching being a possibly being useful solution)
> > note: this will never work as well as a proper US$399 synchronous
> > interface, because it will be limited by whatever buffer size
that
> can
> > be made in the AVR(which has only 8k of ram), after the USB stack
> and
> > the basic code takes everything it needs, but it's possible that
> maybe
> > with a bit of tweaking, it can be made to work well enough to
send
> and
> > receive packets for the emax... as long as it's allowed to spend
a
> bit
> > of time shuffling data to/from the PC between packets....
> > so - how big are the packets that the emax sends and receives,
> anyway??
> > >I guess experimenting with the CTS/RTS signals also does not
make
> > >sense anymore, right ? I thought it could be a way to keep the
> > >drifting under control... I guess not...
> > nope... sorry... it's the mechanism for either side of the comms
> pair to
> > say "hold up! I've had enough!!" to the other side, instead of
just
> > overflowing and crapping out...
> > looking at my service manual again, I don't see CTS or RTS here
> > either.... just tx, rx, and clock. so I guess that's all we need,
> to
> > talk to the emax from a PC?
> > >And I'm still a bit afraid that it could damage my PC RS422 port
> > >since the RTS/CTS pins are expecting either positive or negative
> > >voltages but not a mixture of them. Or are those ports typically
> > >protected against this "abuse" ?
> > They are protected, to some degree.
> > btw, "+" and "-" do not refer to the voltage polarity of a
balanced
> > signal, they refer to the logical polarity. in this case, I think
> you'll
> > find RS422 + and - parts of a signal are both always in the range
> of 0V
> > to 5V, but the "+" is 5V when the "-" is 0v, and the "-" is 5V
when
> the
> > "+ is 0v....
