Emax
Bank transfer between Mac and Emax seems to be possible...
2008-11-16 by esynthesist
*Newsflash*
Today I managed to transfer banks between my Mac Classic and my Emax
Plus with Sound Designer for Emax 1.12.
I just had to hack the Emax OS a little bit :-)
*More information*
Just like Sound Designer for Emulator II, the SD for Emax 1.12
software has a special menu item for sending and receiving complete
banks via RS422.
But... it didn't work until now because Digidesign hardcoded
a "version revision" test of the Emax operating system.
According to SD for Emax you must have a "rev 4.0 or higher" to be
able to use these features. And as we all know, none of the Emax OS
have this high rev. number.
(Well, the software seems to accept the Emax II OS 2.14, but
unfortunately the Emax II OS doesn't support the bank load/unload
feature)
Emu did however add support for fast bank transfer in some of the
available OS versions.
So I thought: let's hack the OS and increase the revision number in
it...
So I created an Emax Plus OS rev 4.0 :-) and guess what:
SoundDesigner for Emax accepts this hacked version as a 4.0 one !
...and moreover the transfer function works 100% !
The total transfer time for loading banks from Mac to Emax takes 25
seconds. The opposite direction takes about 40 seconds, which is a
bit slow but fortunately this transfer direction is not that
interesting...
This feature is a perfect alternative for people owning an Emax
without SCSI, especially the Emax with rev1 boards.
One important note however: this "hack" does not work on all Emax OS
versions.
To be more accurate: although Sound Designer accepts ALL hacked Emax
OS versions as a "4.0 or higher", some of these Emax OS simply do not
support bank transfers.
Following versions succeeded in my tests:
- Emax SE 1.1
- Emax HD SE 1.1
- Emax Plus 1.0
But the other ones do not support the fast bank transfer option:
- Emax 3.2
- Emax HD 1.1
I guess this is not a big problem, because as far as I know one or
more of the "OK" versions can also be used on "non OK" Emax samplers,
right ?
E.g. I think it's possible to run the Emax SE 1.1 on a basic non-SE
Emax, right ?
It's strange though that the Emax 3.2 does not support the bank
transfer option, since Emulatorarchive mentions that this version
added OMI CDROM support and I assume that these CD drives used the
very same bank transfer method...
Conclusion:
I you have an old Mac (Classic, Classic II), Sound Designer for Emax
1.12 (hard to find, see message 3741) and an appropriate cable (see
Emulatorarchive), you can transfer banks between the Emax and the Mac
if your Emax accepts the SE, HD SE or Plus OS.
All you need is a hacked version of the OS, which I can put somewhere
in the files section if people are interested.
///E-Synthesist
Re: [emax] Bank transfer between Mac and Emax seems to be possible...
2008-11-17 by Dave Sotnick
This is awesome! I had always wondered about that rev 4.0 restriction
in Sound Designer. What an elegant way to hack around it, and who knew
it would actually work by changing the ASCII version number string in
the Emax OS EPROM.
Bravo!
-Dave
On Sun, Nov 16, 2008 at 2:04 PM, esynthesist <esynthesist@...> wrote:
> *Newsflash*
> *More information*
> banks via RS422.
> feature)
> it...
> interesting...
> versions.
> - Emax SE 1.1
> - Emax HD SE 1.1
> - Emax Plus 1.0
> - Emax 3.2
> - Emax HD 1.1
> right ?
> Emax, right ?
> Conclusion:
> ///E-Synthesist
Re: Bank transfer between Mac and Emax seems to be possible...
2008-11-17 by esynthesist
The big challenge for most Emax users will be to get hands on Sound
Designer for Emax. As far as I know it's not downloadable anywhere,
and if I understand it well the software uses a strange "copyright"
lock: a copied version of the software can not be used because the
software looks for its original disk (I have no idea if this was a
commonly known Mac security feature...). As a result, to copy the
software the whole disk must be copied as a disk image.
I'm even wondering if SD for Emax 1.12 was the last version ever
released ? Perhaps Digidesign released a higher version which did not
require this "hack" of the Emax OS anymore ??
I can not imagine that Emu and Digidesign did not cooperate on this:
Emu should have informed Digidesign that they would stop their
numbering method with rev 3.2 and restart numbering again at 1.0 but
with OS indicators added such as "SE" or "Plus". I guess Emax SE 1.0
is the same as the intended Emax Software Rev 4.0, the one Digidesign
was actually waiting for...
Anyway: SD for Emax is checking the Emax OS version by sending a
SYSEX MIDI message(request to send misc. info) to the Emax. One of
the return values is a 16 byte string containing a description of the
Emax OS. This is not the string in the Eprom, but the one saved on
the disk. By simply replacing this 16 byte string in the OS binary
(e.g. the OS file produced by EMXP) and copying the updated OS back
to the floppy disk, the hack is fully operational. It's as simple as
that. For my Emax I replaced the string "Emax Plus rev1.0" by "Emax
Plus rev4.0". That's all...
///E-Synthesist
restriction
knew
in
> the Emax OS EPROM.
> Bravo!
> -Dave
wrote:
> > *Newsflash*
Emax
> > *More information*
complete
> > banks via RS422.
OS
> > feature)
in
> > it...
25
> > interesting...
OS
> > versions.
Emax
not
> > - Emax SE 1.1
> > - Emax HD SE 1.1
> > - Emax Plus 1.0
> > - Emax 3.2
> > - Emax HD 1.1
samplers,
> > right ?
SE
> > Emax, right ?
> > Conclusion:
Emax
(see
Mac
somewhere
> > ///E-Synthesist
Emax SCSI Upgrade chip kits - 11 available
2008-11-19 by Ted Summers
Installation Tips / Recommendations now available at:
http://djtbs1.spaces.live.com/default.aspx
Pictures of the Rev 2 and 3 Emax boards at above link so you know what
you are looking for to determine whether the upgrade will work in your
Emax or Baldwin IKE.
The same rules apply that did before as per the SCSI upgrade docs at
Emulator Archive- Instructions here:
http://www.emulatorarchive.com/assets/PDF/Emax%20Plus%20SCSI%20Retro%20Instructions.pdf
a rev 3 board will take the chips- no board mods.....
a rev 2 board needs modified
a rev1 cannot be upgraded.
I have full Chipsets in stock. The cost of the kit is $50 USD +
shipping.
THIS SET DOES NOT INCLUDE A HARD DISK or the- but can be used with
SCSI Zip,
SCSI Compact Flash / SD, SCSI hard drive, etc. IDE CF works via an
ACARD SCSI adapter.....
This set does not include an "external SCSI adapter board", or
external connector.
To provide that would increase the cost of the kit.
Each set of chips will be tested in my Emax to verify operation prior
to shipping.
Kit also includes:
28-pin socket for the EPROM and some connect wire for the mods that
need to be made.
HD-capable Emax OS disk (either SE or Non-SE)
You will need-
A SCSI drive
A mounting plate (make one or a 5 1/4 to 3 1/2 in drive bay converter
kit / rails may work for this purpose also.
A power splitter - I am not including this as I have different reports
as to whether this is needed for all emax.
Soldering skills
The PDF from Emulator Archive on how to do the modification.
I need the following information from those ordering:
Is your emax rev 2 or rev 3 (so I know whether I need to supply the
socket)
Is your emax SE or Non-SE? (So I supply you the right disk).
Ted Summers
Paypal accepted: djtbs1@...
Will the drive in a macintosh classic work in the emax??????
2008-11-19 by J N.
Hey Every body
 I need a drive for my emax se.So i was hoping the drive in the classic macintosh would work in the keyboard???any info on this would help ALOT.
THANX
--- On Wed, 11/19/08, Ted Summers <djtbs1@gmail.com> wrote:
Subject: [emax] Emax SCSI Upgrade chip kits - 11 available
To: emax@yahoogroups.com
Date: Wednesday, November 19, 2008, 1:51 AM
http://djtbs1. spaces.live. com/default. aspx
http://www.emulator archive.com/ assets/PDF/ Emax%20Plus% 20SCSI%20Retro% 20Instructions. pdf
shipping.
SCSI Zip,
external connector.
to shipping.
Kit also includes:
need to be made.
You will need-
A SCSI drive
Soldering skills
socket)
Ted Summers
Paypal accepted: djtbs1@gmail. com
Re: [emax] Will the drive in a macintosh classic work in the emax??????
I believe that is what I used before I got Compact flash.
It was out of some old Mac version that was 20MB
Ted
On Nov 18, 2008, at 11:55 PM, J N. wrote:
Hey Every body
help ALOT.
THANX
shipping.
SCSI Zip,
external connector.
to shipping.
Kit also includes:
need to be made.
You will need-
A SCSI drive
Soldering skills
socket)
Ted Summers
Re: Will the drive in a macintosh classic work in the emax??????
2008-11-19 by Niklas Noren
A mac HD does work.
I have one 100MB in my Emax SE.
But the Emax only format 20MB of it.
/niklas
--- In emax@yahoogroups.com, "J N." <jaedooemax@...> wrote:
> Hey Every body
help ALOT.
> THANX
> From: Ted Summers <djtbs1@...>
what
your
at
> shipping.
> SCSI Zip,
> external connector.
prior
> to shipping.
> Kit also includes:
> need to be made.
> You will need-
> A SCSI drive
converter
reports
> Soldering skills
> socket)
> Regards,
> Ted Summers
Re: [emax] Re: Will the drive in a macintosh classic work in the emax??????
2008-11-20 by J N.
Hey Everyone
 I apologize that's really good to know about the hard drive,But i meant the floppy ;-)
can i use the floppy from the macintosh classic in the emax se????
THANX AGAIN
--- On Wed, 11/19/08, Niklas Noren <niklas627@...> wrote:
Subject: [emax] Re: Will the drive in a macintosh classic work in the emax??????
Date: Wednesday, November 19, 2008, 3:33 PM
A mac HD does work.
/niklas
--- In emax@yahoogroups. com, "J N." <jaedooemax@ ...> wrote:
> Hey Every body
help ALOT.
> THANX
> To: emax@yahoogroups. com
what
your
at
> shipping.
> SCSI Zip,
> external connector.
prior
> to shipping.
> Kit also includes:
> need to be made.
> You will need-
> A SCSI drive
converter
reports
> Soldering skills
> socket)
> Regards,
> Ted Summers
2008-11-20 by Niklas Noren
If I remember it right is the Emax disk drive a Shugart drive.
Some old mac did have Shugart drives.
I think that you can try to replace your broken floppy drive with an
old mac drive.
Lots of other samplers and synths did have Shugart drives, like
Ensoniq VFX-sd, SD and EPS, Korg 01/W, and Casio FZ-1.
/niklas
> Hey Everyone
> THANX AGAIN
> From: Niklas Noren <niklas627@...>
the emax??????
> A mac HD does work.
> /niklas
> > Hey Every body
would
> help ALOT.
> > THANX
> > --- On Wed, 11/19/08, Ted Summers <djtbs1@> wrote:
> > From: Ted Summers <djtbs1@>
> what
> your
> at
> > shipping.
with
> > SCSI Zip,
> > external connector.
> prior
> > to shipping.
> > Kit also includes:
that
> > need to be made.
> > You will need-
> > A SCSI drive
> converter
> reports
> > Soldering skills
> > socket)
> > Regards,
> > Ted Summers
2008-11-20 by Chip
you can use almos any floppy drive
just look at the back. or remove back cover and look for 3 solders points that say DS0
DS1. you have to make it DS0, so grab a solder and do it.
it's cheap and easy... a floppy drive can cost 5 bucks.
chip
> old mac drive.
> /niklas
> --- In emax@yahoogroups.com, "J N." <jaedooemax@> wrote:
> > Hey Everyone
> > THANX AGAIN
> > --- On Wed, 11/19/08, Niklas Noren <niklas627@> wrote:
> > From: Niklas Noren <niklas627@>
> the emax??????
> > A mac HD does work.
> > /niklas
> > > Hey Every body
> would
> > help ALOT.
> > > THANX
> > what
> > your
> > at
> > > shipping.
> with
> > > SCSI Zip,
> > > external connector.
> > prior
> > > to shipping.
> > > Kit also includes:
> that
> > > need to be made.
> > > You will need-
> > > A SCSI drive
> > converter
> > reports
> > > Soldering skills
> the
> > > socket)
> > > Regards,
> > > Ted Summers
