Emax
EMAX II - CD-ROM problem
2001-12-17 by nashy_boyuk
I have both an Emax II KBD & EMAX II Turbo.  I also have an Apple
CD-150 CD-Rom.  This works perfectly with my EIIIXP & ESI but I can't
get either of the EMAX's to see it.
The EMAX II Turbo has an internal HDD (SCSI id 4) and I've set the
CD-Rom to SCSI id 2 but when the EMAX scans that id it hangs.  I have
a terminator connected to the CD-Rom and only have the EMAX and CD
connected with a single cable - I've also tried disconnecting the
terminator and adding other items to the chain with no luck.
Any suggestions ?
Regards
Paul
Re: [emax] EMAX II - CD-ROM problem
2001-12-17 by Bob Conner
I was never able to get an Apple CD ROM to work.
I had to find one of the old (very) Toshiba SCSI
drives. There were only a few models that work, but I
found one with a similar model number that did.
The adminstrator of this group has a list of drives
known to work.
Bob
--- nashy_boyuk <nashy_boyuk@...> wrote:
> Hi,
> have an Apple
> & ESI but I can't
> and I've set the
> it hangs.  I have
> the EMAX and CD
> disconnecting the
> no luck.
> Any suggestions ?
> Regards
> Paul
Do You Yahoo!?
Check out Yahoo! Shopping and Yahoo! Auctions for all of
your unique holiday gifts! Buy at http://shopping.yahoo.com
or bid at http://auctions.yahoo.com
RE: [emax] EMAX II - CD-ROM problem
2001-12-17 by Rob EmuArc
The Emax II doesn't like some Apple CDROM drives, other users have reported
problems with the CD150. Try a different CDROM drive.
Rob
  Sent: 17 December 2001 11:37
  To: emax@yahoogroups.com
  Subject: [emax] EMAX II - CD-ROM problem
  Any suggestions ?
  Regards
  Paul
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Emax and Emax II User's Group
  http://www.silveriafamily.com
2001-12-18 by Skip Spoula
I've had very good luck with a Plextor 4Plex drive with my EIII as well as my Emax II. As a matter of face heres one on EBAY for you. http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1311071873
Good luck to you,
Skip
  Sent: Monday, December 17, 2001 5:37 AM
  Any suggestions ?
  Regards
  Paul
              ADVERTISEMENT
