Emax
Emax II Floppy drive tip
2006-06-02 by thligrdd
The Mitsumi D359T3 is compatible with the Emax II. I have successfully
installed one into mine, the jumpers are relatively easy to access
(right in the back) - mine works with "SW" jumpered and set to ID0.
from a pin perspective, in the format:
1  2  3  4  5  6
7  8  9  10 11 12
10 and 11 should be jumpered, and 3 and 9 should be jumpered. There's
a legend next to the pins anyway, so it should be pretty obvious. :)
This drive is easy to find on ebay and very cheap. It's not
half-height or whatever form factor the original drive is, so you'd
have to make a bracket - but it works quite well so far.
Re: Emax II Floppy drive tip
2014-12-23 by ozgoskar@...
hello could someone help me to set it to id 0? i also have this floppy disk drive and it wont work for me. do i need to do any other modifications than setting the jumpers?
