Emax
Emax Output distorted
2015-09-25 by krikor kouchian
Hello
I'm having a distorted output on my emax.
I recaped the whole analog board, everything was fine, I didn't use it for 2 weeks and when i put it back one, the main output was distorted, like aliased.
I check the separate output and they are the same.
I try to change for another PSU and it acts the same.
here is the sound file:
Any one had a similar problem?
best
K
http://www.krikor.fr
+33632199413
For Live&Dj bookings contact: cedric@referenceprods.fr
RE: [emax] Emax Output distorted
2015-09-25 by Shawn Ward
do you get distortion on all samples/banks that you load?
i had some problems with distortion that were software related to corrupt data in the banks
you should rule this out before troubleshooting a hardware problem
also i have noticed if i have the keyboard local on i get some alias behaviour so i saved all my samples after taking local off
To: emax@yahoogroups.com
Date: Fri, 25 Sep 2015 15:36:21 +0200
Subject: [emax] Emax Output distorted
Hello
best
K
+33632199413
For Live&Dj bookings contact: cedric@...
Re: Emax Output distorted
Yes distortion on all banks, my own, some factory ones…
I have a rack version.
Le vendredi 25 septembre 2015, Shawn Ward shawnjward@... [emax] <emax@yahoogroups.com> a écrit :
> From: emax@yahoogroups.com
> Hello
>; I recaped the whole analog board, everything was fine, I didn't use it for 2 weeks and when i put it back one, the main output was distorted, like aliased.
> https://dl.dropboxusercontent.com/u/35667344/Emax%20Ouput%20mono.aif
> best
> K
> +33632199413
+33632199413
RE: [emax] Re: Emax Output distorted
2015-09-26 by Jose
Krikor
I have the exact same thing happen on my emax rack.  I do not recommend you do what I did but it temp fixed  mine for a few months.  Out of despair, unable to figure out, anger led me and  I took the butt end of a screwdriver and give it a few hits to the right of the LCD about 2 inches and 2 inches down by where the text menu printing are while playing a sample. After a about 3 hits, the sound returned to normal. If you decide to try, place a thin cloth to avoid scratching the face.  I hit it like when hitting drum pads strength.  I still don't know what it fixed/unstuck.  It's happened a few times again, but the hit fixes it for me until I can find out what is in that area that needs a hit to get rid of the distorted hiss noise.  Your could be different but mine had the exact sound in your clip.  For legal reasons and the record, I do not advise you do this and do at your own risk.  Good luck.
From: "krikor kouchian krikorola@... [emax]" <emax@yahoogroups.com>
Sent: ‎9/‎25/‎2015 1:58 PM
To: "emax@yahoogroups.com" <emax@yahoogroups.com>
Subject: [emax] Re: Emax Output distorted
> Hello
> best
> K
> +33632199413
+33632199413
Re: [emax] Re: Emax Output distorted
2015-09-26 by Ted Summers
My suggestion- reseat the chips on the Audio board which are socketed.
-T
On Sep 25, 2015, at 8:40 PM, Jose housemusicmaker@... [emax] <emax@yahoogroups.com> wrote:
Krikor
From: krikor kouchian krikorola@gmail.com [emax] <mailto:emax@yahoogroups.com>
To: emax@yahoogroups.com <mailto:emax@yahoogroups.com>
Le vendredi 25 septembre 2015, Shawn Ward shawnjward@... <mailto:shawnjward@hotmail.com> [emax] <emax@yahoogroups.com <mailto:emax@yahoogroups.com>> a écrit :
> From: emax@yahoogroups.com <mailto:emax@yahoogroups.com>
> Hello
> https://dl.dropboxusercontent.com/u/35667344/Emax%20Ouput%20mono.aif <https://dl.dropboxusercontent.com/u/35667344/Emax%20Ouput%20mono.aif>
> best
> K
> http://www.krikor.fr <http://www.krikor.fr/>
> +33632199413
> For Live&Dj bookings contact: cedric@... <mailto:cedric@...>
+33632199413
2015-09-26 by krikor kouchian
Yes
I did it in the past, I think it is time for a ultrasonic bath or changing all the socket!
Best
K
Le samedi 26 septembre 2015, Ted Summers djtbs1@... [emax] <emax@yahoogroups.com> a écrit :
> -T
> Krikor
> From: krikor kouchian krikorola@... [emax]
>> Hello
>> best
>> K
>> +33632199413
> Posted by: Ted Summers <djtbs1@...>
> Reply via web post • Reply to sender • Reply to group •
+33632199413
