At 10:28 AM 10/9/2014, you wrote:
>In my experience, the Emax does not respond to Sys-Ex fast enough for real-time parameter changes. I had a template for my Remote Zero, that allowed me to make changes, but the reaction time was always too slow, and inconsistent. That being said there are still four real-time parameters that can be assigned to most of the modulation destinations making the filter cutoff/resonance and LFO depth/rate controllable in real time. I have learned to accept this limitation.
Most samplers/synths do a note-off when receiving sys-ex. Emax doesn't?
Sys-Ex was never designed for this type of thing. That's what continuous controllers are for, and you are stuck with the routings the Emax gives you.
Garth Hjelte
Sampler User
