Emax Sample Release High Pitch Noise
2014-07-05 by bry_204@...
Hi all,
Just wondering if this high pitched noise a the end of this sample is normal? I've noticed if I shorten the length of the MIDI note, the noise will go away. It's like it's some kind of high pitched noise that gets triggered after the same is finished playing. If the key is held down, you hear the noise.
I've attached both versions with the longer notes, and shorter.
https://www.dropbox.com/s/xr3bcyg7tfisci6/909HH_D1V1_Emax_31kHz.wav
https://www.dropbox.com/s/ p8hyskae17i69yw/909HH_D1V1_ Emax_31kHz-1.wav
