Emax SE Monophonic
2014-06-13 by bry_204@...
2014-06-14 by KW
use separate outs, they are monophonic ;) ________________________________ Från: "bry_204@... [emax]" <emax@yahoogroups.com> Till: emax@yahoogroups.com Skickat: fredag, 13 juni 2014 17:49 Ämne: [emax] Emax SE Monophonic Hi, I just picked up an E-mu Emax SE rack and I'm still trying to wrap my head around the settings in the unit. One thing I can't seem to figure out, is how to make the unit switch from polyphonic to monophonic? Is this possible? Thanks
2014-06-14 by Michael Laursen
It is located in the "Analog Processing Module" # 21 . pp107 in manual. it's called Solo .
On 13-06-2014 17:49, bry_204@... [emax] wrote: > > Hi, > I just picked up an E-mu Emax SE rack and I'm still trying to wrap my > head around the settings in the unit. One thing I can't seem to figure > out, is how to make the unit switch from polyphonic to monophonic? Is > this possible? > > Thanks > > >
2014-06-14 by Krikor
You choose which voice are active in the advance settings. If you disable all except one it will be monophonic http://www.krikor.fr +33632199413 Booking dj & live: cedric@...
> Le 14 juin 2014 à 12:43, "KW memtechlist@... [emax]" <emax@yahoogroups.com> a écrit : > > use separate outs, they are monophonic ;) > > Från: "bry_204@...m [emax]" <emax@yahoogroups.com> > Till: emax@yahoogroups.com > Skickat: fredag, 13 juni 2014 17:49 > Ämne: [emax] Emax SE Monophonic > > > Hi, > I just picked up an E-mu Emax SE rack and I'm still trying to wrap my head around the settings in the unit. One thing I can't seem to figure out, is how to make the unit switch from polyphonic to monophonic? Is this possible? > > Thanks > > > >
2014-06-15 by bry pro
Thanks, this is the setting I was looking for. Is there a way to do a "glide" style pitch bending to other notes?
"It is located in the "Analog Processing Module" # 21 . pp107 in manual.
it's called Solo ."
On Saturday, June 14, 2014 6:01 AM, "Michael Laursen michael@... [emax]" <emax@yahoogroups.com> wrote:
it's called Solo .
>Hi,
from polyphonic to monophonic? Is this possible?> >Thanks > > >
2014-06-15 by Michael Laursen
No doesn't exist. But another thing that can be very interesting in this solo mode ( there might be another parameter to be set somewhere but I dont remember right now) Try this: load a sample with some speaking sentences, or singing. spread the sample out in about two octaves. Now play, what is happening (or supposed to) is that the sample is not retriggered but is transposed to the new note. so you can play melodies or make singing out of the speaked sentence. Were funny and useabel at times.. :)
On 15-06-2014 02:33, bry pro bry_204@... [emax] wrote: > Thanks, this is the setting I was looking for. Is there a way to do a > "glide" style pitch bending to other notes? > > "It is located in the "Analog Processing Module" # 21 . pp107 in manual. > it's called Solo ." > > > On Saturday, June 14, 2014 6:01 AM, "Michael Laursen > michael@... [emax]" <emax@yahoogroups.com> wrote: > > > It is located in the "Analog Processing Module" # 21 . pp107 in manual. > it's called Solo . > > > On 13-06-2014 17:49, bry_204@... <mailto:bry_204@...> > [emax] wrote: >> Hi, >> I just picked up an E-mu Emax SE rack and I'm still trying to wrap my >> head around the settings in the unit. One thing I can't seem to >> figure out, is how to make the unit switch from polyphonic to >> monophonic? Is this possible? >> >> Thanks >> > > > >
2014-08-10 by djrgary@...
It is monophonic, however it has capacities of effects processing in stereo. If you are seeking monophonic output then connect to the right output as it is mono. You may wish to download the owners manual
