Cgs synth
CGS114 DUSG problems/troubleshooting
2012-10-10 by ch1nard
Okay, i have been staring at this for almost a week without making any progress so its time to start asking around for help on figuring out what might be wrong with my DUSG build
I am running this off +/-15v power supply and i have all the connections appear to be correct with no magic smoke escaping
What is happening is that the output lights are lit up constantly.
When i hook it up to a scope it appears that both halves are cycling (triangle) at about only 300mV p/p
-fiddling with the rise/fall gives minor variations but is still a triangle. (never hits saw or ramp)
-feeding LFO into VC in shows the same minor variances as fiddling with the rise/fall knobs. bipolar control seems to work
-feeding a signal IN combines the signal with this triangle oscillation
-trig and end do nothing
now everything 'appears' to be wired up correctly and there were a couple of lifted pads that i was able to jumper patch around.
building this as part of a 'best of cgs' BOG panel, so the wiring is well documented.
I have verified +/- voltage being delivered to all the TL072's and verified + voltage for the LM3900's
ground appears to be delivered as well.
all the trans are correct value and orientation (2N3904 and 2N3906) where applicable
Anyways, eyes are too tired to look at this anymore tonight...
time to smoke a bowl and watch some doctor who.
Re: CGS114 DUSG problems/troubleshooting
2012-10-10 by Rico Loverde
Are the trannies situated like the silk screen on the pcb or reversed? They
should be reversed.
> documented.
> applicable
________________
rico loverde
415.596.6255
ricoloverde.com
2012-10-10 by sasami@hotkey.net.au
Also make sure you are using the right sort of tranny! I had people with
this problem on another project - and they had used the wrong sort of tranny.
>should be reversed.
>> documented.
>> applicable
>________________
>rico loverde
>415.596.6255
>ricoloverde.com
>The CGS Modular Synth home page: http://www.cgs.synth.net/
>Yahoo! Groups Links
_______________________________________________________________________
Ken Stone sasami@... otherunicorn@...
Modular Synth PCBs for sale <http://www.cgs.synth.net/>
Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
ah yes, you appear to be correct good sir :)
this would be reverse orientation for all trannies? (2N3904 and 2N3906)
i will switch them around after i get home from work and see if that fixes things up.
might need to hit up the parts store on the way home in case i pooched any of them from being in backwards
> >should be reversed.
> >> documented.
> >> applicable
> >________________
> >rico loverde
> >415.596.6255
> >ricoloverde.com
> >Yahoo! Groups Links
2012-10-11 by ch1nard
okay awesome, that was totally it
Now other than the fact that i have the pots wired backwards DUSG seems functional!
> > >should be reversed.
> > >> documented.
> > >> applicable
> > >________________
> > >rico loverde
> > >415.596.6255
> > >ricoloverde.com
> > >Yahoo! Groups Links
> > Ken Stone sasami@ otherunicorn@
2012-10-11 by Rico Loverde
awesome!!!
> functional!
> fixes things up.
> with
> tranny.
> reversed? They
> > > >should be reversed.
> any
> out what
> connections
> with
> oscillation
> couple
> is well
> > > >> documented.
> where
> > > >> applicable
> > > >________________
> > > >rico loverde
> > > >415.596.6255
> > > >ricoloverde.com
> > > >Yahoo! Groups Links
________________
rico loverde
415.596.6255
ricoloverde.com
2012-10-11 by Stephen Richards
My all time favourite Serge function block , DUSG rocks.
To: cgs_synth@yahoogroups.com
Sent: Thursday, October 11, 2012 1:51 PM
Subject: Re: [cgs_synth] Re: CGS114 DUSG problems/troubleshooting
awesome!!!
> functional!
> fixes things up.
> with
> tranny.
> reversed? They
> > > >should be reversed.
> any
> out what
> connections
> with
> oscillation
> couple
> is well
> > > >> documented.
> where
> > > >> applicable
> > > >________________
> > > >rico loverde
> > > >415.596.6255
> > > >ricoloverde.com
> > > >Yahoo! Groups Links
________________
rico loverde
415.596.6255
ricoloverde.com
Yahoo! Groups Links
2012-10-12 by richmolindarius@gmail.com
Fully agreed. The USG is my fave by far with the SSG following up in a close 2nd. :D
> From: Rico Loverde <ricoloverde@...>
> awesome!!!
> > functional!
> > fixes things up.
> > with
> > tranny.
> > reversed? They
> > > > >should be reversed.
> > any
> > out what
> > connections
> > with
> > oscillation
> > couple
> > is well
> > > > >> documented.
> > where
> > > > >> applicable
> > > > >________________
> > > > >rico loverde
> > > > >415.596.6255
> > > > >ricoloverde.com
> > > > >Yahoo! Groups Links
> ________________
> rico loverde
> 415.596.6255
> ricoloverde.com
2013-01-06 by adematteo
Not sure if this is the best way to do this ? but figured if someone in the future searches better to have a few problems in 1 thread.
Anyhow, i have 1 (1/2 of the board) of my dusg's working perfectly and the other not working at all as expected.
The problem is no recognition of a trigger input or signal in for that matter unless i have the fall pot full cw then it seems to go into a slow self cycling.It needs a trigger to start this but does not sync with the trigger at all.As soon as i back off to about 2-3 o'clock it stops.
These are the things i have checked/verified against the working half:
-All ic;s getting and sending the same voltages as working half
-Diode orientations
-resitor values
-Transistor orientation,proper part,voltages the same as working half
-continuity through path of trig in to output
-checked for solder bridges
I'm out of ideas so i will really appreciate it if someone has some advice !
Thanks, Tony
> > From: Rico Loverde
> > awesome!!!
> > > functional!
> > > fixes things up.
> > > with
> > > tranny.
> > > reversed? They
> > > > > >should be reversed.
> > > any
> > > out what
> > > connections
> > > with
> > > oscillation
> > > couple
> > > is well
> > > > > >> documented.
> > > where
> > > > > >> applicable
> > > > > >________________
> > > > > >rico loverde
> > > > > >415.596.6255
> > > > > >ricoloverde.com
> > > > > >Yahoo! Groups Links
> > ________________
> > rico loverde
> > 415.596.6255
> > ricoloverde.com
> > Yahoo! Groups Links
2013-01-06 by sasami@hotkey.net.au
Check your wiring. Make sure you haven't got your pot and trigger wires swapped.
Ken
>-Diode orientations
>-resitor values
>Thanks, Tony
close 2nd. :D
>> > From: Rico Loverde
>> > awesome!!!
>> > > functional!
>> > > fixes things up.
>> > > with
>> > > tranny.
>> > > reversed? They
>> > > > > >should be reversed.
>> > > any
>> > > out what
>> > > connections
cycling
>> > > with
>> > > oscillation
>> > > couple
>> > > is well
>> > > > > >> documented.
2N3906)
>> > > where
>> > > > > >> applicable
>> > > > > >________________
>> > > > > >rico loverde
>> > > > > >415.596.6255
>> > > > > >ricoloverde.com
>> > > > > >Yahoo! Groups Links
>> > ________________
>> > rico loverde
>> > 415.596.6255
>> > ricoloverde.com
>> > Yahoo! Groups Links
>Yahoo! Groups Links
2013-01-07 by Mongo
I have had trouble getting DUSGs to work as well, and there is a technique I've found that seems to help quite a lot.
I print out the picture Ken has on the webpage that shows the PC board traces. I then sit down with that page, a highlighter, the pc board, and an ohmmeter, and I check every single trace for continuity. The traces on these boards are somewhat fragile, especially if you use lead free solder (which requires higher temperatures). Just be patient and you can get through the whole thing in an hour or two. Whenever I've had a DUSG failure, this has found the problem for me.
That being said, I'm troubleshooting a friend's VCS right now, and this hasn't helped a bit ;-)
Anyway, give that a try. Chances are you will find an open trace.
Gary
> -Diode orientations
> -resitor values
> Thanks, Tony
> > > From: Rico Loverde
> > > awesome!!!
> > > > functional!
> > > > fixes things up.
> > > > with
> > > > tranny.
> > > > reversed? They
> > > > > > >should be reversed.
> > > > any
> > > > out what
> > > > connections
> > > > with
> > > > oscillation
> > > > couple
> > > > is well
> > > > > > >> documented.
> > > > where
> > > > > > >> applicable
> > > > > > >________________
> > > > > > >rico loverde
> > > > > > >415.596.6255
> > > > > > >ricoloverde.com
> > > > > > >Yahoo! Groups Links
> > > ________________
> > > rico loverde
> > > 415.596.6255
> > > ricoloverde.com
> > > Yahoo! Groups Links
2013-01-07 by adematteo
Thanks Gary i'll give that a shot.Your right i did use lead free solder and it's very difficult to tell if you have a nice joint so this technique will be helpful.
Thanks Ken but i've checked the wiring so many times i have it memorized.
I'll report back when i get this bugger working.
Tony
> Gary
> > -Diode orientations
> > -resitor values
> > Thanks, Tony
> > > > From: Rico Loverde
> > > > awesome!!!
> > > > > functional!
> > > > > fixes things up.
> > > > > with
> > > > > tranny.
> > > > > reversed? They
> > > > > > > >should be reversed.
> > > > > any
> > > > > out what
> > > > > connections
> > > > > with
> > > > > oscillation
> > > > > couple
> > > > > is well
> > > > > > > >> documented.
> > > > > where
> > > > > > > >> applicable
> > > > > > > >________________
> > > > > > > >rico loverde
> > > > > > > >415.596.6255
> > > > > > > >ricoloverde.com
> > > > > > > >Yahoo! Groups Links
> > > > ________________
> > > > rico loverde
> > > > 415.596.6255
> > > > ricoloverde.com
> > > > Yahoo! Groups Links
2013-01-09 by adematteo
Ok, i tried the suggestion Gary gave me and unfortunately no luck but thank you for the useful tool.
I'm completely in the dark at this point so i want to explain whats happening and maybe someone can have an idea as to what could be acting up.
It will self cycle but only at it's own fixed pace and does not react to triggers or signal input.While cycling if i drop the voltage by decreasing the fall pot past about 2 o'clock it will stop cycling.The led flashes at about 1 second intervals regardless of were i position the pot as long as it's past the 2 o'clock point but when i'm measuring the voltage on the out it behaves how you would expect (at it's furthest cw setting it takes about 2-3 minutes to fully drop to zero) as long as i stay cw of 2 o'clock.
It also outputs a pulse at the end of cycle.
I've checked every single thing i can think of against the working half and everything seems to be the same, even the voltages on all the ic's and transistors.
Thanks for all the help and suggestions so far !
-Tony
> Tony
> > Gary
> > > -Diode orientations
> > > -resitor values
> > > Thanks, Tony
> > > > > From: Rico Loverde
> > > > > awesome!!!
> > > > > > functional!
> > > > > > fixes things up.
> > > > > > with
> > > > > > tranny.
> > > > > > reversed? They
> > > > > > > > >should be reversed.
> > > > > > any
> > > > > > out what
> > > > > > connections
> > > > > > with
> > > > > > oscillation
> > > > > > couple
> > > > > > is well
> > > > > > > > >> documented.
> > > > > > where
> > > > > > > > >> applicable
> > > > > > > > >________________
> > > > > > > > >rico loverde
> > > > > > > > >415.596.6255
> > > > > > > > >ricoloverde.com
> > > > > > > > >Yahoo! Groups Links
> > > > > ________________
> > > > > rico loverde
> > > > > 415.596.6255
> > > > > ricoloverde.com
> > > > > Yahoo! Groups Links
2013-01-09 by sasami@hotkey.net.au
Swap the LF353 IC. See if the fault moves with the IC or stays where it is.
Swap the transistors with a new set.
Ken
transistors.
>-Tony
will be helpful.
>> Tony
>> > Gary
>> > > -Diode orientations
>> > > -resitor values
advice !
>> > > Thanks, Tony
in a close 2nd. :D
>> > > > > From: Rico Loverde
>> > > > > awesome!!!
DUSG seems
>> > > > > > functional!
and 2N3906)
if that
>> > > > > > fixes things up.
i pooched
had people
>> > > > > > with
wrong sort of
>> > > > > > tranny.
>> > > > > > reversed? They
>> > > > > > > > >should be reversed.
without making
>> > > > > > any
figuring
>> > > > > > out what
>> > > > > > connections
constantly.
are cycling
is still a
as fiddling
>> > > > > > with
>> > > > > > oscillation
there were a
>> > > > > > couple
the wiring
>> > > > > > is well
>> > > > > > > > >> documented.
TL072's and
and 2N3906)
>> > > > > > where
>> > > > > > > > >> applicable
tonight...
>> > > > > > > > >________________
>> > > > > > > > >rico loverde
>> > > > > > > > >415.596.6255
>> > > > > > > > >ricoloverde.com
>> > > > > > > > >Yahoo! Groups Links
>> > > > > ________________
>> > > > > rico loverde
>> > > > > 415.596.6255
>> > > > > ricoloverde.com
>> > > > > Yahoo! Groups Links
>Yahoo! Groups Links
HOLY COW, i figured it out and i want to tell you guys but i really hope this doesn't earn me some sort of nickname because i'm pretty sure this may be a first.
Some how i used an led that is i believe a flashing led, i'm not quite sure but it does look to have a small black thing (ic ?) inside.
Either way when i put my meter on it it flashes at about 1 second intervals.Wow i get it now when people say each issue is unique !
I really appreciate your guys help i almost gave up on this one after replacing all the trannies and ic's but just figured that was the only active component i hadn't swapped so...
Thanks again for all the input i actually learned quite a bit on this one !
-Tony
> Ken
> transistors.
> >-Tony
> will be helpful.
> >> Tony
> >> > Gary
> >> > > -Diode orientations
> >> > > -resitor values
> advice !
> >> > > Thanks, Tony
> in a close 2nd. :D
> >> > > > > From: Rico Loverde
> >> > > > > awesome!!!
> DUSG seems
> >> > > > > > functional!
> and 2N3906)
> if that
> >> > > > > > fixes things up.
> i pooched
> had people
> >> > > > > > with
> wrong sort of
> >> > > > > > tranny.
> >> > > > > > reversed? They
> >> > > > > > > > >should be reversed.
> without making
> >> > > > > > any
> figuring
> >> > > > > > out what
> >> > > > > > connections
> constantly.
> are cycling
> is still a
> as fiddling
> >> > > > > > with
> >> > > > > > oscillation
> there were a
> >> > > > > > couple
> the wiring
> >> > > > > > is well
> >> > > > > > > > >> documented.
> TL072's and
> and 2N3906)
> >> > > > > > where
> >> > > > > > > > >> applicable
> tonight...
> >> > > > > > > > >________________
> >> > > > > > > > >rico loverde
> >> > > > > > > > >415.596.6255
> >> > > > > > > > >ricoloverde.com
> >> > > > > > > > >Yahoo! Groups Links
> >> > > > > ________________
> >> > > > > rico loverde
> >> > > > > 415.596.6255
> >> > > > > ricoloverde.com
> >> > > > > Yahoo! Groups Links
> >Yahoo! Groups Links
2013-01-09 by cg_synth
be a first.
Last year I was fixing on of JH's phasers with the two lightbulbs in it. One
globe failed, so I hunted around until I found a couple of matching 6V
globes and whacked them in. I had the same sort of problem. Damn thing kept
flashing at the wrong rate. I had used a pair of flashing globes.....
Yup, that's a flashing LED. It probably also has a very short third leg.
Ken
2013-01-10 by Richarius Molindarius
Now I'm stumped. The flashing LED where it is in the circuit, couldnthave
been responsibkw for the entore problem. .. Could it?
Im wondsring there if it actuallt IS CAUSing (oops) a problem by trying to
deag 20 mA to Ground from the opamp.
this doesn't earn me som...
but it does look to ...
Ken
Ken Stone sasami@... otherunic...
Modular Synth PCBs for sale http://www.cgs.synth.net/>
Australian Miniature Horses & Ponies http://www.blaze.net.au/~sasami/>
2013-01-10 by adematteo
Well i guess i'll check my led's from now on.I don't know how i ended up with it but i just have a bag of random led's and somehow it ended up in there.
Feeling good this thing is working now !
> be a first.
> Ken
