Cgs synth
CGS18 Drum simulator pitch drop question
2012-12-29 by Steve Inselman
Hello,
I have the twin-t drums with the res brought out to the front panel and a 500k pot from the 470k resistor which has given me a range from kick all the way up to a popping click. The pitch goes from the unmodified state on up but my question is how to drop it a couple octaves.
I know there are caps that can be altered in a 1 to 10 ratio but would I put higher or lower capacitors to get the desired effect?
What capacitor ratings would drop the kick about 2 octaves?
Has anybody tried this modification?
Re: CGS18 Drum simulator pitch drop question
2012-12-29 by sasami@hotkey.net.au
Double the value of the capacitor to halve the frequency = 1 oct down.
So 1n > 4n7 and 10n > 47n will give a bit over 2 octaves down for the 'kick'.
470p > 2n2 and 4n7 to 22n will give a bit over 2 octaves down for the other.
>Hello,
>The CGS Modular Synth home page: http://www.cgs.synth.net/
>Yahoo! Groups Links
_______________________________________________________________________
Ken Stone sasami@... otherunicorn@...
Modular Synth PCBs for sale <http://www.cgs.synth.net/>
Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
2012-12-30 by Steve Inselman
Great,
Thanks again Ken. I'll give it a shot. Hopefully I already have all the caps.
As for the Stiener VCF, I put a 2k pot on the res and it is self osc at close to half way and beyond that it is out of control It is very touchy. It goes out of control a the slightest adjustment.
The freq pot is still not opening up. I'll have to keep on troubleshooting.
To: cgs_synth@yahoogroups.com
Sent: Saturday, December 29, 2012 4:50 PM
Subject: Re: [cgs_synth] CGS18 Drum simulator pitch drop question
>Hello,
>Yahoo! Groups Links
2012-12-30 by sasami@hotkey.net.au
Resonance going out of control is a characteristic of the Sallen Key filter
type, so that is to be expected.
How many diodes do you have in your diode strings? What voltage are you
running at? If you are running on +/-12 and have all the diodes in, you may
have problems.
Ken
>Great,
goes out of control a the slightest adjustment.Â
>The freq pot is still not opening up. I'll have to keep on troubleshooting.Â
I'm running +/-15v. It is just a slight adjustment and it goes from minimal res to full on osc.
I placed all the diodes in as directed. I've been troubleshooting this one for weeks before I wrote.
I've tried everything I can think of.
Sent: Sunday, December 30, 2012 4:06 PM
have problems.
Ken
>Great,
Perhaps try a different TYPE of transistor.
Ken
res to full on osc.
> From: "sasami@..." <sasami@...>
>have problems.
>Ken
>>Great,
>goes out of control a the slightest adjustment.ÂÂ
troubleshooting.ÂÂ
>Yahoo! Groups Links
Re: CGS18 Drum simulator Modification results list
2013-01-06 by Steve Inselman
I finally put the capacitors in and it works perfectly. It has a strong punchy low end BD on either side all the way up to clicking popping sounds. I highly recommend the modifications for a more versatile twin-t drum module.
500k pots where the 470k resistor is for pitch adjustment.
Change the capacitors: 1N to 4N7 and 10N-47N 470P-2N2 and 4N7-22N
They are the Caps connected to the 500k pots. This is to drop the pitch because the 500k pots only go from the unmodded pitch up to a click. These caps bring the Kick down to an almost unadioable range up to the popping sound (its a good sound) and the Tom down to a low BD up to the popping sound
Bring the Res to the front for "Decay" control. It lets the low BD ring longer to just a quick click. It is touchy when tuning it going into self-osc very easily.
Thanks for your help Ken.
Steve
>Hello,
>Yahoo! Groups Links
