Sequencer Step 6 HOLD not working
2011-12-06 by Stephen Richards
2011-12-06 by sasami@hotkey.net.au
>Hi Ken/Allpush button momentary switch will not halt the sequence when held down.
>I built the SWAMP panel and have found recently that the Step no 6
>_______________________________________________________________________
>All the other push button momentary switches do halt the sequence.
>This fault does not affect the sequencer's normal operation when being clocked.
>regards
>Stephen
>The CGS Modular Synth home page: http://www.cgs.synth.net/
>Yahoo! Groups Links
>regards
>Stephen
>Yahoo! Groups Links
>Hi Kenconstantly lit.
>Sequence will not jump to Step 6 when Button 6 is pressed.
>Here's what else i found :
>When the Seq is first powered up without anything patched ; step 6 is
>Pulse Divider) , the sequence always starts from Step 6.
>When something is patched to 'down' input (in this case the %2 out of the
>clocked.
>Stephen
> From: "sasami@..." <sasami@...>
>To: cgs_synth@yahoogroups.com
>Sent: Tuesday, December 6, 2011 5:34 PM
>Subject: Re: [cgs_synth] Sequencer Step 6 HOLD not working
>Â
>Does it cause the sequence to jump to step 6 when pressed?
>If not, you have a bad button, a fault with one of the diodes it feeds, or a
>bad connection somewhere areound that area.
>Ken
>>Hi Ken/All
>>All the other push button momentary switches do halt the sequence.Â
>>regards
>>Stephen
>>Yahoo! Groups Links
>Ken Stone sasami@... otherunicorn@...
>Modular Synth PCBs for sale <http://www.cgs.synth.net/>
>Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
>Yahoo! Groups Links
>clocked.
>Stephen
>Â
>Ken
>>Hi Ken/All
>>regards
>>Stephen
>>Yahoo! Groups Links
>Yahoo! Groups Links
