Cynare prob?
2007-01-24 by Pete
I have a bleed through problem with my Cynare. When the filter is all the
way open I can hear bleed through coming form the "shimmer" generator. Its
always there. I usually set the filter cutoff to be lower effectively
cutting out the bleed through, and I usually have to adjust the envelope to
get it just right. If I want to create a cymbal or hi hat sound I have to
set the envelope pot to the top center position and open up the filter to
get more of the high end freq's but this also allows the bleed through to be
heard. Is there a fix for this?
pete
http://www.myspace.com/23isgood
pete
