Archive for Simmons_Drums.
Index last updated: 2026-03-30 01:08 UTC
SDSV oscillator 'bleed'?
2019-04-20 by tubmyk2@...
Hey guys, question - I'm in the process of revamping my SDSV, which so far entailed a power supply recap and 110v transformer conversion.  This eliminated about 99.9% of the noise, hum and buzz I was getting through the unit on top of using the step-down transformer.
Now that it's so quiet, I notice that as I turn the tone clockwise on a module (pretty sure all modules will do it), the higher the pitch gets it will bleed through and be audible.  Looking at the schematic I can't figure out where the oscillator circuit is, but I do know that I was probing around one of the op amps (IC17, MC1458) and the components immediately surrounding it, and as I probed the different pins I would get a tone change.  I'm not sure what to look for on the scope, as I imagine this is all functioning correctly and 2 different cards that I've examined so far have done the same thing.
Has anyone else noticed this?  This was happening before the voltage conversion, now that I think about it, because I recall you could set the tone a little higher and there was always a little audible tone bleeding through.
I would love some guidance on this but I know it's a shot in the dark as it probably is by design....
Re: SDSV oscillator 'bleed'?
2019-04-22 by hr.public@...
You're correct IC17 are the tone oscillator. There are a minor difference for the snare module where the output low-pass filter (R120/C22) are not implemented.
You could measure and compare output of VCAs (IC9/IC10 CA3080 pin6) from a couple of module cards to check if the the OTA is defective. If you find you need to replace one of them this page might be of interest.
hans
