MTM mental meltdown
2016-11-14 by jesper
Hi hexaheads!
After my studio rebuild it is up and running again and I'm slowly
finding the trouble spots. The midi is messing with me, as is often the
case when I get into trouble.
After eliminating as much as possible, this works:
midi master keyboard midi out -> MTM midi in = trig success!
After hooking everything back as it should be:
midi chain is unbroken up to my midi patch which just echoes incoming
midi to seven outputs and also confirms it by LED. The MTM won't trig
anything.
I've switched cables, changed outputs etc. And I have two other MTMs
hooked to the same midipatch and these suxxers work and trig as they should.
If I rewire the test setup, it works again. All the MTM settings are
identical in the MTMs, except for the midi note triggers. But I've moved
these around too just to test... The MTM is running OS 4 and has the
highest serial (800) of my three units.
What am I missing?! *cry of desperation*
electronically yours, jesper
www.electronic-obsession.se
Angaudlinn on iTunes:
https://itunes.apple.com/us/artist/angaudlinn/id582356650
Angaudlinn's playlist på Spotify:
http://open.spotify.com/user/simplyanalogue/playlist/540Srd3zA15pK7G1S8qLHo
Angaudlinn on facebook:
https://www.facebook.com/Angaudlinn
anything.
