portkit schematics 2014-12-23 by alfpaches@... Hi guys!Someone here has the Portakit schematics?. Mine is broken and it would be great help in order to try to repair it. The FRS works fine so it seems the problem is in the PCB.Thanks in advance.
Re: portkit schematics 2014-12-26 by philmurr@... What is the problem with it?The Portakit isn't very complicated so if you can give me an idea of the fault I (or someone else on the list) might be able to help.
Re: [Simmons Drums] Re: portkit schematics 2014-12-26 by ALFONSO PACHES Thanks Phil.Don´t worry, the problem has been resoved. :) El Viernes 26 de diciembre de 2014 18:37, "philmurr@... [Simmons_Drums]" <Simmons_Drums@yahoogroups.com> escribió: What is the problem with it?The Portakit isn't very complicated so if you can give me an idea of the fault I (or someone else on the list) might be able to help.
Re: [Simmons Drums] Re: portkit schematics 2015-02-03 by music@... Hi group!Anyone know why a Portakit's sequencer would just start by itself for no apparent reason?CheersT14
