SDS6 issue
2014-10-29 by Jim Barber
I have an SDS6 that has an issue with the scan on the matrix. Everything works. The Led’s lite with the pattern but when you play one the unit doesn’t scan. I assume it is an internal clock because if I inject an external clock it works. I assume there is a chip that needs replacing. Wondered if anyone could point me in the right direction. Maybe the 311 chip after the tempo pot circuit?
