Index last updated: 2026-03-31 13:50 UTC
SDS3 pads connector
SDS3 pads connector
2014-07-12 by alfpaches@...
Hi group!
Anyone know what type of DIN connector is valid to connect the SDS3 pads to the module?. I tried with a MIDI cable but only a couple of pads work in this way. Perhaps the pad piezzos are failing or maybe I need to connect the MIDI pins in a different way?.
Thanks in advance!
Re : [Simmons Drums] SDS3 pads connector
2014-07-12 by Jacquot.Patrice@...
Have you tried a simple DIN cable (old HIFI stuff) ?
----- Mail d'origine -----
De: alfpaches@... [Simmons_Drums] <Simmons_Drums@yahoogroups.com>
À: Simmons Drums <Simmons_Drums@yahoogroups.com>
Envoyé: Sat, 12 Jul 2014 14:49:01 +0200 (CEST)
Objet: [Simmons Drums] SDS3 pads connector
Higroup!
Anyone knowwhat type ofDINconnector isvalidto connect the SDS3 pads to the module?.I tried witha MIDI cablebut only a coupleofpadswork in this way.Perhapsthe pad piezzos are failingor maybe I needto connect theMIDI pins in a different way?.
Thanks in advance!
Re: SDS3 pads connector
2014-07-13 by Scott Gibbons
Did you check continuity on all of your cable's pins? MIDI only uses 3 of the 5 pins. Some MIDI cables have all 5 pins wired through but most only have 3, the other 2 are left unconnected. DIN-SYNC cables should work fine; those use all 5 pins.
all my best,
- Scott
Re: [Simmons Drums] SDS3 pads connector
2014-07-13 by Michael Buchner
Hello Alphonso,
the DIN is wired like this: the MIDDLE pin (labelled "2" on the connector) is ground, the other four are the pad inputs. This is different to MIDI, because MIDI uses only 3 pins.
Best
Michael
Sent: Saturday, July 12, 2014 2:49 PM
Subject: [Simmons Drums] SDS3 pads connector
Hi group!
Thanks in advance!
2014-07-16 by alfpaches@...
Thanks for the information Scott!.
I´ve spoken with Micha and he´ll make a connector to me. :)
