Simmons SDS 6 gate question
2013-10-05 by Nick Zampiello
Index last updated: 2026-03-31 23:16 UTC
2013-10-14 by vout@...
--- In Simmons_Drums@yahoogroups.com, Nick Zampiello <newallianceeast@...> wrote:
> hello! so i am trying to get a simmons sds 6 to chase a clock pulse and i can't get it to play...
> i see that it expects 15 volts. this is a lot...
> but i am trying to lock it to a garfield electronics mini doc. i figured this would do it.
> thanks!
> z
> NEW ALLIANCE EAST!!!!
> New Alliance East - Mastering
> New Alliance East - Facebook
> X :::: B :::: S
2013-10-14 by Nick Zampiello
> thanks!
> z
> X :::: B :::: S
2013-10-18 by Michael Buchner
----- Original Message -----From: Nick ZampielloSent: Tuesday, October 15, 2013 12:22 AMSubject: Re: [Simmons Drums] Re: Simmons SDS 6 gate question
awesome thanks for the info. i was able to get it to sync if i ran the sequencer clock from the Garfield DR Click into the preamp of the 2600 for a little added gain before the SDS 6 input.I was looking at the scheme and it wouldn't be simple to change the input of the SDS 6 so i might make a little box that just cranks the voltage / current a little before it. than it could be slaved to anything really.zNEW ALLIANCE EAST!!!!
X :::: B :::: S
On Monday, October 14, 2013 6:17 PM, "vout@..." <vout@...> wrote:Hi,
I was able to sync the SDS6 to a TR606 (tom) trigger output, it seems to have enough juice to drive the SDS6 even though the voltages are theoretically wrong. The SDS6 sync inputs (tape and trigger) are very fussy, I think they need a bit of current drive rather than just a certain voltage level. Always reminded me of 80's computers with cassette loading where you spent ages trying to get the level just right.
My sync chain was DAW midi out -> x0xb0x midi in, x0xb0x din sync out -> TR606 sync24 in, TR606 tom trigger out -> SDS6 trigger in.
This generally worked quite well and even allowed me to apply swing to the SDS6 using the x0xb0x swing function.
Cheers, vout
> thanks!
> z
> X :::: B :::: S
2013-10-18 by Nick Zampiello
----- Original Message -----From: Nick ZampielloSent: Tuesday, October 15, 2013 12:22 AMSubject: Re: [Simmons Drums] Re: Simmons SDS 6 gate questionawesome thanks for the info. i was able to get it to sync if i ran the sequencer clock from the Garfield DR Click into the preamp of the 2600 for a little added gain before the SDS 6 input.I was looking at the scheme and it wouldn't be simple to change the input of the SDS 6 so i might make a little box that just cranks the voltage / current a little before it. than it could be slaved to anything really.zNEW ALLIANCE EAST!!!!
X :::: B :::: S
Cheers, vout
> thanks!
> z
> X :::: B :::: S
2013-10-20 by Nick Zampiello
On Friday, October 18, 2013 11:13 AM, Nick Zampiello <newallianceeast@...> wrote:
ok cool, i was unclear as to what changing these would do. thanks!
z
X :::: B :::: S
On Friday, October 18, 2013 11:03 AM, Michael Buchner <buchnerelectronics@...> wrote:
Check R 21 and R 20 on the expansion board, the
level is set there. To rise R 20 value to 1M or simply cut it away should do the
trick.
>To: Simmons_Drums@yahoogroups.com
>z
>X :::: B :::: S
>Hi,
trigger in.
>Cheers, vout
>--- In
is a lot...
>> thanks!
>> z
>> NEW ALLIANCE
EAST!!!!
>> X :::: B :::: S
2013-10-21 by Michael Buchner
----- Original Message -----From: Nick ZampielloSent: Sunday, October 20, 2013 7:52 PMSubject: Re: [Simmons Drums] Re: Simmons SDS 6 gate questionso i looked inside the sds 6 and there's a lot of modification going on...
i attached a picture of that section of board. and the scheme.
there's no R20 and R21 is routed to C14. but i don't see C14 on my scheme.
maybe it's the one behind IC6?
thanks in advance
z
X :::: B :::: S
z
X :::: B :::: S
trick.
>z
>X :::: B :::: S
>Hi,
trigger in.
>Cheers, vout
>--- In
is a lot...
>> thanks!
>> z
>> NEW ALLIANCE
EAST!!!!
>> X :::: B :::: S
2013-10-21 by Nick Zampiello
thanks in advance
z
X :::: B :::: S
z
X :::: B :::: S
trick.
>z
>X :::: B :::: S
>Hi,
trigger in.
>Cheers, vout
>--- In
is a lot...
>> thanks!
>> z
>> NEW ALLIANCE
EAST!!!!
>> X :::: B :::: S
2013-10-22 by jesper
> no midi, i wish!
> did you see thew attached pics?
> thanks,.
> z
2013-10-22 by Michael Buchner
----- Original Message -----From: Nick ZampielloSent: Monday, October 21, 2013 6:03 PMSubject: Re: [Simmons Drums] Re: Simmons SDS 6 gate question
no midi, i wish!did you see thew attached pics?thanks,.zNEW ALLIANCE EAST!!!!
X :::: B :::: S
On Monday, October 21, 2013 10:10 AM, Michael Buchner <buchnerelectronics@...> wrote:Do you have the midi or non-midi version? The expansion boards are totally different. Check pin 2 of IC 6 and follow the track: R20 is located between Gate in and out jacks. R21 is near IC 6. One of the SDS6 here has R20 cut off and R21 lowered to 5K6.Works with any trigger.BestMichael----- Original Message -----From: Nick ZampielloSent: Sunday, October 20, 2013 7:52 PMSubject: Re: [Simmons Drums] Re: Simmons SDS 6 gate questionso i looked inside the sds 6 and there's a lot of modification going on...
thanks in advance
z
X :::: B :::: S
z
X :::: B :::: S
trick.
>z
>X :::: B :::: S
>Hi,
trigger in.
>Cheers, vout
>--- In
is a lot...
>> thanks!
>> z
>> NEW ALLIANCE
EAST!!!!
>> X :::: B :::: S
2013-10-22 by Nick Zampiello
----- Original Message -----From: Nick ZampielloSent: Monday, October 21, 2013 6:03 PMSubject: Re: [Simmons Drums] Re: Simmons SDS 6 gate questionno midi, i wish!did you see thew attached pics?thanks,.zNEW ALLIANCE EAST!!!!
X :::: B :::: S
thanks in advance
z
X :::: B :::: S
z
X :::: B :::: S
trick.
>z
>X :::: B :::: S
>Hi,
trigger in.
>Cheers, vout
>--- In
is a lot...
>> thanks!
>> z
>> NEW ALLIANCE
EAST!!!!
>> X :::: B :::: S
