Visu-lite Cymbals?
2013-05-27 by simmonssds7fan
Index last updated: 2026-03-30 17:31 UTC
2013-05-31 by simmonssds7fan
2013-06-01 by jesper
> Anybody? Anyone? Opinions please.....Most of us are into old gear... so no, sorry... :-/
2013-06-01 by superwolle70
--- In Simmons_Drums@yahoogroups.com, jesper <jesper@...> wrote:
> simmonssds7fan skrev 2013-05-31 23:27:
> electronically yours, jesper
> www.electronic-obsession.se
2013-06-01 by Mark Frost
--- In Simmons_Drums@yahoogroups.com, "simmonssds7fan" <ptmetcalf@...> wrote:
> Does anyone have any experience using Pintech's Visulite cymbal triggers with their vintage SDS-7 units? Are they compatible? Original Simmons cymbal triggers are rare as hens teeth as we all know. I was wondering if they will work PROPERLY (you know, electronically correct?)with an SDS-7 before outlaying the cash for them as they are on the expensive side.
2013-06-01 by simmonssds7fan
--- In Simmons_Drums@yahoogroups.com, "superwolle70" <superwolle70@...> wrote:
> I saw Jay Rajeck of TRS-80 in a video using Visulites with a Simmons kit http://www.youtube.com/watch?v=Vy8ui56C7PU
> contact him. He doesn't bite :-)
--- In Simmons_Drums@yahoogroups.com, "Mark Frost" <airflamesred@...> wrote:
> I would be surprised if they worked that well only because I don't think there would be enough adjustment in the '7' especially beyond a single zone. They look good, are solid, though noisy but this would be an expensive experiment. You might want to try with a Kittoy or something from ebay just to get an overview.
2013-06-01 by Mark
--- In Simmons_Drums@yahoogroups.com, Mark <airflamesred@...> wrote:
> If it is too hot then it can be cooled, Personally, i would be cautious
> for that sort of outlay.
2013-06-01 by Mark
On Jun 1, 2013 8:53 PM, "simmonssds7fan" <ptmetcalf@...> wrote:
2013-06-01 by Jacquot.Patrice@...
2013-06-02 by Michael Buchner
To: Simmons_Drums@yahoogroups.com
Sent: Saturday, June 01, 2013 8:37 PM
Subject: [Simmons Drums] Re: Visu-lite Cymbals?
How would one "cool" the output signal if it is too "hot"? I'm assuming it would be best if I contact Pintech and ask questions then before attempting this.....
2013-06-02 by jesper
> Note: If your SDSV kickpad isIs it only me or isn't "krnnch" a far cooler sound than "click"? ;)
> producing "krnnch, krnnch" istead of "click, click", try this out.
> Happy weekend, hexheads!
Sent: Sunday, June 02, 2013 4:24 PM
Subject: Re: [Simmons Drums] Re: Visu-lite Cymbals?
Michael Buchner skrev 2013-06-02 15:53:
(Tweaking Quad 478 och SDS-III while the kids are playing outside in the
rain. The best with the swedish summer...)
> It is only you. And it is only you who likes to playback printer OS:D
> Eproms in his SDS7.
> That's what makes you so unique! :-)
> And all others like boring "click" instead of "krnnch".*humming along to "trigger track" by Boytronic* :)
> But there has to be a mass! :-)
Sent: Sunday, June 02, 2013 5:33 PM
Michael Buchner skrev 2013-06-02 17:18:
> Eproms in his SDS7.
:D
(But I only run printer proms in the SDS-1's. The 7 has the custom
Ultravox set.)
2013-06-02 by Mark Frost
--- In Simmons_Drums@yahoogroups.com, "Michael Buchner" <buchnerelectronics@...> wrote:
> To "cool" the output of a pad is the best expression I ever heared, really. This is done normally by a resistor in parallel of the piezo. For SDSV and SDS7 add 1k, this is a good value. Or do it with a pot for testing first.
> Many of the pad users think, if the pad has a too high output, one can lower the sensitivity pot on the brain and that's it. But this is only half of the truth. If you play an SDSV or an SDS7 for example with a "too hot" pad and lowered sens, you quickly realise, that the dynamic range is poor. Or, better description: your playing style from soft to hard will not be expressed in the right way.
> This happens, if you try to play one of the old Simmons brains (not SDS9 or SDS1000) with new pads like Roland and Yamaha. With the visulites I have no experience, but I think, it is the same.
> Vice versa, the SDSV and 7 pads (with the internal resistor) are too weak for a modern brain. So, if you want to have the sexy look of a hex on stage, you have to cut the resistor out. It is fitted on the back of the pads XLR.
> Now, I hear the question: One day I need the pad for SDSV, the next day for a Roland. You can cut the resistor out and solder it into the SDSV brain. Or you solder it into a cable used only for the SDSV.
> Note: To calm the output down, Dynacord used a 22nF capacitor in parallel of the piezo. This was cool, too. If your SDSV kickpad is producing "krnnch, krnnch" istead of "click, click", try this out.
> Michael
> From: simmonssds7fan
2013-06-02 by WT
To: <Simmons_Drums@yahoogroups.com>
>> Eproms in his SDS7.
> :D
> Ultravox set.)
2013-06-02 by WT
Sent: Sunday, June 02, 2013 7:00 PM
> Have you made any copies to the U-vox eproms ?
> WT
> From: "jesper" <jesper@...>
>>> Eproms in his SDS7.
>> :D
>> Ultravox set.)
>> Yahoo! Groups Links
2013-06-02 by simmonssds7fan
> Michael
> Pooh, for 1 second I thought, you would ban me from the list for the*haha* I might be mr moderator, but I do have humour... I think. :)
> last post :-)
> Have you made any copies to the U-vox eproms ?Nope, no way of copying them either. And... since they're 90's Ultravox
> Ok, that sounds like something I could easily add to the cables for the cymbal triggers.[Non-text portions of this message have been removed]
> However, it also sounds like my SDS-9 pads are "too hot" as-is for my SDS-7.....is this correct as well? I do not recall a resistor wired to the 1/4" phono jacks on these. (I'm currently using commonly available 1/4" phono to XLR conversion cables to be able to use the pads with the SDS-7. No "crunch-crunch" noises and they seem to be ok, but....)
> > Michael
2013-06-03 by simmonssds7fan
--- In Simmons_Drums@yahoogroups.com, Michael Buchner <buchnerelectronics@...> wrote:
> Try a 1k, solder it into the jack between tip and sleeve. I also use SDS9 pads, but I soldered the 1k into the brain.
> Von meinem iPhone gesendet
> Am 02.06.2013 um 19:16 schrieb "simmonssds7fan" <ptmetcalf@...>:
> > --- In Simmons_Drums@yahoogroups.com, "Michael Buchner" <buchnerelectronics@> wrote:
> > > Michael
2013-06-03 by Michael Buchner
Sent: Monday, June 03, 2013 3:56 PM
Solder the resistor between the tip and sleeve connections? Wouldn't that cause a dead short? Can you clarify this and correct me if I'm wrong?
> > > Michael
> If you take a resistor with 0 Ohms, yes, indeed, that would be a shortcut. But I was recommending 1k meaning 1000 Ohms. :-)
> --- In Simmons_Drums@yahoogroups.com, Michael Buchner <buchnerelectronics@> wrote:
> > Am 02.06.2013 um 19:16 schrieb "simmonssds7fan" <ptmetcalf@>:
> > > > Michael
> > > > Michael
Sent: Monday, June 03, 2013 6:09 PM
Ok, I'm following you now.
So not only would this work with my SDS9 pads, but also the Pintech pads, correct?
> > > > Michael
2013-06-04 by Nick Zampiello
> > > > Michael
2013-06-04 by Phil a
On Tue, Jun 4, 2013 at 5:25 AM, Nick Zampiello <newallianceeast@...>wrote:
> Is there a chart that shows the volt / impedance differences between the
> different Simmons SDS pads?
> z
> NEW ALLIANCE EAST!!!!
> New Alliance East - Mastering
> New Alliance East - Facebook
> X :::: B :::: S
> From: simmonssds7fan <ptmetcalf@...>
> Sent: Monday, June 3, 2013 11:58 AM
> correct?
> for testing first.
> pads XLR.
> > > > > Michael
> cautious
2013-06-04 by Michael Buchner
Sent: Monday, June 03, 2013 5:58 PM
> > > > Michael
2013-06-08 by simmonssds7fan
> Yes.
> > > > > Michael
