Archive for Simmons_Drums.
Index last updated: 2026-03-30 01:08 UTC
Need some help, folks....
2013-04-30 by Tony Henderson
Hi everyone....I've recently come into ownership of an SDS7 kit. It's a basic 5 - drum pad model ( kick, snare, three toms ) and it also has a kit  selector pad. I've now discovered that there's a problem with the " brain" in that the whole right - hand, programming and selector part of the module has an intermittent power fault and the LED display with the rotary selecter switch doesn't light up at all. I'm no electronics guru so I've no idea where to start. Is there anyone who does an accredited repair service for a Simmons of this vintage in the UK ? Am I even wasting my time trying to GET it repaired ?? Any pointers gratefully recieved....
Thanks, Tony
Re: [Simmons Drums] Need some help, folks....
2013-04-30 by jesper
Tony Henderson skrev 2013-04-30 15:37:
> recieved....
> Thanks, Tony
It certainly deserves getting fixed. And if you decide it's not worth it
I bet there are a few in here ready to take on the challenge. Check with
James at Synth Repair to at least get a quote. He's a good guy with good
reputation.
http://www.synthrepairservices.com/
If it gets too expensive, you might sell it off in parts. Heretic - yes,
but just don't throw it out!
But there might even be help had here... Let's wait and see. Znd once
again, welcome! :)
electronically yours, jesper
www.electronic-obsession.se
2013-04-30 by Nick Zampiello
also, these are old enough ( and the caps they used were cheap enough ) that they are completely out of spec.
early digital hates this enough to completely break down when it is the case.
a recap and new battery may be all of the issue.
z
NEW ALLIANCE EAST!!!!
New Alliance East - Mastering
New Alliance East - Facebook
X :::: B :::: S
To: Simmons_Drums@yahoogroups.com
Sent: Tuesday, April 30, 2013 9:51 AM
Subject: Re: [Simmons Drums] Need some help, folks....
> recieved....
> Thanks, Tony
reputation.
again, welcome! :)
2013-04-30 by Chris Cronin
Hi Tony,
I had my SDS7 repaired here a few years ago:
http://adcdrums.co.uk/Contact.aspx
Chris
To: "Simmons_Drums@yahoogroups.com" <Simmons_Drums@yahoogroups.com>
Sent: Tuesday, 30 April 2013, 14:37
Subject: [Simmons Drums] Need some help, folks....
Thanks, Tony
2013-04-30 by Mark Frost
Or Colin at Koby drums. I think he was doing repairs at ADC.
--- In Simmons_Drums@yahoogroups.com, Chris Cronin <gushi1@...> wrote:
> Hi Tony,
> Chris
> From: Tony Henderson <tonyhenderson@...>
> Thanks, Tony
2013-05-01 by Michael Buchner
You can do a test on your own without being an experienced tech. Unscrew the front and take all modules out, check, if the small centering pins are still in the edge connector of the backplane and not accidentally stuck in the slot of the modules.
Now unscrew the 4 screws of the panel with the rotary encoder. You find 2 PCBs behind it: The RAM/ROM to the right and then the CPU. Pull both out.
Also check, if the centering pins of these are still in place. Clean the gold plated fingers of the cards.
Insert the RAM and move it back and forth in the connector. If there is some stain or oxide inside, the chance to get rid of it with that way is big. Same with the CPU. When you think, it is enough, check, that the two cards are in the exact position in the connector (with a torch) and power up. If some segments on the display are lit know, start again. The right startup display must be "01"
Check also the RAM battery. If it has something green outside, replace it.
Good luck
Michael
Sent: Tuesday, April 30, 2013 3:37 PM
Thanks, Tony
2013-05-01 by Tony Henderson
This is great ! Thanks very much.... I'll get the screwdriver out now !!
Cheers,
Tony
> Good luck
> Michael
> Thanks, Tony
Just want to say a huge thanks to everyone who came back with replies to my request for help.... not only the fastest but the best response to any forum I've ever been on ! Always trust a drummer .....! I'll let you know how I get on, and thanks again !
Cheers,
Tony Henderson
> > recieved....
> > Thanks, Tony
> reputation.
> again, welcome! :)
2013-05-01 by jesper
Tony Henderson skrev 2013-05-01 11:05:
> Cheers,
> Tony
Yes, the best thing is always to check yourself first. But from the
original Q you sounded like a guy not daring to peek inside. :)
Also, this groups sure is great. Many skilled techs, many with knowledge
and histories from the business. Also friendly and fun 99% of the time.
We hope you get the SDS-7 sorted and that you stick around!
Re: Need some help, folks....
2013-05-01 by gordonjcp
--- In Simmons_Drums@yahoogroups.com, Tony Henderson <tonyhenderson@...> wrote:
Very carefully clean the edge connectors and check that the keys that line up with the keyway in the edge of the board is correctly fitted.
Remove the battery, and check *very very carefully* that it hasn't piddled electrolyte all over the board. This is extremely difficult to fix. Search for similar battery problems with Korg Polysixes if you want to know the full horror.
Check the power supply outputs carefully. IIRC they are +/-15V DC and +5V DC. As long as the 15V rails are reasonably close and +5V is within about +/- 0.2V it should be good. Check the PSU ripple under load.
DO NOT "RE-CAP" IT. You'll only give yourself even more faults. "Re-capping" equipment pretty much only ever makes things worse. Electrolytic capacitors just don't fail in equipment like this - about the only place you'll find genuinely faulty electrolytics is in very old (1930s-ish) equipment, and modern cheap crappy switched-mode power supplies. In something like 20-odd years of repairing electronic equipment I've found about a dozen electrolytics that were genuinely faulty, and only one of those in a synth - my own Polysix ;-)
Now, disc ceramic capacitors, they're another story altogether...
Gordonjcp MM0YEQ
Re: [Simmons Drums] Re: Need some help, folks....
2013-05-01 by chris@chriswareham.net
You've clearly never had the "pleasure" of dealing with an ARP Omni then. The
tantalum capacitors in those tend to have failed long ago, although that's only
the tip of the iceberg when it comes to the Omni - the power supply has a design
flaw that causes components to die, and the sliders fall to bits :-/
Chris
2013-05-01 by Gordon JC Pearce
Ah, tantalums give up their magic smoke noisy and messily though, so
they're a dead giveaway ;-)
Gordonjcp MM0YEQ
