Simmons brains and cheating!
2013-03-01 by harvey bendover
Archive for Simmons_Drums.
Index last updated: 2026-03-30 01:08 UTC
2013-03-01 by superwolle70
--- In Simmons_Drums@yahoogroups.com, harvey bendover <cadiumcar@...> wrote:
> I am sure this has been covered before but since I am new I have a question
> regarding cheating with Simmons' brains ...
> On my small, inexpensive Roland TD3 drum module, I can take a Y-cable, plug
> TWO different pads into it, plug into one jack and have the same sound come
> out of both pads ... two pads working while using one trigger ... has
> anyone ever tried this with a Simmons brain and does it work?
> Thanks
On Fri, Mar 1, 2013 at 10:02 AM, superwolle70 <superwolle70@...> wrote:
> What "Simmons brains" are you talking about? Hopefully the vintage 80s
> ones... With those it cannot work because the inputs are all mono (except
> the snare input of the SDS9)
> question
> plug
> come
> > Thanks
2013-03-02 by jesper
> (except the snare input of the SDS9)
> question
> Y-cable, plug
> sound come
> > Thanks
2013-03-02 by harvey bendover
On Sat, Mar 2, 2013 at 8:42 AM, jesper <jesper@...>wrote:
> I think he only talks about a splitter, not a stereo cable (i e insert),
> so yes, it works. You just send the trigger from different sources. The
> pads are not powered and therefor there are no "active" components in them.
> If two identical trigger signals arrive at the brain at the same time it
> just ends up as one. If you however trigger with synthesizers etc you
> can accidentally double the trigger level and damage the input (at least
> in theory).
> Side note: I have modified my Star Synare 1 with external triggers for
> all the "pad areas" (12 in total). Since it's _one_ monophonic synth
> behind all sound generation a double trigger combines the voltages of
> the areas and the result is an even higher pitch than the two intended.
> Having tuned them over an octave a C and a G# can result in something
> odd like a very flat E2b. Weird and cool!
> electronically yours, jesper
> www.electronic-obsession.se
> Basic superwolle70 skrev 2013-03-01 16:02:
> > question
> > Y-cable, plug
> > sound come
> > > Thanks
2013-03-02 by Scott Gibbons
