Simmons SDS 6 in the wild?
2013-01-29 by Nick
Archive for Simmons_Drums.
Index last updated: 2026-03-30 01:08 UTC
2013-01-29 by Nick
2013-01-31 by Ed
--- In Simmons_Drums@yahoogroups.com, "Nick" wrote:
> Anyone using one of these Or have extensive experience with one?
> how is it?
> always wanted one...
> z
2013-02-01 by Richard
> how is it?
> z
2013-02-01 by vout@...
--- In Simmons_Drums@yahoogroups.com, "Richard" wrote:
> I have one of the ultra rare factory midi units. Great machine to use and looks a treat when running. The midi implementation is really rudimentary, just midi clock and start/stop functions but allows it to work with other sequencers. When I get time I hope to work up a small PCB that can be fitted to existing units to update them to midi. The main cpu is simply unplugged, the new pcb is fitted into the existing cpu socket, then you plug the cpu into the addon board. The new pcb will contain the required components for midi. Also the existing eprom will need to be replaced with one I will copy from my unit. this has all the added midi code required to run it all.
> > how is it?
> > z
2013-02-12 by marnnieto
--- In Simmons_Drums@yahoogroups.com, vout@... wrote:
> I love my SDS6. I think it has a few appealing characteristics - firstly it just looks great! second, they are pretty rare - I think less than 300 were made, but it could be a lot less, there are certainly not many still alive today so they have a certain cachet. Thirdly, unlike any other drum/trigger sequencer or midi to trigger interface I can think of, it is specifically designed to interface with Simmons gear, so the trigger voltages are much higher than the usual 5v. Also, the dynamic programming is a great feature, especially when driving an SDS7.
> Biggest downside for me is the lack of any swing function, though this can be implemented with the right sync source (I've used a x0xb0x with modified OS with swing function, driving a TR-606 through DIN Sync and in turn triggering the SDS6 from one of the tom triggers set to trigger every 1/16th note, it works well as long as you reset the SDS6 everytime you stop/start)
> Richard, I would love to see the midi addon board developed, Good luck with that, I hope you can spare the time.
> > > how is it?
> > > z
2013-02-15 by Richard
--- In Simmons_Drums@yahoogroups.com, "marnnieto" <marnnieto@...> wrote:
> Is there any way to get pictures of the midi circuit and a copy/file of the SDS6 Midi Eprom please? (3rd Attempt)
> Thanks
> > > > how is it?
> > > > z
2013-02-15 by Nick Zampiello
> Thanks
> > > > how is it?
> > > > z
2013-02-15 by marnnieto
--- In Simmons_Drums@yahoogroups.com, "Richard" <warlandr63@...> wrote:
> As I said in my earlier post, WHEN I get some time I will put together a series of files etc that should enable others to "midify" there SDS6's. It isn't a 5 min job as the midi section is mounted on the output board (which is different from the non midi units)and will require reverse engineering if it is to be available as an "addon" for exiting units. Be patient and I hope sometime soon I can find the time to do this.
> > Thanks
> > > > > how is it?
> > > > > z
