Index last updated: 2026-03-31 13:50 UTC
Simmons SDS1 issues...crazy arcade noises!
2012-09-14 by philbanksdj
Hi everyone, hopefully someone can help me.
I've recently purchased 3 SDS1 drum pads...and they all seem to have the same issue.
I'm powering them off batteries, not psu at this moment in time, as I don't have a psu for them.
When I hit the pad they make mad arcade type 8 bit noises, even when the eprom isn't plugged in. and when the eprom chips are in place you can hardly hear them due to the other noise being generated.
All three units have the same problem...
does anyone have any idea what could be causing this please? I don't think its an eprom issue due to the fact the noise is generated when hitting the pad, with or without the chip in place.
Thanks in advance for your help
Phil
Re: [Simmons Drums] Simmons SDS1 issues...crazy arcade noises!
2012-09-16 by sovereigng@aol.com
Try reversing the batteries.
In a message dated 9/16/2012 3:06:03 A.M. Eastern Daylight Time,
philbanksdj@... writes:
same issue.
Phil
2012-09-16 by philbanksdj
If I reverse the batteries there will be no sound at all!...the batteries only work one way.
> same issue.
> Phil
2012-09-16 by Michael Buchner
If you reverse the batteries, you will destroy the DA converter. Somebody did this already. Sad: The Ferranti DAC is no longer available. The arcade noises is the counter. Does it change if pitch or bend is altered? Does it change if you open the ZIF? Then there might be hope, because these noises also occur when the ZIF is dirty and one or more data lines are not working. Clean the ZIF by rubbing an Eprom from side to side scratching with its legs the ZIFs contacts. Good luck.
Von meinem iPhone gesendet
hi MIchael, thanks for your help.
I tried what you've said with no luck. The pitch of the crazy sounds does change and the bend also...but rubbing the eprom had no affect on the sound.
--- In Simmons_Drums@yahoogroups.com, Michael Buchner <buchnerelectronics@...> wrote:
