Index last updated: 2026-03-30 17:31 UTC
Triggering SDS-V with a Roland Tr 707
2012-04-29 by matthew
Does anyone know if triggering a SDS-V would work hooked up to a the individual outputs from a Roland Tr-707?
Regards
Matt
Re: [Simmons Drums] Triggering SDS-V with a Roland Tr 707
2012-04-29 by jesper
matthew skrev 2012-04-29 18:13:
> Hi,
It won't trigger at full effect over the 6,3 jacks, but will probably do
the trick over xlr. Watch the levels though.
electronically yours, jesper
www.electronic-obsession.se
2012-04-29 by ALFONSO PACHES
I use the YAMAHA DX5 individual outputs to trigger my SDSV and SDS7. The best way to do that is using the XLR pad inputs , so you´ll need jack- XLR cables. Anyway you should to put shorter as possible the decay of each Roland channel. Otherwise, you will get a distorted sound.
Good Luck
Alfonso
De: jesper <jesper@...>
Para: Simmons_Drums@yahoogroups.com
Enviado: Domingo 29 de abril de 2012 18:37
Asunto: Re: [Simmons Drums] Triggering SDS-V with a Roland Tr 707
> Hi,
2012-04-30 by Michael Buchner
The SDSV needs a very short spike-like trigger pulse. The shorter, the better. If the trigger signal is a tom or a cymbal, the click portion of the SDSV sound will crunch as long as the trigger sound is and after the triggersound is over, bend and decay envelopes will start.
The 707 sidestick/rim or closed HH will do the job. You need a cable jack/XLR , life/tip pin 2 of the XLR, ground/sleeve pin 1. You cannot use the sequencer inputs without a modification. Be careful with the output volume of the 707.
Best
Michael
To: Simmons_Drums@yahoogroups.com
Sent: Sunday, April 29, 2012 6:13 PM
Subject: [Simmons Drums] Triggering SDS-V with a Roland Tr 707
Regards
Matt
