Michael Buchner grew nostalgic:
> Imagine this: Once (1985?) Simmons promised a drummer to be able to
> leave his own SDS7 drumkit at home, go to a stage or studio anywhere on
> the planet, plug in the memory card and go exactly with his own personal
> sounds...
That idea was splendid!
> The first step to this must be: The right cards and eproms in the right
> slot. But: I never saw an SDS7 with the original recommended card
> sequence in my shop: bass, snare, tom1, tom2, tom3, I think Hihat was
> next and then the first crash cymbal, after that somewhere bass 2, well,
> read about that in the manual.
*haha* Yes, that's a laugh these days. I've seen the 5-card setup
mentioned though but after that it's basically anarchy out there. My
customized Ultravox machine has bass, snare, octaban, octaban, bass,
snare, octaban, octaban. I bet that's quite unique. :D
> When delivered, the units were fully
> equipped with sounds for the dedicated channels. But it made no sense,
> if you decided to put f.e. your Hihat card into slot 3, because the
> factory parameters there were thought for a high tom.
That fact makes it even more tempting to move them around if you ask a
sound junkie like me.
> Another example:
> When I first transformed one of my tom cards to a cymbal (yes, because I
> didn't have the 690 Deutsche Mark for a sixth card these days and they
> still took 120 Deutsche Mark for the cymbal Eprom only, a lot of
> money...), I was dissapointed of the awaited cymbal sounds. But then
> they told me to put the former-tom-but-now-cymbal card to the crash
> cymbal slot, and: Voila, I had 50 sense-making cymbal sounds. They were
> factory- presetted on the seventh slot (or so).
> Now it is getting more serious: Think about adjusting and tuning three
> toms in a row on your SDS7 brain, with three similiar cards and three
> similiar eproms (like "bright tom") You have the (intelligent and
> logical...) idea to program all parameters on each of your tom cards to
> the same value and vary only the individual pitches afterwards: I never
> was successful doing like that. One tom was dull, the other bright, one
> decay was longer, the other (with same value set) shorter, one tom
> clicked heavy, on the other softly. The tolerances of the electronic
> parts are definitely too big.
I see the problem from a drummers point of view but as a fan of analogue
electronics I LOVE this unpredictability.
> To get a good impression of this phenomenon, make the following
> experiment with all of your SDS7 cards by yourself: Put click, noise and
> digital noise to zero, filter freq 255, reso somewhere, decay 255.
> Analog vol to 255, analog mod to zero, analog pitch to something like
> 125. Now try to adjust the analog bend to a value where you can hear NO
> bend at all (neither up, nor down, sound has to stay at constant pitch):
> Is it 145? Then you are lucky: It is the standard zero bend value for
> analog sound source! And? On the next card? Is it 155? Oh, this means
> nothing, it is still good average. Now change the cards to other slots
> and try again: What happens?
> In my opinion, the biggest trouble is caused by the cheap resistors,
> with tolerances up to more than 10%. They brought in gold plated
> fingers, Curtis ICs and the expensive "hybrid" SMD board, but took the
> cheapest coal resistors instead of metal foil ones. I had cards for
> repair, on which it was not possible to reduce click level to zero. On
> others, decay set to zero still was much longer than usual and useful.
> So, to come to a conclusion: It is a dream to interchange sounds on
> SDS7s exactly, but not possible. Shared values might be a good start-off
> for own creations, but nothing more. But, nevertheless, I love all of my
> SDS7s.
> Michael
Great story and a splendid finale there Michael! :D
electronically yours, jesper
www.electronic-obsession.se
www.myspace.com/machinepop
"Spotify is fully legal and so should our content be too."
