SDS2000 service manual or schematics please
2008-06-03 by p_k_daniels
Index last updated: 2026-04-05 19:50 UTC
Just picked up a faulty SDS2000 (want to revisit my soldering / faultfinding skills and fill up some empty evenings) just wondering if anyone has or can point me in the direction of service guides or schematics? Apparently it all buzzes and the lights work but no sound out...keeping my mind open until I can do some experimentation myself, being a computer service engineer Ive learnt not to take other peoples explanation of the symptoms too seriously
2008-06-10 by p_k_daniels
Ok so thought id give you all an update, couldnt find schematics anywhere, but downloaded the user manual from simmons museum (thanks wolfgang!) unwrapped it, powered it up, wired in some computer speakers to the headphone socket...as described lights on no sound, did a factory reset as per the manual still no sound, took the top off and s**t myself was expecting it to be all transistors and bits due to the age (TTL was what i thought it would be) instead im faced with a veritable chip shop, at least 5 of which have the simmons logo on them and not a lot else...however even a blind monkey could have found this one one of the 2 big 23v capacitors had a blown can bottom, changed it out and bingo everything works. so SDS2000 no000397 is resurected, polished and has been added to the setup...total cost �50 inc delivery, capacitor free from a box of bits and RS �1.95 for some slider knobs. now questions for all you list gods/demigods/demons or plebs like me...does anyone have any idea what sort of card goes in the soundcard slot? does anyone, know anyone, who has a friend, who may know where to get and how to program the said card, to gain access to the other available sounds for this beasty? no thought not;-)
2008-06-10 by jesper
p_k_daniels skrev: > > > Ok so thought id give you all an update, couldnt find schematics > anywhere, but downloaded the user manual from simmons museum (thanks > wolfgang!) unwrapped it, powered it up, wired in some computer > speakers to the headphone socket...as described lights on no sound, > did a factory reset as per the manual still no sound, took the top > off and s**t myself was expecting it to be all transistors and bits > due to the age (TTL was what i thought it would be) instead im faced > with a veritable chip shop, at least 5 of which have the simmons > logo on them and not a lot else...however even a blind monkey could > have found this one one of the 2 big 23v capacitors had a blown can > bottom, changed it out and bingo everything works. so SDS2000 > no000397 is resurected, polished and has been added to the > setup...total cost £50 inc delivery, capacitor free from a box of > bits and RS £1.95 for some slider knobs. Congratulations! But... the SDS-2000 is a late machine on the Simmons timeline and you need to go into the early 70's to loose most IC's in synthesisers... -- electronically yours, jesper - -- --- ---- ----- ---- --- -- - www.electronic-obsession.se www.myspace.com/machinepop - -- --- ---- ----- ---- --- -- -
2008-06-10 by Patrice Jacquot
Hi & Bravo for the resurrection... I love very much the SDS2000. nothing to see with the other Simmons probably the most cold one in term of sound ...But there's something very nice in it !!! I have 5 sound cards & they're not all working ... the ones that are working don't bring anything interesting , just the same sounds all the time... I had them probably from a maintenance service... I don't know much more about them ... The fact is that I would like to find some other sounds &eventually reprogram & reuse the ones that are faulty ... But I have no Idea yet how to do that ... Maybe one day ... I doubt it helps but anyway it's always good to talk abou this (quite forgotten) unit... good luck, Patrice. Le 10 juin 08 à 17:11, p_k_daniels a écrit : > Ok so thought id give you all an update, couldnt find schematics > anywhere, but downloaded the user manual from simmons museum (thanks > wolfgang!) unwrapped it, powered it up, wired in some computer > speakers to the headphone socket...as described lights on no sound, > did a factory reset as per the manual still no sound, took the top > off and s**t myself was expecting it to be all transistors and bits > due to the age (TTL was what i thought it would be) instead im faced > with a veritable chip shop, at least 5 of which have the simmons > logo on them and not a lot else...however even a blind monkey could > have found this one one of the 2 big 23v capacitors had a blown can > bottom, changed it out and bingo everything works. so SDS2000 > no000397 is resurected, polished and has been added to the > setup...total cost £50 inc delivery, capacitor free from a box of > bits and RS £1.95 for some slider knobs. > > now questions for all you list gods/demigods/demons or plebs like > me...does anyone have any idea what sort of card goes in the > soundcard slot? does anyone, know anyone, who has a friend, who may > know where to get and how to program the said card, to gain access > to the other available sounds for this beasty? > > no thought not;-) > > > [Non-text portions of this message have been removed]
