SDS8 pads question
2008-02-14 by stixman2364
Index last updated: 2026-04-28 23:14 UTC
Hello all, Can the SDS8 pads be taken apart (like the sds9) and repaired? Cheers, Steve
2008-02-15 by Matt
Hi Steve, Yeah, they can be taken apart but with care like any of the other pads. You'll notice that if you lift up the rubber rim the shell is stapled in to the plywood, it's just a matter of carefully pulling the staples out without cracking the shell. I use a sharp pointy knife to get it started and then a broad flat screwdriver once there is enough room to slip it under. You should be able to tap the staples back into their original holes once you've done your repairs. Cheers, Matt. --- In Simmons_Drums@yahoogroups.com, "stixman2364" <stixman2364@...> wrote:
> > Hello all, > Can the SDS8 pads be taken apart (like the sds9) and repaired? > > Cheers, > Steve >
2008-02-19 by stixman2364
Hi Matt, Thank you very much. Cheers, Steve --- In Simmons_Drums@yahoogroups.com, "Matt" <sds5@...> wrote: > > Hi Steve, > > Yeah, they can be taken apart but with care like any of the other > pads. You'll notice that if you lift up the rubber rim the shell is
> stapled in to the plywood, it's just a matter of carefully pulling > the staples out without cracking the shell. > > I use a sharp pointy knife to get it started and then a broad flat > screwdriver once there is enough room to slip it under. You should > be able to tap the staples back into their original holes once > you've done your repairs. > > Cheers, > > Matt. > > > > > > --- In Simmons_Drums@yahoogroups.com, "stixman2364" > <stixman2364@> wrote: > > > > Hello all, > > Can the SDS8 pads be taken apart (like the sds9) and repaired? > > > > Cheers, > > Steve > > >
2008-02-19 by Darren Craven
Hey Guys I recently restored a set of SDS8 pads, so I'll add my findings as well. Be carefull when sliding the screwdriver under the staples, don't press on the plastic shell with the screwdriver too hard or the plastic may bruise and turn white, or worse, break. Lift the rubber sides up carefully, it can be old and a bit brittle and may crack and break. Perhaps think about replacing the 6.5mm (1/4) jack socket while the pad's apart. Given the pads are 20+ years old, all my sockets were a bit wonky. I also removed the resistor while I had the pads apart. I'm using them with a DM5 at the moment so had to do this. When using the pads with my Simmons modules, I can just add the resistor to an adaptor on my leads if I need it. Regards -- Darren
-----Original Message----- From: Simmons_Drums@yahoogroups.com on behalf of stixman2364 Sent: Tue 19/02/2008 11:19 AM To: Simmons_Drums@yahoogroups.com Subject: [Simmons Drums] Re: SDS8 pads question Hi Matt, Thank you very much. Cheers, Steve --- In Simmons_Drums@yahoogroups.com, "Matt" <sds5@...> wrote: > > Hi Steve, > > Yeah, they can be taken apart but with care like any of the other > pads. You'll notice that if you lift up the rubber rim the shell is > stapled in to the plywood, it's just a matter of carefully pulling > the staples out without cracking the shell. > > I use a sharp pointy knife to get it started and then a broad flat > screwdriver once there is enough room to slip it under. You should > be able to tap the staples back into their original holes once > you've done your repairs. > > Cheers, > > Matt. > > > > > > --- In Simmons_Drums@yahoogroups.com, "stixman2364" > <stixman2364@> wrote: > > > > Hello all, > > Can the SDS8 pads be taken apart (like the sds9) and repaired? > > > > Cheers, > > Steve > > > [Non-text portions of this message have been removed]
