Index last updated: 2026-04-03 01:20 UTC
Best monitor sistem for simmons sounds
2008-01-10 by giamesimmons
Hi all,
do someone of you have experience with simmons drum in live contests ?
I mean: what is the best monitor system to let the drummer and the
others band member hear the punch of the kick and the "feel" of the
drum ?
I was about to buy a small system with a sub 12' and a mid-hi range
speaker 10' mounted on it.
Do you think it would do the job ?..
I'm talking about medium stages, like pubs or discos, where you don't
have a sound tech at your service and you have to bring your own setup.
Giame
Re: Best monitor sistem for simmons sounds
2008-01-10 by Matt
Howdy Giame,
I do alot of gigs both big and small, obviously with your big shows
you'll have your very own monitor send which will sound massive!
For smaller shows a powered wedge/monitor is the best, I actually
have an 8 DI unit in my rack and that can double as a line mixer
which means I just plug in powered monitor and can mix my own
foldback.
I'd go for a 12" speaker at very least, you'll need something to
handle the bottom end of you kick and toms.
If I'm using a speaker like this I think it's best to put it on your
floor tom side facing at your head, you'll feel the "Thump" from
your kick drum then!
Cheers,
Matt.
--- In Simmons_Drums@yahoogroups.com, "giamesimmons"
<giamesimmons@...> wrote:
> Hi all,
contests ?
> drum ?
range
don't
setup.
> Giame
Re: [Simmons Drums] Best monitor sistem for simmons sounds
2008-01-10 by Patrice Jacquot
Hi Giame,
here start the all problem of electronic world ...
about the monitor you have to test there are no rules, except maybe
that you need  a good speaker for the bass frequencies...
I would recommend a 16' but it depends ...SWR are making very good
low end with small speakers...
Anyway you'll probably have to premix you Simmons & have different
EQs on theToms , BD & Snare ...
a SPM8 would be perfect for it & especially for the Simmons grain...
Personnaly I'm using a multiband compressor behind the
premix ...that's very important with these beasts...
& of course you'll need a very good & fast amplifier ...
Now it depends what you're asking to your system , what band... , &
if you're playing loud ...
But the minimum is to have a comfortable level as loud as your
acoustics elements...
knowing that with our fellows musicians, our bass drum is often
disappearing after 3 songs ...
Personnaly I 'm miking the bass drum too....
so anyway , you need a quite sufficient level & it requires quite
some artillery in the end..
But this is just my advice ...
Good luck ,
Patrice.
Le 10 janv. 08 à 12:16, giamesimmons a écrit :
> Hi all,
> drum ?
> setup.
> Giame
