problems with SDSV snare module .........
2006-12-09 by memtechlist
hi all, when i switched my LinnDrum on it gave away a spike in the electrics, SDSV's all modules sounded at the same time... next i started a pattern on LinnDrum and jammed along on the pads, then i noticed something was wrong. the snaredrum square waveforms had just about 60-70% of the volume but the click sounded that it should (same volume as before i started LinnDrum) also it feels like the bassdrum module have more power now, i run all modules separately out of course... this is not an new issue, i remember it happend last time i had SDSV lined up and back then i did not need to switch anything on, it just happend all by it self ;=( anyone have a clue ? i will add a wav-file into files section so you ppl can listen or maybe drag it into a soundeditor to look at this strange fenomenon... /kw
