Re: [Simmons Drums] SDS-9 Interference Problems
2005-12-08 by jesper@electronic-obsession.se
PC's are vicious and the work of the devil... or something! ;) Seriously, it's normally just trial and error that helps. Some earthing problem is my immediate thought... electronically yours, jesper - -- --- ---- ----- ---- --- -- - www.electronic-obsession.se ----- Original Message -----
From: "richdjpearson" <rpearson79@...> To: <Simmons_Drums@yahoogroups.com> Sent: Thursday, December 08, 2005 9:41 AM Subject: [Simmons Drums] SDS-9 Interference Problems > Hi, > > I have an SDS-9 connected to a PC which has a 6 channel > (soundblaster) external audio interface. > > The problem is that I am getting a constant high pitched > interference, and other noises when I move windows around on the PC > screen. There is at least 1.5 metres of separation between the PC > and the other boxes. > > The interference is identical across all channels, so in a mono mix > it is multiplied six times becoming quite noticeable. > > I have just made new cables in hope of curing the problem, but it > has not helped. I cannot see any grounding problems. > > Does anyone know how to solve this problem please. > > Thanks in advance, > > Richard. > > > > > > > > > Yahoo! Groups Links > > > > > > > >
