Index last updated: 2026-04-03 21:51 UTC
Re: [Simmons Drums] HiHat pedal for the SDX
2005-06-10 by Patrice JACQUOT
Hi SDX Owner !
a friend of mine just talked about  a custom Roland  volume pedal that works fine for the SDx even better than the original Simmons HH pedal (not difficult the Original one is a pain ! )
I kno the pedal has been transformed with a potentiometer  inside ...
He can even use it with a ADDone for the pich controller ...
There's some hope & it should work ...
But you'll have to change the threshold setting ...etc...on the HH sample window ...
bye,
Patrice.
  To: Simmons_Drums@yahoogroups.com
  Sent: Friday, June 10, 2005 10:41 PM
  Subject: [Simmons Drums] HiHat pedal for the SDX
  Hi SDX owners,
  I had the opportunity to try the Roland FD-8 HiHat Controller with my
  SDX, and: It does NOT work by default.
  But I found out (without schematics..., just try and error as I am not
  too familiar with electronics), that using a stereo jack cable, a
  short circuit between ring and sleeve means "HiHat Closing", nothing
  connected means HiHat open, with a potentiometer (modulated by the
  angle of the pedal) between tip and ring you can modulate between open
  and closed. Enough theory for the moment. I don't know yet wether I
  will slaughter the Roland pedal or build something "special" like when
  I put a bassdrum pedal in my Volkswagen Bus when the gas pedal broke
  off in southern France 15 years ago.
  I'll keep you up to date ;-)
  Yahoo! Groups Links
    a.. To visit your group on the web, go to:
    http://groups.yahoo.com/group/Simmons_Drums/
    b.. To unsubscribe from this group, send an email to:
    Simmons_Drums-unsubscribe@yahoogroups.com
    c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-06-11 by david pinnington
great news
  Sent: Friday, June 10, 2005 9:41 PM
  Hi SDX owners,
  Yahoo! Groups Links
