HiHat pedal for the SDX
2005-06-10 by superwolle70
Hi SDX owners, I had the opportunity to try the Roland FD-8 HiHat Controller with my SDX, and: It does NOT work by default. But I found out (without schematics..., just try and error as I am not too familiar with electronics), that using a stereo jack cable, a short circuit between ring and sleeve means "HiHat Closing", nothing connected means HiHat open, with a potentiometer (modulated by the angle of the pedal) between tip and ring you can modulate between open and closed. Enough theory for the moment. I don't know yet wether I will slaughter the Roland pedal or build something "special" like when I put a bassdrum pedal in my Volkswagen Bus when the gas pedal broke off in southern France 15 years ago. I'll keep you up to date ;-)
