SergeModular
Index last updated: 2026-04-28 23:13 UTC
CV to ADSR attack
CV to ADSR attack
2009-04-21 by johnrichoux
Hello all
Would someone with an ADSR on their panels confirm something for me? When I apply a CV to any of the blue inputs, it behaves as I would expect: +CV= longer delay, decay, etc, consistent with knob direction. Except on the attack portion, where +CV= shorter attack, the opposite of the knob direction.
So, I end up setting the attack knob to a maximum, then use +CV to shorten it; conversely, I set the knob to a minimum and use -CV to lengthen it.
If that really is the intent, perhaps someone could explain the advantage to me. Does it have something to do with VC-All? Even then I would expect +CV to lengthen the entire envelope (except for the delay portion).
jmr
Re: CV to ADSR attack
2009-04-21 by matthew carpenter
Hi John,
That's how mine works, as well. I remember Rex telling me that this is the way it has to be.
Matt
On Tue, Apr 21, 2009 at 10:57 AM, johnrichoux <jrichoux@...> wrote:
Hello all
jmr
2009-04-22 by Kim Hansen
same thing here -
kim
On Apr 21, 2009, at 5:14 PM, matthew carpenter wrote:
> Hi John,
> Matt
>> Hello all
>> lengthen it.
>> delay portion).
>> Thanks
>> jmr
2009-04-22 by ty hodson
Maybe the thinking behind that design was the higher the voltage the steeper the curve, rather than voltage being related to duration?
ty
_______________
http://sublevel9.net
From: SergeModular@yahoogroups.com [mailto: SergeModular@yahoogroups.com ] On Behalf Of Kim Hansen
Sent: Wednesday, April 22, 2009 1:11 PM
To: SergeModular@yahoogroups.com
Subject: Re: [SergeModular] CV to ADSR attack
same thing here -
kim
Hi John,
Matt
On Tue, Apr 21, 2009 at 10:57 AM, johnrichoux < jrichoux@... > wrote:
Hello all
jmr
2009-04-22 by Chris Muir
I don't have a Serge system anymore, but I think that this is what I
would want. Think of the "velocity" of striking a bell or plucking a
string: the attack would get more pronounced (faster) with higher
velocity, while the decay would take longer because the object was
more excited.
- C
Chris Muir
cbm@...
http://www.xfade.com
2009-04-23 by johnrichoux
Hi Matt
I appreciate the verification. If it has to be, that's OK by me. Actually, it is a marvelous little module that I am just now beginning to appreciate. The ASR makes a good companion to it - rotating values to the segments.
Thanks again
jmr
--- In SergeModular@yahoogroups.com, matthew carpenter <matfhew.carpenfer@...> wrote:
> Hi John,
> way it has to be.
> Matt
> On Tue, Apr 21, 2009 at 10:57 AM, johnrichoux <jrichoux@...>wrote:
> > Hello all
> > direction.
> > Thanks
> > jmr
2009-04-23 by matthew carpenter
You're welcome, John.
Thanks for the tip on the ASR/ADSR combination! An SQP (n stages to n segments) is a good pairing, as well.
On Wed, Apr 22, 2009 at 12:51 AM, johnrichoux <jrichoux@...> wrote:
Hi Matt
Thanks again
jmr
> Hi John,
> way it has to be.
> Matt
> > Hello all
> > direction.
> > Thanks
> > jmr
