SergeModular
Index last updated: 2026-04-28 23:13 UTC
Touch Envelope Voltage Source
2009-03-17 by Bakis Sirros
hi Group,
just uploaded a decent size sketch of the TEV panel with 8 Transient Generators.
thanks,
Bakis.
Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
Re: Touch Envelope Voltage Source
2009-03-17 by Chris Muir
> Generators.
Yahoo is reporting file not found.
Chris Muir
cbm@...
http://www.xfade.com
on the files section, in the new folder 'Touch Envelope Voltage Source'.
www. DiN. org. uk
Athens - Greece
--- On Tue, 3/17/09, Chris Muir <cbm@...> wrote:
Subject: Re: [SergeModular] Touch Envelope Voltage Source
To: SergeModular@yahoogroups.com
Date: Tuesday, March 17, 2009, 10:52 PM
> Generators.
Chris Muir
cbm@...
http://www.xfade. com
> Source'.
Right, but when I click on the .jpg inside that folder, I get:
Document Not Found
The document you requested could not be found.
Chris Muir
cbm@...
i cannot help you on that.
i see the file fine...
www. DiN. org. uk
Athens - Greece
Date: Tuesday, March 17, 2009, 11:09 PM
> Source'.
Document Not Found
Chris Muir
cbm@...
2009-03-17 by kkonkkrete
I still don't really understand the TEV. Can someone explain to me what the black sockets on the left hand side are? They are inputs, right? Does that mean you can use this as eight parallel envelope followers? I don't suppose you can use these like eight miniature DSG-style transient generators --- that would be pretty sick.
But if not, then what is the point? If you can only have one envelope at a time, why not just control a single ADSR with a TKB (ABCD outputs going to ADSR VC inputs)?
Confused ....
2009-03-17 by Carlos
Not sure this will help or confuse more but from REX last time I asked (I am going to call him soon to clarify about multiple triggering on the left side, and to see if the sequencer ont he right side can work independently of the 8 transients)
On the [TEV]:
This mates 8 of the [DTG]s with the sequencer section of the [TKB] so that the triggering of a complete cycle of each DTG can be initiated by either touching the associated key PAD
#1-8 or by the externally clocking the onboard sequencer. The use of the patch programmable RESET points and GATE outs make this very deep in the interaction of ASR generation.
This graphic shows the black jacks as the 'input' (one per
envelope) for external 'sustain' gating & recursive operations. So these will oscillate and track other signals at this input, as your SIG INs do on the DTGs (with that option) and our DSGs.
The other option in that jack location (x8) is the use of blue jacks for VC of the total time of each envelope. This can also be used as a log thru linear thru exponential shaper of the each independent envelope's response characteristic.
Stages #9-16 on the right half of the [TEV] are there to be assigned to your 'other' DSGs, DTGs, SSGs & DADSRs for triggering and presetting of their CV inputs for sequence programming of their independent segments and timing functions.
The [TEV] is there to work in conjunction with your [TKB] for true "two fisted" tactile control over your sound and control networks.
> Confused ....
2009-03-17 by Christopher Jon
Very cool. Much better than the pic I found and uploaded, thanks!
//Chris
--- In SergeModular@yahoogroups.com, Bakis Sirros <synth_freak_2000@...> wrote:
> hi Group,
> thanks,
> Bakis.
On Mar 17, 2009, at 4:51 PM, amnesia wrote:
> i get document not found???
I did too for a while, but it loads now. Probably some artifact of the
way Yahoo propagates data throughout its server farm.
- C
Chris Muir
cbm@...
