SergeModular
Index last updated: 2026-04-28 23:13 UTC
new member
new member
2003-09-23 by foleymachine
hi,
my name is greg. i just joined because i have begun using the serge
at san francisco city college and have tons of questions. one for now:
when using the tkb, is there any simpler way to sequence rests
(triggering only select steps) than to stack all of the desired step
outs into the envelope generator? triggering the envelope from the
clock source (cycling dtg) obviously gives me a note on every step.
how do other people do this? is it common just to use an external
clock source which steps the sequencer to the desired rhythm, rather
than constantly?
thanks a lot,
greg
Re: new member
2003-09-23 by Blake Wilson
Attachments :
    At 05:13 PM 9/23/03 +0000, you wrote:
    hi,
    than constantly?
    ok, try this:
    set up a nice 8 step sequence, triggering it off the DTG as you describe. you will have a steady rhythm with a note at every step. feed output D from the tkb to the CV input of the DTG and apply a little CV offset pos or neg. depending on the voltages set on line D, the DTG will either speed up or down at that step and then move onto the next one, speed up, etc. so, to set up a simple 4/4 with note-rest-note-note, set up a 3 (yes) step sequence with a touch of voltage from step 1 row D (causing DTG to hold) and none on D for 2 and 3. adjust according. you can also try this type of thing with the "hold" input on the tkb and a clock divider.
    good luck, hope this helps,
    blake, your moderator.
    y
    thanks a lot,
    greg
    Yahoo! Groups Sponsor
    ADVERTISEMENT
    SergeModular-unsubscribe@yahoogroups.com
    Keep on Patchin'!
    M. Blake Wilson, Esq.
    LAW OFFICES OF M. BLAKE WILSON
    1532 Sixth Ave.
    San Diego CA 92101
    t:619/234-2200
    f:619/234-2219
    mbwlaw@...
    http://www.blakewilsonlaw.com
    Re: new member
    ok, i think i understand;
    you just manually adjust the length of each step with row D's pots.
    i've used this to get swing and triplets before. i'm curious about
    the hold and clock divider method. there is no dedicated clock
    divider on this system, is there another module that could function
    as one?
    thanks a lot,
    greg
    describe.
    output D from
    or neg.
    up or
    so, to
    hold)
    type of
    > y
    > >thanks a lot,
    > >greg
    > >ADVERTISEMENT
    ><http://rd.yahoo.com/M=194081.3897168.5135684.1261774/D=egroupweb/S=1
    705032144:HM/A=1732161/R=0/SIG=11p5b9ris/*http://www.ediets.com/start.
    > >Keep on Patchin'!
    > ><http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
    > 1532 Sixth Ave.
    > San Diego CA 92101
    > t:619/234-2200
    > f:619/234-2219
    > mbwlaw@b...
    Re: new member
    2003-09-23 by James R. Coplin
    You can use the divide by n comparator for the same thing. You can also
    use the Boolean logic modules coupled with delayed gates (via dsg's
    etc).
    James R. Coplin
    If anyone asks of my whereabouts,
    simply tell them i've gone out the window
    for a spot of tea and am not
    expected back any time soon.
    > -----Original Message-----
    > From: foleymachine [mailto:foleymachine@...]
    > Sent: Tuesday, September 23, 2003 3:56 PM
    > To: SergeModular@yahoogroups.com
    > Subject: [SergeModular] Re: new member
    > as one?
    > thanks a lot,
    > greg
    > describe.
    > output D from
    > or neg.
    > up or
    > so, to
    > hold)
    > type of
    > > y
    > > >thanks a lot,
    > > >greg
    > > >ADVERTISEMENT
    > > >Keep on Patchin'!
    > > 1532 Sixth Ave.
    > > San Diego CA 92101
    > > t:619/234-2200
    > > f:619/234-2219
    > > mbwlaw@b...
    > Keep on Patchin'!
    Re: new member
    2003-09-23 by John Papiewski
    Hi Greg!
    Welcome.
    Could you tell us when the Serge was made (Is new? Old?).
    What modules does it have? That would help in figuring out techniques.
    John P.
    foleymachine wrote:
    > hi,
    > than constantly?
    > thanks a lot,
    > greg
    > Keep on Patchin'!
    Re: new member
    shucks, i don't think the system has these... it does have a dual
    comparator, but each comparator only has a knob for the threshold.
    --- In SergeModular@yahoogroups.com, "James R. Coplin" <moog@q...>
    also
    > etc).
    > James R. Coplin
    > > From: foleymachine [mailto:foleymachine@y...]
    pots.
    function
    > > as one?
    > > thanks a lot,
    > > greg
    > > describe.
    > > output D from
    pos
    > > or neg.
    speed
    > > up or
    etc.
    > > so, to
    step
    to
    > > hold)
    this
    > > type of
    > > > y
    > > > >thanks a lot,
    > > > >greg
    > > > >ADVERTISEMENT
    > > > >Keep on Patchin'!
    > > > 1532 Sixth Ave.
    > > > San Diego CA 92101
    > > > t:619/234-2200
    > > > f:619/234-2219
    > > > mbwlaw@b...
    > > Keep on Patchin'!
    Re: new member
    thanks! i believe it must be from sometime in the 70s. from memory:
    4 PCO
    2 NTO
    2 VCQ
    1 DTG
    1 Wave Multiplier (with 3 submodules)
    1 Quad VCA ("UPAP" or something)
    1 Ring Mod
    1 CV invertor/processor
    1 Random Voltage Generator/Noise Source
    2 VC DADSR
    1 Dual Comparator (no divide by n)
    1 6 ch mixer
    1 TKB
    thanks,
    greg
    --- In SergeModular@yahoogroups.com, John Papiewski
    <johnp299792@a...> wrote:
    > Hi Greg!
    > Welcome.
    techniques.
    > Thanks
    > John P.
    > foleymachine wrote:
    > > hi,
    serge
    now:
    step
    step.
    rather
    > > than constantly?
    > > thanks a lot,
    > > greg
    > > Keep on Patchin'!
    Re: new member
    2003-09-24 by John Papiewski
    Well OK.
    Here's one approach...
    1. Use one layer of the TKB to control volume. Set all the knobs on
    that layer to fully-on.
    2. Send that voltage to one of the VCA's in your UPAP.
    3. Send your audio signal into that VCA, then send the output into
    another VCA that your DADSR or DTG is enveloping the audio with.
    Now to 'turn off' or silence any sequencer step in your melody just turn
    off the layer you used for step 1 above. The advantage here is, in
    addtion to creating a 'rest' beat(s) wherever you want, you can also
    create accenting... daDA DADAda ... by varying the volume control
    stage pot on the TKB.
    More efficiently, this could also be done with one VCA if you can mix DC
    signals together ... You mention you have an inverter/processor.. can
    that combine control voltages? I have a Dual Processor & a CV mixer
    that do that. Anyway take the TKB volume control layer and your ADSR
    and mix them together, biasing the whole thing by -5v, and use this to
    control a VCA for your audio. You should only hear notes where the TKB
    volume control stage is fully on. This can do the 'accenting' as above.
    It's also fun to use another TKB layer (by layer I mean the A,B,C,D rows
    of 16 steps going across) to control pan position. Makes your sequence
    dance nicely!
    All the above needs only simple TKB patching... clock the clock input
    like you always do, and set the sequence length using a stage output &
    reset input, or just run 16 step sequences.
    Good luck!
    John P.
    > 4 PCO
    > 2 NTO
    > 2 VCQ
    > 1 DTG
    > 1 Ring Mod
    > 2 VC DADSR
    > 1 6 ch mixer
    > 1 TKB
    > thanks,
    > greg
    >>Hi Greg!
    >>Welcome.
    > techniques.
    >>Thanks
    >>John P.
    >>foleymachine wrote:
    >>>hi,
    > serge
    > now:
    > step
    > the
    > step.
    > rather
    >>>than constantly?
    >>>thanks a lot,
    >>>greg
    >>>Keep on Patchin'!
    > Keep on Patchin'!
    Re: new member
    2003-09-24 by foleymachine
    yes! thank you! that's the beautifully simple solution i was
    overlooking.
    greg
    > Well OK.
    on
    turn
    also
    control
    mix DC
    can
    mixer
    ADSR
    to
    TKB
    above.
    rows
    sequence
    > dance nicely!
    input
    output &
    > Good luck!
    > John P.
    memory:
    > > 4 PCO
    > > 2 NTO
    > > 2 VCQ
    > > 1 DTG
    > > 1 Ring Mod
    > > 2 VC DADSR
    > > 1 6 ch mixer
    > > 1 TKB
    > > thanks,
    > > greg
    > >>Hi Greg!
    > >>Welcome.
    > > techniques.
    > >>Thanks
    > >>John P.
    > >>foleymachine wrote:
    > >>>hi,
    > > serge
    for
    > > now:
    > > step
    > > the
    > > step.
    external
    > > rather
    > >>>than constantly?
    > >>>thanks a lot,
    > >>>greg
    > >>>Keep on Patchin'!
    > > Keep on Patchin'!
