frame/end boards
2007-05-19 by john barrick
Index last updated: 2026-03-31 23:14 UTC
2007-05-20 by Doug Berg
>wondering if
> I'm wanting to remove the end boards from the frame so I can get a
> really good polishing job done on the aluminum, and I was
> there are any issues with remounting them - or should they simplyprevention
> re-attach and that's it.
> Also, what are the specs on the resistor for magnetization
> that you need to put on the preamp lead from the headblock, and doyou
> simply solder it across the leads of the jack?Hi Again, Dealing with second question, resistor recommended is
> Thanks,
> john barrick
2007-05-20 by NormLeete@aol.com
On your headblock are 35 tape
heads. That is there are 35 coils able to store energy. Assuming
you are demagging headblock removed from machine, a good practice,
the coils can pick up a residual static charge. Think of them if
you will as capacitors. So before you plug heads into preamp, they
need to be drained. This is what the resistor does, but you can do
the same thing by shorting out the lead at headblock and the head
receptacle on preamp with same results.
