t-tech and Precise Cut on E-Bay
2004-05-07 by Dave Mucha
Hi all,
in case you are interested, there is a Precise Cut unit on E-Bay
without the driver electronics.
There is also a sample board they cut. On the upper large pad, it is
not completely round. ditto for the lower pad.
Also, some of the square pads, the trace enters the pad a little too
deeply.
Although it is not perfect, you can see it makes a very useable
board. As many of these will.
It also shows the need for the additional ring traces on pads as
since that is where you solder, you need to be careful with a small
isolation.
Maybe I'll do a similar board with my machine to show some of the
features I like to use.
Dave
deeply.
isolation.
Dave
