Homebrew_PCBs
how to use ammonium persulphate?????
2004-03-30 by mumin55555
hallo!
i just bhought 2 litre of ammonium persulphate, since im tired of
the mass ferric chloride makes. my only problem is that i have to
fill a 3 litre tank with the 2 litre i have. can i mix ammonium
persulphate with water??? and if so- how much water can i use on
each litre of ammonium persulphate so it will keep working well?
one more question- what is the shelf life of ammonium persulphate? i
read that once you heat it up and cool it down it wont work again.
is that true? and what is the optimal temperature to use ammonium
persulphate????
thanks a lot
mumin
Re: [Homebrew_PCBs] how to use ammonium persulphate?????
2004-03-30 by Rick C.
I assume your A.P. is in powder form. Use only enough powder to do 3 or
less boards under 4X6 inches. Pour water into a glass tray such as a
casserole dish to about one inch deep. Add A.P., about 3 tablespoons.
Stir until dissolved. Emmerse board and agitate often. With single sided
boards, copper side down. With double sided boards turn over every
minute. If you heat the solution it will etch faster, less than 10
minutes. Solution can be used until it turns a medium blue. Solution can
be cooled and reheated as necessary to use. It is not necessary to
bottle it or cover it if you come back in a week or so to reuse it. A
heat lamp or hot plate can be used to speed up the etching as described
on the website. I heat mine to almost a boil and I can etch a board with
fresh A.P. in less than 5 minutes.
Rick - http://www.pic101.com/pcb
mumin55555 wrote:
> hallo!
> persulphate????
> thanks a lot
> mumin
Terminals outside enclosure
2004-03-30 by ghidera2000
3 or
<snip>
Rick! The first picture on your webpage shows a PCB with green screw
terminals that (apparently) mate with the ones on the cover.
What are those called, how much are they(roughly)? Where did you get
them?
I've been trying to figure out how to allow screw connections
without leaving a gaping hole in the side of my enclosures - those
look perfect!
Merci!
Re: Terminals outside enclosure
2004-03-30 by ballendo
Hello,
I'm not Rick, but the green color is a tipoff. They're likely Phoenix
connectors, and they're available at mouser and digi-key. You can get
these kind of screw terminals a number of places, and the "other"
major mfr's. products are blue. Usually they come in .200 and .156"
inch size, and 5mm metric (pin spacing) Sold in 2 and 3 screw units,
they have "dovetails" so you can join them up as long as you need.
Some types are what's called "pluggable", which means you solder a
strip which looks just like a typical pin header, and the screw
terminal part fits onto this. That way, once you're wired up, you can
remove the connector to remove/replace the unit. Without re-wiring
everything.
Hope this helps,
Ballendo
P.S. You usually design the s/m cover to surround the screw
terminals. Some types have a "ledge" across the back to help. The
sides are easy.
--- In Homebrew_PCBs@yahoogroups.com, "ghidera2000"
do
> 3 or
> <snip>
screw
get
> them?
> look perfect!
> Merci!
Re: [Homebrew_PCBs] Re: Terminals outside enclosure
2004-03-30 by Stefan Trethan
The ones with fixed soldering pins are nearly all grey here,
the ones with the "plug on pins" are dark grey or black.
Rest is the same as described by Ballendo.
Are sold in all dimensions (for different currents with different spacing).
some have a receptacle for the 2/4mm meter probes.
Find them cheap at ebay on "sub-D to screw terminal adaptor" or similar.
often >50 screw terminals at one pcb for next to nothing, even cheaper
than
loose terminals.
ST
On Tue, 30 Mar 2004 15:56:52 -0000, ballendo <ballendo@...> wrote:
> Hello,
> everything.
> Hope this helps,
> Ballendo
2004-03-30 by David P Harris
Hi-
These are grat, but a little expensive. I have some 0.1" centred ones.
They also come in a wide variety of units: single to 12. Have a look at
the http://www.digikey.com catalog, serach for Phoenix.
David
ballendo wrote:
>Hello,
>everything.
>Hope this helps,
>Ballendo
>sides are easy.
2004-03-30 by Richard Mustakos
jtm
Another way to secure the wires (physically, not electrically) is to
hot glue them in place when your dome soldering. It's great stuff -
friendly to use, strong, and resilient enough to not just snake the
wires off.
Richard
