Heatless (cold) Toner Transfer for PCB making
2016-01-05 by leeleduc@...
Archive for Homebrew_PCBs.
2016-01-05 by MIKE DURKIN
2016-01-05 by Nuno Tavares
Certainly worth trying!
Thanks for sharing.
Nuno T.
Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: terça-feira, 5 de Janeiro de
2016 16:18
Subject: [Homebrew_PCBs] Heatless
Saw this on Instructables. Looked interesting.
http://www.instructa bles.com/id/Heatless-cold-Toner-Transfer-for-PCB-Making/?ALLSTEPS
2016-01-06 by alienrelics@...
2016-01-06 by keith printy
If you are in the united states you can get acetone at ace hardware stores or boat supply shops. It is used for thinning fiberglass resin. Last time I bought a gallon it was about $17
Sent: Tuesday, January 05, 2016 2:56 PM
Subject: RE: [Homebrew_PCBs] Heatless (cold) Toner Transfer for PCB making
Can we assume that's denatured alcohol ? ... need to get some acetone .... where do you get pure stuff ?
Date: Tue, 5 Jan 2016 08:18:17 -0800
Subject: [Homebrew_PCBs] Heatless (cold) Toner Transfer for PCB making
http://www.instructables.com/id/Heatless-cold-Toner-Transfer-for-PCB-Making/?ALLSTEPS
2016-01-06 by Jean-Paul Louis
> On Jan 5, 2016, at 7:02 PM, alienrelics@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> It says Ethyl Alcohol, which is often denatured. Not everyone uses the same denaturing agents.
> However, in one of the comments he says:
> "The one I use is Ethyl alcohol (pure 96%) also called Ethanol. It's the one used as antiseptic."
> Medical Ethyl alcohol seems to be about 95% or so.
> Hardware store denatured alcohol seems to be about 90%.
> https://en.wikipedia.org/wiki/Denatured_alcohol
> Some people in the comments mentioned Everclear. It seems to be sold in 75.5% (151 proof) and 95% (190 proof).
> Steve Greenfield AE7HD
2016-01-06 by Roger Blair
Pure Ethyl Alcohol (Ethanol) will be the hardest to find in the US. All the pharmacies in the US now carry IPA (Iso Propyl Alcohol) which is not Ethanol. 96% purity limit for current ethanol is not by accident. It is the maximum purity that you can obtain by distillation. In order to get 99%, you need to use a different process that will go beyond the 96% limit. I do not know the english name of the process.
When I was in France, 99% Ethanol was available at any pharmacy and was called “Alcool rectifié” which translate approximately by rectified alcohol.
My $0.02,
Jean-Paul
N1JPL / ex-AC9GH
> On Jan 5, 2016, at 9:18 PM, Roger Blair Roger.Blair@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> FYI...
> http://www.sciencelab.com/page/S/PVAR/SLE2248
> General Chemical Specifications: Assay (C2H5OH; by Volume) Min. 99.5% Water (H2O)0.2%
> Roger Blair
>> My $0.02,
>> Jean-Paul
>> N1JPL / ex-AC9GH
2016-01-06 by Ancel
WOW, that’s really expensive! $144.10 per liter + hazardous material fee + shipping.
Jean-Paul
N1JPL
> FYI...
> Roger Blair
>> My $0.02,
>> Jean-Paul
>> N1JPL / ex-AC9GH
2016-01-06 by rolohar@...
Yes,
Expensive enough to do a needs/cost/benefit reality check! My point was that greater than 99% purity was available... As a hobbyist, I would start with hardware-store grade materials and test my way up the cost ladder to a reasonable result for the application.
Roger
Jean-Paul
N1JPL
> FYI...
> Roger Blair
>> My $0.02,
>> Jean-Paul
>> N1JPL / ex-AC9GH
2016-01-07 by Howard Chester
2016-01-07 by Corey Minion
Correct me if I'm wrong... But isn't brandy, whiskey and vodka consist of denatured Ethyl Alcohol?If you make up a simple "still" to concentrate a few Liters of a well known Russian brand of vodka that is "filtered through charcoal seven times for purity", or perhaps contact the local "moonshiners" for a pure(undiluted) pint of their finest would be a lot cheaper?chester
2016-01-07 by alienrelics@...
2016-01-07 by Jean-Paul Louis
> On Jan 7, 2016, at 12:06 PM, alienrelics@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> Everclear 190 proof is available for around $30 per liter, after tax. Not sure why everyone is getting worked up about getting even more pure ethanol.
2016-01-07 by leeleduc@...
2016-01-07 by rolohar@...
Hi Steve,
I agree with you. I just found out about the Everclear product.
190 proof is 95% pure ethanol, so it should work just fine for the purpose.
73 de Jean-Paul
N1JPL
2016-01-08 by keith printy
You could just set up your own still and make it. Alcohol boils at a lower temperature than water , so when you distill it the alcohol boils off but the water stays behind. Another thought maybe try e 85 motor fuel? It is 85% alcohol 15 % gasolinethis alcohol would have to be very pure because a car does not run well if at all below like 180 proof
Sent: Thursday, January 07, 2016 8:53 AM
Subject: Re: [Homebrew_PCBs] Heatless (cold) Toner Transfer for PCB making
No
"Methylated spirit (Meths or denatured alcohol—but not Rubbing alcohol which is different) is ethanol which has been rendered toxic or otherwise undrinkable, and in some cases dyed.
It is used for purposes such as fuel for spirit burners and camping stoves, and as a solvent.
Traditionally, the main additive was 10% methanol, which gave rise to its name, but this is not always the case now.
There are diverse industrial uses for ethanol, and therefore literally hundreds of recipes for denaturing ethanol.
Typical additives are methanol, isopropanol, methyl ethyl ketone, methyl isobutyl ketone, denatonium, and even (uncommonly) aviation gasoline.
As used in the phrase denatured alcohol, denatured means "a specific property of ethanol, its usefulness as a beverage, is removed".
The ethanol molecule is not denatured in the sense that its chemical structure is altered."
ref:http://cqconcepts.com/chem_denaturedethylalcohol.php
(and decent pricing for 99% - not affiliated in any way)
Booze - that's 40-60% alcohol the most potent 'shine is 75%
you might be able to use the first few pints, which are toxic and undrinkable.
Corey
On 1/7/2016 8:35 AM, Howard Chester howard.chester@... [Homebrew_PCBs] wrote:
chester
To get it past 96% maybe they distill the alcohol again to further reduce the water content ? remember alcohol boils at a lower temp than water that is how a still leaves the water behind. I would think the alcohol is only being used in the toner transfer process as maybe a carrier? Most toners I have seen are polyester based and acetone will dissolve them. You can for example clean vinyl with acetone but you must dilute with water or it will dissolve it.
Sent: Tuesday, January 05, 2016 11:01 PM
Jean-Paul
N1JPL
> FYI...
> Roger Blair
>> My $0.02,
>> Jean-Paul
>> N1JPL / ex-AC9GH
2016-01-08 by Donald H Locker
> From: "'keith printy' keethpr@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
> Sent: Thursday, January 7, 2016 7:41:02 PM
> it.
> shipping.
> Jean-Paul
> N1JPL
> > FYI...
> > (H2O)0.2%
> > Roger Blair
> >> alcohol.
> >> My $0.02,
> >> Jean-Paul
> >> N1JPL / ex-AC9GH
> From: "rolohar@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
> Sent: Thursday, January 7, 2016 2:27:09 PM
> 1. It seems that the primary functions of the alcohol are to (a) clean the
> PCB and and artwork,
> and (b) dilute the effectivity of the acetone, then I do not see the need for
> "exotic" materials.
> 2. If the function of the acetone is to soften the laser toner so that under
> slight pressure it will
> get "sticky" and adhere to the copper, then it seems that there is no
> requirement for a "special" type of acetone, as any acetone will soften and
> eventually dissolve
> laser toner.
> I don't know what type of "blending" takes place between the alcohol and the
> acetone,
> if there is actually anything like cross-linking, etc. I doubt it.
> 3. If I can dig up some unwanted PCB artwork that was copied on a laser
> printer (on glossly paper),
> I'll do a quick and dirty experiment with the materials I have on hand, which
> would be
> 90% Iso, and off-the-shelf acetone from my local hardware store.
> I'm just not understanding the need for difficult-to-obtain compounds for
> such a simple
> operation.
> I hope some others will try whatever materials they have and we can see if
> this very
> alluring process can be made totally practical.
> BTW: On YouTube, there is also a video showing how to use shipping tape, like
> the
> Scotch shipping tape product, to transfer laser generated artwork to PCB's
> Looks very interesting.
> I don't have a laser printer, so I can't try it.
> Regards.
> Roland F. Harriston, P.D.
> From: "Jean-Paul Louis louijp@... [Homebrew_PCBs]"
> Sent: Thursday, January 7, 2016 10:45:22 AM
> Hi Steve,
> 73 de Jean-Paul
> N1JPL
> > ethanol.
2016-01-08 by leeleduc@...
I remember molecular sieves ,but would they get all the water ? what was nice about them you could bake them and reuse them
Sent: Thursday, January 07, 2016 8:45 PM
Subject: [Homebrew_PCBs] Re: Heatless (cold) Toner Transfer for PCB making
Distillation of ethanol will only produce about 95% ethanol. The mixture of ethanol and water produce what is known as an azeotrope. Azeotropes are a mixture of at least two different liquids. Their mixture can either have a higher boiling point than either of the components or they can have a lower boiling point. Azeotropes occur when fraction of the liquids cannot be altered by distillation.
Here's an interesting youtube video explaining this. How to make 100% Ethanol (anhydrous)
in this video we will be making some 100% Ethanol from 95% Ethanol. I use molecular sieves but other drying agents can be used. I just like sieves the most....
Preview by Yahoo
Dextrin is an ingredient in most white glue’s it is also used in fireworks . they mix it with water and sometimes a little alcohol. I would think water dissolves it.
Sent: Thursday, January 07, 2016 8:29 PM
To: Homebrew PCBs
Further to that, acetone is miscible with water which is really easy to find, so that may be an adequate diluent. I feel a bout of experimentation coming on! (I'm planning to use the inkjet paper with the dextrin surface, figuring that the dextrin will be softened/dissolved by the diluent while the toner will be softened by the acetone. Dextrin will then release the toner after it has had time to adhere to the circuit board.
Many thanks to the OP for noting this, and to the instructables author for the presentation.
Donald.
> "exotic" materials.
> eventually dissolve
> laser toner.
> acetone,
> would be
> such a simple
> operation.
> this very
> the
> Regards.
> Hi Steve,
> 73 de Jean-Paul
> N1JPL
> > ethanol.
2016-01-08 by Nuno Tavares
being
example
dissolve
> it.
> WOW, thats really expensive! $144.10 per liter + hazardous material fee +
> shipping.
> Jean-Paul
> N1JPL
> > FYI...
Water
> > (H2O)0.2%
> > Roger Blair
not
> >> called Alcool rectifié which translate approximately by rectified
> >> alcohol.
> >> My $0.02,
> >> Jean-Paul
> >> N1JPL / ex-AC9GH
in
Posted by: Donald H Locker <dhlocker@...>
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
Yahoo Groups Links
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
I’ve heard the term before. I work in heating and cooling and some of the refrigerant blends are described as such. They say it is 2 or more components but in use behaves as one.
Sent: Friday, January 08, 2016 6:37 AM
"Azeotropic" ?
There's another term I never heard before. Another thing to read and learn!
Thank you!
Nuno T.
Sent: sexta-feira, 8 de Janeiro de 2016 1:22
To: Homebrew PCBs
To get past 95.6% requires something other than distillation to separate the
alcohol from the water. At 95.6%, the ethanol and water boil off
simultaneously at the same temperature (it's an azeotropic mixture; look it
up if you want to know more) and the concentration just doesn't change any
more.
<https://en.wikipedia.org/wiki/Ethanol#Purification> has a good writeup.
Donald.
being
example
dissolve
> it.
> shipping.
> Jean-Paul
> N1JPL
> > FYI...
Water
> > (H2O)0.2%
> > Roger Blair
not
> >> alcohol.
> >> My $0.02,
> >> Jean-Paul
> >> N1JPL / ex-AC9GH
in
Yahoo Groups Links
2016-01-10 by duwaynes@...
2016-01-11 by Jeff Heiss
How do you tin your boards? Looking good.
Sent: Sunday, January 10, 2016 2:42 PM
I have been using toner transfer for years with my Brother printer and a Scotch Tl902 laminator, with great success. Only problem has been that I need to use a genuine Brother toner cartridge, and have had problems with a little over etching of larger copper pour areas. Saw this instructable, and thought I would give it a try, since my toner cartridge was almost out and the would have to order a new one soon. I have a couple generic cartridges that I use for general printing, but they have not worked well for making boards, so I thought I would give them a try.
Looking around at my painting stuff I had some denatured alcohol and a couple of different types of solvent. but no acetone. I tried a couple to see which one would dissolve toner, and found the Xylene that I used for thinning out some enamel worked well. I tried different mixtures and found 4 to 1 mixture of denatured alcohol to Xylene worked well. Printed a couple copies of a board layout on Hammermill color laser copy paper, and used a modified version of the method in the instructable. Using a eye dropper I placed a small amount of the mixture on cleaned boards and spread it around until I had a even coating on the board. I placed the laser print on the board and lightly pressed it down so it made even contact with the board. Then with the eye-dropper I flooded the back of the paper until it became nearly transparent and I could see the pattern through the paper. Waited about 30 seconds and covered the paper with a folded over paper towel, placed a small piece of board material on top and applied pressure for about two minutes. After that I removed the board and used the rounded back of a fork and burnished the board, first with the paper towel , and then without. After soaking the board in water and removing the paper, everything looked nice and crisp. Good adhesion over the entire board, and no voids that I could see. I etched the boards, and everything came out great. Nice clean lines, no breaks in any of the traces, good sharp clearance where I had traces going between pins, and very little problem with etch through on the large ground plane areas.
Looks like time to retire the old laminator. I will post some pictures of a completed board on my blog.
DuWayne
KV4QB.blogspot.com
2016-01-11 by duwaynes@...
2016-01-11 by rolohar@...
2016-01-11 by Corey Minion
DuWayne:Thanks for the detailed account of your heatless toner transfer experiment.As I suspected, the need or exotic materials is not required.There are many materials that will dissolve the polymer particlesthat make up laser printer toner, and the alcohol mix-in is used primarilyto reduce the effectivity of the solvent so that it softens, but does not completelydistort and weaken the image too much.Xylene is a good choice because it is relatively inexpensiveand readily available. Same for denatured alcohol, and I thinkthat ordinary drug store 70% or 90% isopropyl alcohol shouldbe OK.The alcohol is also effective in cleaning the bare PCB material.
I plan to try to duplicate your process sometime this week.ThanksRoland F. Harriston, PD***************************
2016-01-12 by K5ESS
Well using a respirator and gloves is a good idea in any case but: EPA has classified mixed xylenes as a Group D, not classifiable as to human carcinogenicity.
Group D: "Not Classifiable as to Human Carcinogenicity"
"This group is generally used for agents with inadequate human and animal evidence of carcinogenicity or for which no data are available."
Most if not all chemicals and compounds have a Material Safety Data Sheet MSDS that you can find online that will tell you about the potential hazards of that material.
Two widely used cleaners/solvents in the past that are now known and listed carcinogens are Carbon Tetrachloride and Trichloroethylene.
Mike K5ESS
Sent: Monday, January 11, 2016 7:51 AM
Subject: Re: [Homebrew_PCBs] Re: Heatless (cold) Toner Transfer for PCB making
One remark, please use respirator & gloves when handling xylene.
The stuff is 100000x more carcinogenic than we knew pre 1990.
I remember working in billboard printshops mid 80s and shoving my arms bicep deep into 55 gallon drums to clean off ink.
Wondering whats going to get me down the road.
Corey
On 1/10/2016 11:47 PM, rolohar@... [Homebrew_PCBs] wrote:
DuWayne:
be OK.
2016-01-12 by rolohar@...
2016-01-12 by satdaveuk@...
2016-01-12 by camillus
On 1/12/2016 4:09:27 AM, satdaveuk@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
Hi
Anyone here know of a simple way to reset my usage counters
Got plenty of toner left but not letting me use due to print count.
Regards
Dave
2016-01-12 by lilacbarn@...
Hi DuWayne. Thanks for your added and slight variation on the original instructable.
3 Questions:
1) is your Hammermill paper of the glossy photo type or a different one?
I have a load of Kodak High Gloss Premium Photo Paper suitable for inkjet printers
Do you think that would work too. (I dumped my inkjet for a laser a while ago and get my
photos done by Costco - much cheaper!)
2) you said that you "flooded the back of the paper".
Was that with the Xylene/ethyl alcohol mix or with just the ethyl alcohol? What was the intent of that flooding?
3) how long do you wait after applying pressure and burnishing with a rounded tool before
soaking to remove the paper baking from the toner? Do you allow the alcohol/xylene mix to evaporate before the soak?
I plan to try this method as I was without a laminator and the hot iron method did not work for me with the Brother laser toner.
Thanks, Geoff.
2016-01-12 by duwaynes@...
2016-01-13 by lilacbarn@...
Thanks DuWayne. That was really helpful. If I get any reasonable results with the Kodak paper I will post.
Geoff.
2016-01-13 by leeleduc@...
2016-01-13 by rolohar@...
2016-01-13 by søren hansen
Pictures!! :-)
Heatless Toner Transfer:First experiment with this technique: Very successful.I used ordinary 70% Isopropyl alcohol with acetone in the ratio given in the YouTube video.And, I must admit that my technique was very sloppy.With a bit of refinement, I think I would be inclined to use this method over heat transferbecause it gives very good etch images with an absolute minimum of fuss, bother, andunreliable results.Next, I will try 70% Iso with Xylene.Regards,Roland F. Harriston, P.D.From: rolohar@...
Sent: Monday, January 11, 2016 10:53:15 PM
Subject: RE: [Homebrew_PCBs] Re: Heatless (cold) Toner Transfer for PCB makingBesides:You are not going to take a bath in the stuff!At most, you will have a few CC's out in the open, or a few eyedroppers' full.
2016-01-14 by David Pickering
2016-01-14 by vk5xgh@...
2016-01-14 by Mike
Some things to try is to let the alcohol-acetone saturated paper fully dry on the board (didn't let the paper fully dry the second attempt), let the paper soak in water longer before removing (may put some dish washing soap in the water). Will try to find a more concentrate alcohol to use (will have to adjust the alcohol acetone ratio with a higher alcohol concentrate).
This process looks promising enough to keep experimenting to come up with a mix, process that works for me."
2016-01-14 by camillus
On 1/14/2016 10:30:01 AM, Mike k4gmh@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
Tried the"heatless" toner transfer process using what I could find at home, acetone and rubbing (isopropyl 70% by volume) alcohol. Printed the PCB artwork on standard, white, office paper. Using the 8:3 mix didn't get any transfer to the PCB. Upped the ratio to 8 parts alcohol to 6 parts acetone. Did get a good transfer, but some of the toner came off the board while trying to remove (rubbing) the paper residue left when the paper was pealed off. This was my second try to use the "heatless" toner transfer.Some things to try is to let the alcohol-acetone saturated paper fully dry on the board (didn't let the paper fully dry the second attempt), let the paper soak in water longer before removing (may put some dish washing soap in the water). Will try to find a more concentrate alcohol to use (will have to adjust the alcohol acetone ratio with a higher alcohol concentrate).
Mike, K4GMH
2016-01-14 by rolohar@...
HI, You do not need an more concentrated alcohol. All you need to do is experiment with the amount of acetone. It is the acetone that makes the toner sticky. The alcohol is there to dilute the acetone so it does not dissolve the toner completely.
Mike, K4GMH
2016-01-17 by alan00463@...
2016-01-18 by RDHeiliger
