Homebrew_PCBs
Flip n' Print ? (concept proposal for development)
2010-05-20 by Richard
Hello Homebrew Printed Circuit Group!
I have successfully modded my Epson Artisan 50 printer Epson Printer
Mod
<http://groups.yahoo.com/group/Inkjet_PCB_Construction/photos/album/1664\
97487/pic/list> to make PCB boards. I did this, as I'm sure as all in
this forum, want to quickly build working devices from all the many
awesome microchips out there (ie: MCU, RFID,WIFI,GSP, etc.)
In my current project, I need to fabricate a "system-in-package" (SIP)
module containing an RFID reader chip (QFN), MCU chip and WIFI
chip(QFN) on two PCB's (1 1/4" x 3/4") including the required discrete
SMD's (resistors, capacitors, inductors, x-tal, etc).
This project requires very small SMD's and a very small and dense
multi-layer PCB with micro vias for fabrication.
This project well exceeds my existing "Homebrew" equipment capability to
fabricate this module.
In assessing the demands for the size and scope of this project (for a
"homebrew" solution) the "show stopper" was all in the fabrication of
the PCB itself.
Here I began my quest for a different "homebrew" solution.
Could I build this module without the complex multi-layer PCB?
Could I interconnect all SMD's (IC's and discrete's) without soldering?
Concept proposal:
Start with a blank substrate (metal, glass, FR4,ceramic,etc) in place of
a conventional PCB.
Apply double sided releasable 3M "micro adhesive" tape covering the top
surface of the substrate.
"Pick and Place" all SMD's onto the top surface of the substrate. Note:
with no PCB traces or vias to contend with, a 50% reduction in SMD
spacing is obtained.
"Epoxy Pot" the top surface embedding all the SMD's.
Flip over the substrate (now working from the bottom side) and release
the tape and substrate from the potted assembly. Clean off any residual
adhesive.
At this point, you should see only the exposed metal contacts of all the
SMD's.
Using the modified Epson Artisan 50 printer (set head height to pass the
1/8" thick epoxy pot assembly depth) and print with special UV curable
conductive ink (Metalon®)
UV cure (need to build a "homebrew" UV source for curing the conductive
ink). The commercial version does it in 3 or 4 seconds.
Subsequent conductive traces (emulating the multi-layers of a
conventional PCB) are first "masked out" by printing with a different
inkjet of NON-conducting ink at the conductive trace crossovers.
DONE! : )
Re: Flip n' Print ? (concept proposal for development)
Addendum
To "Flip n' Print?"
Other options:
Flip n' Autocatalytic method
Pick and place all SMD's and pot assembly.
Inkjet liquid palladium for your desired circuit traces.
Autocatalyticly "grow" gold or copper traces to the desired thickness.
For emulation of multi-layered construction, Inkjet NON-Conductive ink to cross-over areas (as an insulating mask).
Flip n' Stitch method
Pick and place all SMD's and pot assembly, then send out to be "stitched" (ultrasonic wire bonded) with special "INSULATED" X-wire bonding wire) Note: This method requires the use of the "wire bondable type" discrete SMD's. This method also allows the direct connection to a bare IC die.
This method creates point to point and multi-point "air wire" or "rats nest" connections in gold, copper or aluminum insulated wires. The air wires can be potted for protection.
Note: A good "used" wire bonder goes for about $ 8 to $ 10K "…… so send it out for stitching! : )
Note: All methods are "solder-less" and without the need to fabricate a conventional multi-layered fiberglass "PCB".
All proposed methods here are only concepts offered for investigation and/or development.
--- In Homebrew_PCBs@yahoogroups.com, "Richard" <richard.liberatoscioli@...> wrote:
> Mod
> the PCB itself.
> Concept proposal:
> a conventional PCB.
> adhesive.
> SMD's.
> DONE! : )
2010-05-20 by James
I think you would have difficulty getting all the components lined up at exactly the same height and making reliable connections. It would be interesting to try but if I were trying to make something so complex I'd have a batch of boards made.
Hi James!
"....difficulty getting all the components lined up at exactly the same height...."
You lost me here ... all the SMD's lay in flat down against the flat surface of the substrate, easily keeping all the SMD's at the same level.
--- In Homebrew_PCBs@yahoogroups.com, "richard.liberatoscioli" <richard.liberatoscioli@...> wrote:
Re: [Homebrew_PCBs] Re: Flip n' Print ? (concept proposal for development)
2010-05-20 by Henry Liu
I don't see the advantage of the flipping.
If you can print layers of conductive ink and non conductive ink then you
can just make a multilayer pcb and place the components on top. You can
just make your final pads be all connected through the lower layers with the
equivalent of blind filled vias.
I don't think the conductive ink ejects well but I'd be very curious to hear
your results.
I've found some good UV curable inks but they're not cheap and they're not
conductive.
On Thu, May 20, 2010 at 2:59 PM, Richard
<richard.liberatoscioli@...>wrote:
> Hi James!
> height...."
> --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
Hi James!
" ...but if I were trying to make something so complex I'd have a batch of boards made..."
Well, the idea here is to develop "Homebrew" solutions to an SMD technology, that by virtue of its mini and now micro sizes, threatens to make "Homebrewing" just to difficult to do.
Sure, you can pay some fab shop to do it for you ..... but, this forum is to develop "Homebrewed" solutions.
> Hi James!
> --- In Homebrew_PCBs@yahoogroups.com, "richard.liberatoscioli" <richard.liberatoscioli@> wrote:
Hi Henry!
Look here for the conductive inks:
http://www.novacentrix.com/
> your results.
> conductive.
> > Hi James!
> > height...."
Those machines look expensive. Certainly a lot more expensive than sending
it out to a pcb house.
If you are able to buy some ink and eject it out of a cheap epson printer,
I'd be very interested!
On Thu, May 20, 2010 at 3:31 PM, Richard
> Hi Henry!
Henry,
How long would it take you to make a 1 1/4" x 3/4" with two 64 pin QFN IC's and aproximtyly 25-30 descrete 0402 SMS and a 4 layer PCB , then solder them all in place?
> Hi Henry!
> > your results.
> > conductive.
> > <richard.liberatoscioli@>wrote:
> > > Hi James!
> > > height...."
NOOOOOO! ... the mod printer is cheap! $ 120.00
Heres the mod I did:
http://groups.yahoo.com/group/Inkjet_PCB_Construction/photos/album/0/list
> > Hi Henry!
But can you eject the conductive ink with your $120 printer? Have you tried
anything exotic besides inkjet inks? Will they even sell you the conductive
ink in small samples?
Your project seems pretty doable using double sided technology. If you're
hurting on space, get BGA components and use 0201 components.
I pay like $2/board for professional assembly with 200 components.
On Thu, May 20, 2010 at 3:45 PM, Richard
> sending
> printer,
> > > Hi Henry!
The Epson printer was chosen just for this reason. Its printer head technology is the same "Pizo type" used in the commercial conductive ink jetables.
> > sending
> > printer,
> > > > Hi Henry!
2010-05-21 by James
> Hi James!
Oh I misread part of the process. I had thought you meant you would lay out the components upside down and pot them in epoxy up to the level of the leads and then print on top of that. Makes sense now, curious how this works out.
2010-05-25 by Richard
Project update:
In my modified Epson Artisan 50:
http://groups.yahoo.com/group/Inkjet_PCB_Construction/photos/album/166497487/pic/list
I added a very simple 15 minute mod to allow the print head to pass my experimental "Flip n' Print" module.
The mod is simply to remove the two existing print head adjustment cams and permanently raise both ends of the print head "guide bar" to their maximum vertical heights. I used heavy gauge magnet wire to do this. DONE!
The printer now expects anything I want to print is 1/4" thick.
This thickness is ideal for my project even allowing for the 1/4" mini-pin header for connections to the outside world (USB,I/O,Battery,etc).
I will now be fabricating the "potting molds" representing the board size of my project (can be of any size from 3/4" by 3/4" up to 7" by 10"). I will be using 1/4" thick Dupont "Corian" for its easy to machine router and cut very precisely. Not only does the Corian serve as the potting mold, but also serves as the carrier transport for feeding the potted SMDs through the printer. No matter what size "potted board" your making, the carrier transport dimensions will always be 8 1/2" by 11"(for stable printer feeding through the printer). The "potting mold" templates are 100% reusable.
Other stuff:
As I pointed out before, by not having PCB traces and vias on the same surface as your SMDs, an over 50% reduction in "board size" is afforded. Something else I realized tonight, since the SMDs are "picked and placed" onto the "micro adhesive only"(no soldering) the SMDs can be placed "end to end" or "side to side" depending on the design of your schematic.
For instance, 3 legs from my 64 pin QFN IC go to 6 capacitors, each leg going to two capacitors, then all caps go to vdd-.
This normally would take 16 PCB tracks just to do this. By joining the SMDs "physically", soldered end to end without wires, from the top surface, I have now reduced my "printed wiring" down to just 4 connections. Similar printed wiring reductions are reflected throughout the entire assembly. Basically, your eliminating approximately 50 to 80% of the total "printed wiring" required!!
> Mod
> the PCB itself.
> Concept proposal:
> a conventional PCB.
> adhesive.
> SMD's.
> DONE! : )
..... an example of the conductive traces "reduction" ratio:
64 pin leadless QFN RFID GEN2 UHF Reader IC with all required SMDs connected (res,caps,inductors,x-tal,etc.)
Conventional multi-layer "PCB" verses "Flip n' Print"
16 traces reduced to 4
5 traces reduced to 2
14 traces reduced to 3
23 traces reduced to 10
7 traces reduced to 4
6 traces reduced to 3
8 traces reduced to 3
Totals:
110 traces reduced to 41
Instead of a 5 or 6 layer conventional "PCB" (1.5" by 3/4") only 2 or 3 "printed layers" are needed.
By placing the SMDs "end to end" and "side by side" in combinations, for these connections, you afford essentially a zero "resistive loss",zero "stray inductance and capacitance" and highly conductive soldered connections.
With the now greatly reduced physical length of the "inkjetted conductive traces"(most are only 1/8" to 1/16" long), the higher resistance of the conductive inks now becomes negligible.
In essence, this assembly method uses the SMDs themselves as the majorty of the "wire traces" required.
> Mod
> the PCB itself.
> Concept proposal:
> a conventional PCB.
> adhesive.
> SMD's.
> DONE! : )
NOTE:
I have the special metal CD insert for making 2.5" by 3.5" conventional circuit boards made by Full Spectrum Engineering.
You can read about it here:
http://www.fullspectrumengineering.com/pcbinkjet.html
Its yours for the asking (FREE) ....just drop me an e-mail or Yahoo IM
> Totals:
> --- In Homebrew_PCBs@yahoogroups.com, "Richard" <richard.liberatoscioli@> wrote:
> > Mod
> > the PCB itself.
> > Concept proposal:
> > a conventional PCB.
> > adhesive.
> > SMD's.
> > DONE! : )
.........Yes!
Any RCL electronically grouped is "physically grouped" into a very tight formation during the "pick and place"
--- In Homebrew_PCBs@yahoogroups.com, Andrew Villeneuve <andrewmv@...> wrote:
> So you're saying that you're soldering SMD devices directly to one another
> on the board when possible, instead of running traces?
> -Andrew
2010-05-26 by Richard
Addendum Notes:
The factory printer head cams do not allow such an extreme height adjustment. You must secure the print head guide bar up to its max. obtainable height yourself.
1/4" is the absolute max. height you can raise the print head in this mod for this printer.
This mod converts your standard PCB printer to a 1/4 inch thick "SMD module printer"
As you will want to print out(onto your temporary substrate) an SMD "component placement outline screen" before "pick and placing", simply print this screen on a blank 8.5" by 11" by 1/4" thick Corian. Then your transport carrier stacks on top for pick and place.
> Project update:
> Other stuff:
> > Mod
> > the PCB itself.
> > Concept proposal:
> > a conventional PCB.
> > adhesive.
> > SMD's.
> > DONE! : )
.... THIS CD PCB ADAPTER HAS NOW BEEN TAKEN
Thank-you!
> NOTE:
> > Totals:
> > > Mod
> > > the PCB itself.
> > > Concept proposal:
> > > a conventional PCB.
> > > adhesive.
> > > SMD's.
> > > DONE! : )
2010-05-26 by Andrew Villeneuve
How often can this be practical? It seems to me that the vast majority of
signals would not happen to align with the physical pin you needed in order
to attach components side by side. You'd need to space them out and put
small traces.
I have seen some clever IC configurations along these lines, though - I've
once seen on a production board, SMT memory ICs literally stacked atop one
another, all the top pins soldered directly to the bottom pins, with just
the chip-enable and write-enable signals broken out independently.
-Andrew
On Tue, May 25, 2010 at 10:28 AM, Richard
> .........Yes!
Hi Andrew!
I'm not sure exactly what your saying.
First, did this make sense to you?:
http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/25979
Basically, what I'm doing is making micro "hybrids" out of the top LCR circuitry before I commit them to bottom layer routing.
IE: a top layer 16 point(connection)circuit then becomes only 4 points of bottom layer(connections) Your PCB placement and routing software now sees the this "hybrid lump" as only 4 points of connections.
In other words, this method is not just one routing algorithm, but divided into two, a separate "top layer optimization" and a separate "bottom layer optimization".
Also, Inkjetting the "muti-layer bottom layers"(conductive and insulating) affords a unique optimization in routing in that you can now "spot mask" areas without masking the entire layer.
If you dont understand what I'm saying here, I can give you a link to my webmeeting for a audio/visual explanation of this.
> small traces.
> -Andrew
> > .........Yes!
"......It seems to me that the vast majority of
signals would not happen to align with the physical pin you needed in order to attach components side by side" - Andrew
No!!! the opposite is true. I gave the example of a complex circuit i'm now working on, showing a 16 to 4 bottom layer trace reduction by making the top SMDs present themselves as a "micro-hybrid" ie: RCL SMDs physically lumped together for just these 3 pins off my 64 pin IC. This is repeated throughout the entire circuity to varying degrees. The average "bottom layer" trace reductions looks be at least 60%.
I then force, by physical placement(ie: T,H,L,etc patterns)of the SMDs themselves to an optimized layout for the most compact and shortest routing path possibale.
This gives me great control especially for the demanding UHF transmission paths.
> small traces.
> -Andrew
> > .........Yes!
.....also , If you plan to use your software "auto-routing" you must inform the software(simply by creating a new "micro-hybrid" component for your component library. This way the auto-router knows NOT to treat the SMDs as discretes , but as a hybrid lumped module.
> Hi Andrew!
> > small traces.
> > -Andrew
> > > .........Yes!
2010-05-27 by gnuvvekaavaali
Wow - very creative effort, indeed.
How do you ensure the accuracy of the SMD placement on the tape?
2010-05-27 by Richard
Hi gnuv!
On a blank 8.5"x11"x1/4" Corian@ substrate, print out your component layout screen (lets say that's a 2.5"x3.5" finished module size) in the center of this substrate.
Apply double sided (releasable) "micro-adhesive" tape/film over your printed screen (its "micro thin" and "see through").
Apply SMDs with a vacuum assisted "pick and place" probe.
When finished, stack on top your substrate the 8.5"x11"x1/4" Corian@ potting mold (with the 2.5"x3.5" square hole in the middle).
Epoxy Pot to top of mold. When cured, release potting mold from substrate, potting mold is then flipped over, and run through the modified printer for conductive and insulative inkjeting.
--- In Homebrew_PCBs@yahoogroups.com, "gnuvvekaavaali" <gnuvvekaavaali@...> wrote:
...... screen printing "on top" of the "micro-adhesive: may be an even better solution.
> Hi gnuv!
> --- In Homebrew_PCBs@yahoogroups.com, "gnuvvekaavaali" <gnuvvekaavaali@> wrote:
It may even be possible to print both the conductive and insulating layers at the same time as they are from separate inkjets.
This would cut the total "print/UV cure" time in halve!!
> > Hi gnuv!
NOTE: The LAST thing you do is to release your completed epoxy potted module from the Corian@ "mold/carrier".
Should this assembly process prove competent, fabrication of extremely dense, multi-chip modules could be completed and working in around 4 hours(provided parts in hand and cad ready).
> > > Hi gnuv!
Design considerations:
As this assembly process is targeted to the fabrication of very low powered 3/5volt microchips and their supporting SMDs, there are instances where in the final output stage, higher current carrying capacity wiring is required.
The wiring (ultrasonic die bonding wires) used "inside" the microchip address this issue by doubling or tripling the bonding wires to the same connection.
The simple addition of "solderable" insulated magnet wire for these higher current conductive paths are resolved (this is a very easy and minimal "manual" wiring requirement).
In other RF microchips (ie: Bluetooth,WIFI,GSM,etc) "coplanar printed" transmission paths could be fabricated.
> > > > Hi gnuv!
.... with the extreme "back to back" SMD placement of the antenna matching network, I have not yet had to implement coplanar design.
> > > > > Hi gnuv!
2010-05-27 by Derk Steggewentz
Richard,
I am following the thread. because I like the creative
approach.Regarding accurate placement: Why don't you just place the
components arbitrarily and after potting and peeling of the tape you
scan the side with the exposed pins. With a piece of software (to be
written) the user then can interactively identify the components on the
image. With this information and the schematic the software has all the
information to do the rest, including printing.
Although I can see a few problems with the general approach I think it's
worth following.
Derk
Richard wrote:
> Hi gnuv!
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "gnuvvekaavaali"
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "Richard"
> schematic.
Hi Derk!
....mmmmmmmmmmmmm , well, first let me say that your thought process is so powerful, I will have to assume that I fatally missed something in your rational.
I'll respond briefly on this in hopes I'll get to better understand the merits of your suggestions.
In prima fasia, this would be a complete disaster. Placing the SMDs in a "random" fashion, would seriously violate essential physical and electronic associations that the components function provides.
Example: With the very high speed microchips we use today, very heavy use of decoupling and bypass capacitors must be used and must present themselves IMMEDIATELY (asigned placement) on the IC pins they afford their function to.
"Random placement" of these components would folly at best.
--- In Homebrew_PCBs@yahoogroups.com, Derk Steggewentz <derks@...> wrote:
> Richard,
> worth following.
> Derk
> Richard wrote:
> > Hi gnuv!
> > schematic.
Richard wrote:
> Hi Derk!
> in your rational.
I guess so. Maybe because my unfortunate use of the term 'arbitrary'.
Although with my suggestion you could position components arbitrarily
because software could be written to do the trace printing (component
locations are taken from the scan), it, of course, does most of the
time makes no sense electrically/physically, as you pointed out (This is
self explanatory and I implied it). So you should still do a well
thought out component layout, but manual placement does not need to be
as precise as you suggested (making a hardcopy of the layout, put the
transparent adhesive foil on it, using a vacuum tool etc etc..). That
should make it easier for quick prototyping in the home lab - wasn't
that you initial idea?? It also would avoid mistakes in the component
layout because the trace printing function gets its information from the
actual physical scan of the components in place.
Hope that makes my point a little clearer
Now, talking about high speed components and capacitors - Besides trace
resistance, the dielectric properties of the insulating ink and it's
thickness, which I assume is rather thin (significantly thinner compared
to multilayer pcb's), will sure have effects like coupling and unwanted
filtering. Granted, this problem is known for PCBs as well, but it is
understood to a degree.
What's about heat build up in the epoxy pot?
Another disadvantage, although it probably only plays a role for more
complex circuits, is, considering you suggested this method for quick
prototyping, the fact that it's going to be very difficult to access
the circuit for probing (even many component pins might not be
accessible anymore) and replacing or adding components is absolute
impossible. For me, these are both things that are extremely important
in prototyping. As a matter of fact, that's the whole idea of a
prototype. Spice and breadboarding just don't give you the whole picture
with increasing frequencies. Wouldn't matter so much for a final
product, but with that I would go to some pcb manufacturer anyway.
The last point actually would pretty much rule this method out for me,
even if it would work. I just wouldn't see a place in my development cycle
(design on paper, component selection, simulating w/ SPICE,
breadboarding if necessary and/or possible, prototyping, probing and
refining, finalizing).
I still like the idea though, maybe just as a thought experiment - or
maybe for some special cases I could see an application.
Just some thoughts, Derk
> their function to.
> <mailto:Homebrew_PCBs%40yahoogroups.com>, Derk Steggewentz <derks@...>
> wrote:
> > Richard,
> it's
> > worth following.
> > Derk
Hi Derk!
I'll address some of the points you make.
"...because software could be written to do the trace printing" -Derk
Excellent and very powerful PCB CAD software already
exists(KICAD,Eagle,etc.)for FREE! Do you really want to start your project with trying to first write your own routing software?? I don't think the "homebrewer" has on staff a seasoned team of code writers at their disposal : (
".... but manual placement does not need to be as precise as you suggested" -Derk
Well, yes it does! The CAD software un-forgivenly demands this. It expects what you place in its "virtual design board" to be absolutely representative of the real world "outside physical placement" of the actual components location. When I have you print the component layout screen to the substrate, the CAD software later makes reference to this fine placement when you flip the module upside down and now needs to print micro thin conductive traces. Think about a 128 pin QFN IC with lets say 50 0404 SMDs. Your SMDs better be right on the money!
"What's about heat build up in the epoxy pot?" -Derk
This process is targeted to the ultra low powered new generation of microchips we all use today(MCU,RFID,GSP,ZigBee,GSM,etc.) Ultra low power equates to ultra low heat. Heat dissipation is not really even an issue here. The use of epoxy potting in my process was used for the complete elimination of fabricating an extremely complex multi-layer conventional PCB(FR4). The fact that the epoxy potting I'm using has great thermal conduction by the manufacturer's design was not even a considered attribute in my design, thou the relative bulk mass of the potted assembly does provide for an excellent "heat sink".
"prototyping, the fact that it's going to be very difficult to access
impossible. For me, these are both things that are extremely important". - Derk
In re of "probing" .... your wrong! All the SMDs remain 100%accessible, even the connections "inside" of the constructed "micro-hybrids". Yes, they are covered by the insulating mask, simply run your finished module through the printer again, this time printing the "inverted version" of the component screen. With a micro-sized drill or sharp needle point probe, slightly tag the surface to pass through to the conductive layer underneath.
"....Replace/Adding components is ... impossible.... " -Derk
That's very true! But think about it. Is the "homebrewer" equipped with special and very expensive "solder re-work stations" that allows changing out a 128 pin QFN or 0404 SMDs??? Your talking about ICs that cost on average $3 to $5 and descretes around 20 cents a piece.
Have you ever tried to "solder wick" out a defective IC before? Chances are you'll lift every "pad" right of the board!
My point is .... for the cost and time involved,if you have a defective module...PRINT OUT A NEW ONE!! In about 4 hours, your back up and running!
And this final thought:
I currently prototype with the expensive and NON-REUASABLE Scmart@ boards. Many of latest and greatest IC technologies today "complain" and are "unstable" in such a "rats nest" prototyping environment. Manufacturers today must commit their prototypes to the fabracation of "real" sized PCBs to even develop the circuitry through many iterations of the "true sized" PCBs.
Therefore; I respectfully do not hold with most of your observations or rationals. I do hope you continue to further asses this concept assembly and to share your thoughts into its development.
> Richard wrote:
> > Hi Derk!
> > in your rational.
> > their function to.
> > <mailto:Homebrew_PCBs%40yahoogroups.com>, Derk Steggewentz <derks@>
> > wrote:
> > > Richard,
> > it's
> > > worth following.
> > > Derk
2010-05-28 by Derk Steggewentz
> their disposal : (
No, I don't want to reinvent and reimplement existing router apps. I am
thinking of using the scan to e.g correct component placement in the
input file of the Router, using maybe a router produced Gerber and
slightly shifting components, modifying/extending Kicad etc. etc. There
are many approaches thinkable and they don't seem insurmountable to me.
That problem is exactly what I tried to solve with my suggestion. Did
you ever try to manually place something onto something adhesive? When I
do, it's usually always a tiny little bit off. And then there is no
pushing around anymore and cursing won't help either, as soon as one
corner touches the adhesive surface, that's it. Well, I guess some
mechanical and optical (think parallax) help can be constructed. I'd
rather write some code, trying to take human failure out of the equation.
I like your idea of 'running your finished module through the printer
screen'. Good thought. But I have difficulties to think of how that
would work in the real world. What is if there is a conductive layer in
between, e.g. a ground plane, which I can imagine you want considering
all this tight spacing and possibilities of capacitive coupling etc? Or,
if no layer, what if a trace crosses just there and you are poking your
needle through possibly more then one of them? It doesn't seem practical.
> up and running.
Yes, I hand solder surface mount components quite frequently. And yes, I
have tried and succeeded to "solder wick" out a defective IC before,
more then once. O.k. not a 128 pin QFN, but regular SOPs etc.. The
majority of SMT components ain't 128 pin QFN's anyway. Regular solder
station and a fine tip is all you need. I want to be able to do that
with my prototypes where an IC (your quote) 'cost on average $3 to $5'.
PRINT OUT A NEW ONE (your quote) and throwing away maybe 10 of the other
chips in the circuit worth $3 to $5 apiece does not sound like a great
option to me.
Very true. But that's not what you are doing with your technique. Your
'hybrid' is as far away from a a 'real' sized PCB as it gets.
The advantage of real prototype PCBs are also that I can put my finger
onto components or traces, introducing capacitance and changing circuit
behaviour, take a soldering iron and quickly add a cap, change an R etc
etc (with my cheap soldering iron), until i am ready for the next
iteration of the prototype pcb.That would possibly save substantially on
the number of iterations. Each iteration with your technique, even the
smallest, requires a complete redo. I can change an R in a minute while
you have a 4 hr turn around.
Derk
2010-05-28 by Richard
Hi Derk!
Thank-you for your added/expanded thoughts here.
In this most resent iteration, I do now hold with much more in what your presenting. I now have a much better understanding to your points of view.
This concept assembly proposal is certainly not the cure all for all situations.
I venture in this concept to address the desire to "homebrew" the many mobile projects I have in mind using the absolutely awesome capabilities of these new generation microchips, but realizing the "micro size" nature of them threatens the affordability and capability of the "homebrewers" to fabracate them.
This is my quest.
> > their disposal : (
> > up and running.
> option to me.
> Derk
.... now back to design considerations!
"....with your technique, even the smallest, requires a complete redo. I can change an R in a minute while you have a 4 hr turn around" -Derk
I hear you, Yes! but my rational is this:
Your capability to change out a resistor in one minute is a "red herring" to the "means-to-an-end" that my assembly affords.
Think about the amount of time you had invested into fabricating your prototype before you had a "resistor" to replace!
Compare your "conventional methods" to the fabrication of my current project.
Build a working "proof-of concept" device on a 1.5" x 3/4" multi-layer(5 layer) PCB for field testing outdoors(wet environment) with two 64 pin QFN ICs with around 40 0404 discretes.
I could do this in 4 hrs, every 4 hrs, you would need at least a month (and thats assuming you have the special equipment to fabricate such a complex micro-sized assembly ... most "homebrewers" don't)
And this is a "real" project, its an "invisible fence" (pet containment) and is embedded into a dog's collar.
> Hi Derk!
> This is my quest.
> > > their disposal : (
> > > up and running.
> > option to me.
> > Derk
2010-05-28 by James
> Hi Derk!
I don't think he meant just randomly throwing them down wherever they land, but rather place them such that the layout makes sense, without worrying about the precise alignment of everything, then scan that and draw the traces for it. There are certain rules for the layout, but components need not be placed with extreme precision.
2010-05-30 by Richard
Hi James!
Yes! ..... after narrowing down Derks process, it's really a brilliant idea!
I've tried at look see at this in KIKAD, if I could get the "scanned" jpeg into the software's design window to show up as an overylay.
There would be a need to have some "reference object" in the scanned jpeg so you could scale your design window against the scale of KIKAD.
I'll continue to ponder this process for sure.
> > Hi Derk!
... one drawback is that for every copy (replication) you make, you have to go in you CAD and "pull" all your end points to the new "skewed" SMDs positions.
I think a "homebrewed" XYZ mechanical assist "pick and place" may be a better approach to the fine placement of the SMDs.
> Hi James!
> > > Hi Derk!
