Muriatic acid + drug store hydrogen peroxide => cannot get cupric chloride??
2010-02-13 by awakephd
I am following up on a comment in an earlier thread, to the effect that starting with 2 parts drug store hydrogen peroxide + 1 part Muriatic acid, one cannot ever get to the point of having CuCl2. (BTW, please forgive & correct if I do not get the chemical formulas right. Chemistry was a LONG time ago!)
I am concerned / disappointed, because I have been saving my used etchant, made from the above, thinking that I would eventually build a tank to bubble in air to regenerate it, etc. But now it sounds like I would do better to neutralize what I have and start over.
1) Is that right, or is there any way to use the used etchant I now have on hand?
2) What do I need to do to make up an etchant mix that WOULD serve as the base for CuCl2?
Many thanks ...
Andy
Re: [Homebrew_PCBs] Muriatic acid + drug store hydrogen peroxide => cannot get cupric chloride??
2010-02-13 by Stefan Trethan
If you actually want to use air to regenerate it that could work. You
might have to fine some CuCl to add, it could take a long long time
otherwise.
I don't think many people are patient enough to use air regeneration,
concentrated H2O2 is such a nice quick fix.
ST
> Many thanks ...
> Andy
Re: Muriatic acid + drug store hydrogen peroxide => cannot get cupric chloride??
2010-02-14 by designer_craig
I don't see why it would not regenerate with air.  However, because the drug store H202 is only 3% you resultant solution is going be fairly weak in CuCl, you may need to evaporate the saved etchant to up the concentration.  I have seen posts suggest 30% H202 is available at beauty supply outlets, used for hair bleaching.
I was able to find a gallon of 3% H202 at my local Smart and Final
warehouse grocery store, was fairly low cost.  Its used in the food service industry as a sanitize.  I don't worry about regeneration and just make up new each time but I have been evaporating the spent etchant and saveing the resulting CuCl for future use. Not sure I will use it as I am thinking of going back to ammonium persulfate because its nice and clean with no corossive fumes. You do have to heat the AP to make it work.
> Many thanks ...
> Andy
2010-02-14 by DJ Delorie
"awakephd" <a_wake@...> writes:
This is wrong - I did exactly that.  I started with two parts 3%
(drugstore) peroxide and one part 37% (hardware store) HCl, added
copper, and now have a tank of gleaming green CuCl etchant.
It's not instant - I dumped the copper in the tank, turned on the air
bubbler, and waited - it took a few days to completely convert (3
liters solution, 0.5 lb copper).  Probably would have gone faster if I
had put the copper in right away, but I didn't figure that part out
until a few days had past, and most of the H2O2 was decomposed, so I
had to pour more in.
2010-02-14 by awakephd
Okay, it sounds like I'm back to plan A -- saving the etchant and making a bubbler tank down the road. A followup question -- now that you have the CuCl, how long does it take to etch a board with it?
BTW, is it CuCl or CuCl2?? I think I've seen it both ways on this forum??
Re: [Homebrew_PCBs] Re: Muriatic acid + drug store hydrogen peroxide => cannot get cupric chloride??
2010-02-15 by DJ Delorie
Usually 3-6 minutes depending on how long I let it warm up first, and
if I manually swish it around in the etchant or let the bubbler do the
work.
http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/#Chemistry_of_cupric_chloride_etchant
