Help finding transformer for r.s.u.
2007-07-25 by SRY
I've been meaning to build a resistance solder unit. I went to the
local RS yesterday to see what types of transformers they had. They
didn't have anything close to what I hoped to find. Not deterred I
went to an electronics store. There sure were a number of large flat
screen tvs in for repair! I gave the tech what I hoped would be an
easy part to provide. Nope, he said,  try Jameco on line. So I came
home and I did. Either I'm not sure what to put in the filter or I'm
looking for an oddity.
I'm trying to build a resistance solder unit.
I've searched on-line.
For the curious here are a couple of links:
http://www.girr.org/girr/tips/tips1/solderer.pdf
But this one uses a battery charger. I was hoping for something a bit
smaller and more home-brew.
This is more like what I was hoping to find but a bit pricey:
http://www.istnet.net.au/~wamrc/res_solder/index.html
Yeah, I also went out to the Train Index. I have the Mainline Modeler
magazine. That's what started this train of thought.
And there is this reference too:
http://www.trainweb.org/bristol-s-gauge/Projects/rsu.html
So what the heck am I looking for???
I thought I knew!
One article suggests a transformer that takes house current and on the
secondary posts gives 6-8 volts AC at 3 Amps. That's what I was asking
for at the local stores.
Another articles says I need a filament transformer that provides less
than 7 volts at 6 or more AMPS.
So far no luck. Any help appreciated.
Gordon
Re: [Homebrew_PCBs] Help finding transformer for r.s.u.
2007-07-26 by Leon
Sent: Wednesday, July 25, 2007 11:30 PM
Subject: [Homebrew_PCBs] Help finding transformer for r.s.u.
RS used to sell a transformer kit with just the primary, so one could put
one's own secondary on it. I used one once for a special low voltage I
needed. One of those would be ideal, wound with really thick wire for the
desired currrent. They might still sell them.
http://rswww.com
Leon
2007-07-26 by lists
In article <f88iu9+ro6j@...>,
Hmmm, sounds ok for soldering tinplate together but I wouldn't use one for
delicate electronic components. I'll stick to a proper temperature
controlled iron or hot-air unit thank you.
2007-07-26 by Hugh Prescott
Salvage a microwave oven transformer and remove the HV secondary.
Wind your own high amperage low voltage secondary to the specs your need
/ work.
The web will have many sites that show how to do this for resistance
welding batteries etc.
Hugh
>I thought I knew!
>Gordon
>http://groups.yahoo.com/group/Homebrew_PCBs
>If Files or Photos are running short of space, post them here:
>http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
>Yahoo! Groups Links
2007-07-26 by John Young
Gordon
   I have had some luck using old soldering 'guns' as a transformer for a
RSU.
Remove the tip and attach the wires to hand piece and ground to the two rods
that would hold the tip.
If you have too much current try the lamp dimmer on the AC input.
Old guns of 100 - 250 watts can be found at garage sales and hamfest for a
few dollars.
John
> Gordon
John D Young
WA8KNE
ETC USN retired
Re: Help finding transformer for r.s.u.
2007-07-26 by wayneosdias
asking
Try looking at the hammond line @ hammondmfg.com look under classic
tube transformers. They have specific filament xfers in the 3-8v @ up
to 10amps.
That or find any old peice of electronics that use vacuum tubes, the
2ndaries always include a 6.3v filament winding capable of a couple of
amps.
If you decide to buy try angelainstruments.com, they have the best
prices on hammond xfers Ive seen over the last 10 years.
GL wayne
asking
to 10amps.
amps.
GL wayne
2007-07-26 by Mark Brueggemann
> a bit smaller and more home-brew.
But you're not going to find much cheaper, or easier to
build around.  You can buy chargers like these brand new
for ~$20-$30, and it comes in a nice metal box with a line
cord, switch and current meter.  You could readily modify
it for a footswitch and there's likely room for a dimmer
or ballast for current control inside.  Volt amps is volt amps,
for a given power the transformer is going to weigh a given
amount, so I'm not sure how much smaller you expect this
to get.  By using a charger you get the housing, cords and
controls built in for you, so it doesn't get any easier than
that.
