what about using a heat press?
2007-06-18 by circuitmangler
I was wondering if anyone has considered or tried using a heat press
for the toner transfer method. They are usually used for transferring
images onto t-shirts.
Re: what about using a heat press?
2007-06-19 by Len Warner
I wonder if anyone ever looks into the archives
before expressing their curiosity ;-)
Oh, sorry, was that meant to be a "good idea"(TM).
How does your typical T-shirt press compare with
a smoothing iron or a laminator for pressure?
(That's units of 'force per area' not just force.)
And how important does pressure seem to be
using a smoothing iron, where it is completely
under the operator's control, though not
necessarily very closely controlled?
(And for the laminators, the force is so high it
is difficult to get the board in - and it is concentrated
along a line, so the resulting pressure is quite high.)
How does a press compare with a medium-quality
business laminator for price?
So, unless you already have a T-shirt press
or you are thinking of setting up a T-shirt
business alongside PCB production,
it is basically a non-starter.
Regards, LenW
   Content of a follow-up post should exceed quoted content. (rfc1855)
RE: [Homebrew_PCBs] what about using a heat press?
2007-06-20 by Tony Smith
> Hi,
> heat press for the toner transfer method. They are usually
> used for transferring images onto t-shirts.
There was a thread about it a while back (A year? More?).
Track down Tom Gootee's page, I think it was him who tried it.  Might be
some results there.
Apparently it's a bit hard to apply enough pressure.  Clamping causes
distortion, so you get pressure in one spot but not another, etc.  Dumping
weights on top didn't seem to help either.
Tony
Re: [Homebrew_PCBs] what about using a heat press?
2007-06-21 by Jim Hutchinson
Tony Smith wrote:
>> Hi,
> some results there.
> Tony
I use a heat press of sorts ... I make small PCB's  no larger than 3x4
inches ... I have a 4x6x1 inch piece of steel ... I took a piece of
aluminum oxide abrasive paper (8x10 inch) laid it flat on the top of my
table saw and dragged the steel plate back and forth across the abrasive
paper until it was flat and shiny (I actually made a motor driven
fixture to do the dragging in a random fashion for me ... it took
several days and several sheets of abrasive) ... I use a hot plate to
heat the steel plate until it is the temp I want (usually 350 to 400
degrees F) using a thermocouple attached to the steel plate to measure
the temp ... I have ready a flat wooden surface that has the blank
PCB/laser image/plane paper  ready to receive the hot steel plate ... I
place the steel plate on the top cover paper and clamp the steel plate
with about 300 pounds of pressure (about 25 pounds per square inch)
using a wide mouth vice grip pliers (this is moderate pressure ... you
can easily get 400 to 500 pounds of pressure) ... I leave it clamped for
about 1 minute then off to the water soak ... I get good resolution and
consistent results ... the flat surface insures an even distribution of
pressure ... the thick steel plate holds the heat and won't distort
under the moderate pressures and temps  used ...
Jim KI6MZ
2007-06-21 by Tony Smith
> it.  Might
> > be some results there.
> Clamping causes
> > Dumping weights on top didn't seem to help either.
> > Tony
> than 3x4 inches ... I have a 4x6x1 inch piece of steel ... I
> took a piece of aluminum oxide abrasive paper (8x10 inch)
> laid it flat on the top of my table saw and dragged the steel
> plate back and forth across the abrasive paper until it was
> flat and shiny (I actually made a motor driven fixture to do
> the dragging in a random fashion for me ... it took several
> to 400 degrees F) using a thermocouple attached to the steel
> plate to measure the temp ... I have ready a flat wooden
> surface that has the blank PCB/laser image/plane paper  ready
> to receive the hot steel plate ... I place the steel plate on
> the top cover paper and clamp the steel plate with about 300
> pounds of pressure (about 25 pounds per square inch) using a
> you can easily get 400 to 500 pounds of pressure) ... I leave
> it clamped for about 1 minute then off to the water soak ...
> I get good resolution and consistent results ... the flat
> surface insures an even distribution of pressure ... the
> thick steel plate holds the heat and won't distort under the
> Jim KI6MZ
Sounds like you've got too much time on your hands, you need a hobby  :)
I can't remember what the original thread was about, but it was something
like a clothes press.  I guess a lot of people start eyeing the sandwich
maker in their kitchen as well...
That chunk of steel you have won't bend easily, one problem solved.  How
long does it take to heat up?  Obvious for making a batch it'll be faster
than a laminator, but for one-offs?
So for double sided you just flip the board over afterwards?
(BTW, gluing the sandpaper to a sheet of glass works well for lapping stuff,
in case you don't have a cast iron table saw handy.  Glass is very flat.)
Tony
>> it.  Might
>> Clamping causes
>>> Tony
>> Jim KI6MZ
If you are going to do a process several times, you will always spend
LESS total time if you take the time up front to build the proper tools
... the steel I used was a mill "cut-off" so it had some ripples in it
... if the steel had been cut when the steel was cool, the lapping would
be done in 30 to 90 minutes
It takes about 10 minutes from room temp the first use ... I always
allow the temp to over-shoot by about 20 degrees then set the steel
block on a narrow strip of wood ... when the temp comes back down to the
target   i use it ... the thermocouple is on the top of the steel so
there is a temp gradient across the steel
I do one side at a time ... I spray paint side 2 .. image transfer and
etch side 1 ... then spray paint side 1 ... image transfer and etch side
2 ... I do drill alignment holes for registration
> Tony
2007-06-23 by Stefan Trethan
Aluminum might be a better choice it conducts heat much better.
I find it amazing that you actually built a motor for the lapping and
let it run for several days ;-)
ST
2007-06-23 by Tony Smith
> > tools ... the steel I used was a mill "cut-off" so it had
> some ripples
> > in it ... if the steel had been cut when the steel was cool, the
> > lapping would be done in 30 to 90 minutes
> back down to the
> transfer and
> > side
> lapping and let it run for several days ;-)
> ST
I built a similar rig to grind glass for a telescope mirror.  Doing it by
hand gets a bit boring after a while...
Aluminium would distort more (more flexible than steel), so you'd need to
make the plate smaller (small boards), or used a thick piece of metal, which
might take away the fast heating.
Still, the answer is now "Yes you can, got a big lump of steel handy?".
Good idea for small scale production.  I tend to do one-offs every so often,
so I'll stick with the printer fuser laminator.
Tony
2007-06-23 by Jim Hutchinson
> ST
Hello ST ... I didn't build a motor ... I used an existing motor
attached to a simple wooden frame ... The motor already had a 10 inch
pulley ... the motor was a DC gear head motor so I could vary the speed
... it took all of 30 minutes to build the fixture ... along with some
"C" clamps and wood screws ... when I tried to lap by hand, It became
clear that it was going to take more than an hour or so ... it was in
the summertime and my garage is hot 100+ degrees ... so I made the
fixture , turned it on and come in to the cool house and had a glass of
iced tea ... ... the man at the metal shop gave me the 4x6x1 hunk metal
... I later bought a larger 6x10 inch piece of steel for just a few
dollars ... it was smoother and lapped in a couple of hours ... I rarely
make more than two of anything and heating the steel clamping it down on
the transfer stack is faster than a laminator or ironing and most
important of all, I have control of all the important parameters and few
limitations ...
I didn't use Aluminum because I thought strength (or resistance to
distortion) was more important and the steel was free ...
Jim KI6MZ
Etching Tips and Tricks
2007-06-25 by Kamal Shankar
Guys
I have been facing a problem in getting 15x10 sq.cm
single side boards etched under 5 mins. I use
commercial grade FeCl3 and heat up the water to
boiling point. Then add it in a plastic tray having
FeCl3 and after mixing thoroughly, drop the boards.
I keep enough solution in the tray to just have the
board below the surface at an uniform 4mm.
But I have to heating mechanism due to which the
solution cools down after 2 mins. I also constantly,
manually rock the tray a little to remove "dust"
formed on the boards.
Currently this is taking me more than 20 mins for the
etching to complete !
I think I am wasting too much time behind an
ineffective/inefficient etching process - the
equipments I am using ssem to be far from optimal..
Any tips on ultrafast (sub 10 mins) etching ?
KamalS
Sick sense of humor? Visit Yahoo! TV's
Comedy with an Edge to see what's on, when.
http://tv.yahoo.com/collections/222
Re: [Homebrew_PCBs] Etching Tips and Tricks
2007-06-25 by Leon
Sent: Monday, June 25, 2007 6:32 PM
Subject: [Homebrew_PCBs] Etching Tips and Tricks
> Guys
I use a similar technique (the etchant is deeper, though), and my boards
take less than 10 minutes to etch. Have you got the right concentration for
the FeCl3?
Leon
2007-06-25 by DJ Delorie
I pre-heat the etchant (in it's bottle) in a few inches of hot water;
it doesn't have to be *that* hot.  However, I don't just soak the
board in etchant, I use a sponge to wipe the etchant across the board.
I did a 3"x3" board today (er, 1 or 2 oz) in just a few minutes.  The
mechanical action of the sponge really speeds up the process, but you
need more than just toner - the sponge trick is a Pulsar trick that
works with their green TRF, which seals and protects the toner.
2007-06-25 by Dale Chatham
The problem with unagitated FeCl is that the sludge left is thick and
inhibits further reaction.  It's the reason why the spray method works well.
It's my opinion that the sludge from FeCl is worse than several of the
alternatives.  I've come to use Amonium PerChlorate in a tank with a
submersible aquarium pump to keep things stirred up.
The trouble with using an air pump for agitation is that it tends to
create some aerosols that you might not want to mess with.  I lost the
head off of every nail in a storage shed that way :)
2007-06-26 by Kamal Shankar
> the FeCl3?
A question I have been dreading - right concentration
As I mentioned.. I am using a commercial grade, and by
that I think the retailer meant it has as much FeCl3
as everything else...
Is that a wrong thought ?
But I still mix about a table spoon in 250ml of hot
water.
Also.. does the depth of the etchant matter ?
KamalS
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121
> few minutes.  The
> process, but you
> Pulsar trick that
> the toner.
I think this would be too risky for us TT types who
use the Flyers for transfer and often have to
"correct" bad traces by a Sharpie ?
You snooze, you lose. Get messages ASAP with AutoCheck
in the all-new Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/newmail_html.html
2007-06-26 by DJ Delorie
Kamal Shankar <kbshankar2000@...> writes:
> I think this would be too risky for us TT types who use the Flyers
> for transfer and often have to "correct" bad traces by a Sharpie ?
Well, it's worth a try anyway, but even with the special Pulsar paper,
Pulsar strongly recommends adding the TRF to seal the toner.
http://www.pulsarprofx.com/PCB/a_Pages/5_Support/5b_Tips_Tricks/Tips_Tricks.html#Anchor-49575
Have you tried the pulsar paper?  Or, you can buy just the green TRF
from digikey for $9 for an 8"x15' roll.
2007-06-26 by Leon
Sent: Tuesday, June 26, 2007 2:28 AM
Subject: Re: [Homebrew_PCBs] Etching Tips and Tricks
>> the FeCl3?
> water.
That is nowhere near concentrated enough!
Not really, I just like to have plenty of it.
Leon
> hot
> > water.
Oh no !
What IS the right proportion?
Do you use lab grade or commercial grade?
How do you deal with excess etchant?
Have you ever tried anything else other than FeCl3?
KamalS
No need to miss a message. Get email on-the-go
with Yahoo! Mail for Mobile. Get started.
http://mobile.yahoo.com/mail
2007-06-26 by Leon
Sent: Tuesday, June 26, 2007 5:49 PM
>> hot
>> > water.
> Oh no !
Something like 500g/litre.
I just buy the stuff from Mega Electronics, or one of their distributors.
Pour it down the lavatory.
I used ammonium persulphate many years ago, it doesn't last long once it's
made up as a solution.
Leon
Re: Etching Tips and Tricks
2007-06-26 by Jim
I discovered about 15 years ago a technique which has worked
flawlessly for me and etches in about 5 min.:  Float the board,
copperside down, on the etchant.  The surface tension of the FeCL3
easily supports the board.  As the copper disolves into the FeCL3
the Fe, which is heavier, drops to the bottom of the container.
This leaves fresh etchant on the surface of the board all the time.
Best of all, NO AGITATION is required!  On FR4, you can see the
progress just fine through the board.  Heating (luke warm) the FeCL3
first does help, but we all know that.  Just drop the board on to
the etchant, walk away for 5 minutes, and the board is done.  Give
it a try next time.
Jim
--- In Homebrew_PCBs@yahoogroups.com, Kamal Shankar
<kbshankar2000@...> wrote:
> Guys
> KamalS
_______________
Re: [Homebrew_PCBs] Re: Etching Tips and Tricks
> has worked
> the board,
> into the FeCL3
> container.
Anyone else had this brainwave ?
Sounds nice ! So why do others use agitators ?
Anyone ?
> warm) the FeCL3
> the board on to
> is done.  Give
> it a try next time.
How much FeCl3 you mix up with the water ?
Do you keep it heated ?
KamalS
Get the free Yahoo! toolbar and rest assured with the added security of spyware protection.
http://new.toolbar.yahoo.com/toolbar/features/norton/index.php
2007-07-25 by Chris Hart
Just don't put it in, walk away, forget about it, and go to bed. That's
the quick way to get the toner floating on the etchant. :)
> > has worked
> > the board,
> > into the FeCL3
> > container.
> Anyone ?
2007-07-26 by Leon
Sent: Wednesday, July 25, 2007 2:21 AM
Subject: Re: [Homebrew_PCBs] Re: Etching Tips and Tricks
>> > has worked
>> > the board,
>> > into the FeCL3
>> > container.
It's difficult to see when it is fully etched. The technique has actually
been around for 30 years or so!
Leon
