toner removal methods?
2007-07-26 by timbomcnuckle
Hi again all-- how are you all removing toner from unetched PCB's?
like if you make a mistake in you alignment and need to start over
again? I am seeking something which will remove without having to
scrub the plate!,, which is what I've been doing up till now. It works
but is alot of work. I would prefer a solvent that will easily remove
the material without having to scrape at the plating further,
something gentle to the surface? Any tips here folks? thanks in
advance, jd
Re: toner removal methods?
2007-07-26 by wayneosdias
--- In Homebrew_PCBs@yahoogroups.com, "timbomcnuckle" <jaydag71@...>
> the material without having to scrape at the plating further>
Acetone works, but if you do etch the board I dont rec using the
acetone for the toner removal of the traces as it stains the bare glass
wayne
Re: [Homebrew_PCBs] toner removal methods?
2007-07-26 by Leon
Sent: Thursday, July 26, 2007 6:40 PM
Subject: [Homebrew_PCBs] toner removal methods?
> advance, jd
Cellulose thinners worked quite well when I tried TT.
Leon
2007-07-26 by Mark Brueggemann
Automotive brake cleaner.  Cuts it instantly and doesn't
evaporate as quickly as acetone.  I also use brake cleaner
for the initial de-greasing step prior to toner transfer.
2007-07-26 by Leon
Sent: Thursday, July 26, 2007 7:59 PM
Subject: Re: [Homebrew_PCBs] toner removal methods?
> I've been using "Goof off" (xylene) with great results, but be careful
> to read and heed the warnings.
The cellulose thinners I mentioned contain xylene.
Leon
Thanks folks! I ended up using some old thinnner that I had laying
around and it seemed to work out fine.
 I am wondering though if I can use this stuff for cleaning after
etching without the staining as cautioned above. I am not 100% on
what it made of but I think acetone perhaps. I was surpirsed to se
how well it actually worked though- as I had tried it a long while
back on some boards I tried using the staples t-shirt transfer
material (which is terrible btw)and it did nothing to help.
 Anyways, thanks again, jd
--- In Homebrew_PCBs@yahoogroups.com, "Leon" <leon355@...> wrote:
> From: "DJ Delorie" <dj@...>
careful
> Leon
2007-07-27 by lemonyx
> advance, jd
I use lacquer thinner to take the tonner off the cooper.
2007-07-27 by dl5012
Hi jd,
It wouldn't hurt to try it on a test board.
I've found that removing toner with acetone works well with FR4 and
CEM1.  I've only had problems with staining on FR4 if I used too
little (using a cotton ball applicator).
It could be a matter of technique.  Use enough solvent to disolve the
toner and getting it off before the solvent evaporates.
Acetone is nasty stuff.  Eats through latex and many plastics.  Wear
goggles too...
Dennis
2007-07-28 by TonyB
I use lacquer thinner, also, for toner removal.  Also for ink removal
when I do silkscreen.  But it's always a good idea to scrub the boards
after removing the toner/ink.  After cleaning with LT, I use 220grit
sandpaper or double-ought(00) steel wool.  The idea is to remove all
the oxidation on the surface of the copper.  Copper oxidixes very
fast.    T
--- In Homebrew_PCBs@yahoogroups.com, "lemonyx" <g_cw@...> wrote:
> --- In Homebrew_PCBs@yahoogroups.com, "timbomcnuckle" <jaydag71@>
> > advance, jd
