Copper Pours - pros/cons?
2007-01-18 by David McNab
What do people see as the pros/cons of copper pours in board artwork?
For mainly digital circuits with small amounts of analog sampling, do
they offer any significant improvement in electrical performance?
I tried a couple of boards with GND copper pour.
For me, all I've noticed is that they make my etchant last a little
longer, but increase the time taken in removing backing paper, and make
the soldering phase slightly less comfortable.
Cheers
David
Re: [Homebrew_PCBs] Copper Pours - pros/cons?
2007-01-18 by Stefan Trethan
On Thu, 18 Jan 2007 21:29:59 +0100, David McNab <rebirth@...>
wrote:
> Hi,
> Cheers
> David
Ground planes are a huge topic, i suggest you google and read some of the
papers (often from IC manufacturers).
There are many potential problems, especially with our one and two layer
boards where copper areas will be badly connected or even isolated
alltogether. For high frequencies an island grounded by only one spot may
be more of an antenna than anything else, and should be grounded at least
on the far end through vias.
The more obvious problems are of course capacitive coupling to ground, and
ground drops, although vastly reduced, may add up in different ways than
without the copper pour. completely isolated areas are even more
problematic, potentially coupling unwanted signals together.
Anyway, i don't understand half of it, but read the stuff on the web,
lotsa stuff going on with ground planes that you may not expect.
ST
2007-01-18 by Leon
Sent: Thursday, January 18, 2007 8:29 PM
Subject: [Homebrew_PCBs] Copper Pours - pros/cons?
> Hi,
It can make routing easier, which is why I sometimes use it, as well as
giving better electrical performance. Having as much ground area as possible
is usually a good thing. It can also give more even etching - isolated
tracks tend to get over-etched.
Leon
Leon Heller
Amateur radio call-sign G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
