Toner Transfer System - order direct from your favourite supplier (e.g. Digikey)
2007-01-15 by torinwalker
Have you had enough of photoimagable pcb etching?
I just found (and purchased) this product from Digikey, pn# 182-1003-
ND. $14.95. If you buy two packages, Digikey will waive the 8.00
shipping fee.
Each package contains ten sheets of laser-printable, specially water-
soluable paper, plus green thermal transfer film.
Check out the product page:
http://www.pulsar.gs/PCB/a_Pages/3_Direct_Etch/3c_How_Fine_A_Line/How_F
ine_A_Line.html
Now... if only the same could be done for the solder mask!
I'll post a final review after I create my prototype.
Torin...
Re: [Homebrew_PCBs] Toner Transfer System - order direct from your favourite supplier (e.g. Digikey)
2007-01-15 by Herbert E. Plett
> shipping fee.
there definitely are cheaper (and better?) ways...
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
Re: Toner Transfer System - order direct from your favourite supplier (e.g. Digikey)
2007-01-15 by nixiebuilder
Follow the  instructions on saving paper.  I went thru 10 sheets
learning how to do it.  Spendy.  Remember to print your image on the
shinny side.
good luck
--- In Homebrew_PCBs@yahoogroups.com, "torinwalker" <torinwalker@...>
> shipping fee.
> ine_A_Line.html
> Torin...
Re: [Homebrew_PCBs] Re: Toner Transfer System - order direct from your favourite supplier (e.g. Digikey)
2007-01-15 by Torin Walker
It would be interesting to try to create a home-made version of that "shiny" coating. What chemicals can you think of that would allow one to coat an ordinary piece of laser-printer paper so that one could print on it, and dissolve the bond between the toner and the paper with ordinary water?
I was imagining a water-soluable shellac, of sorts. My brother is into chemistry. I'll ask him.
Perhaps we can save on the paper. The film is dirt cheap - 8" x 15' for $8.99. The paper is the killer.
Torin...
----- Original Message ----
Sent: Monday, January 15, 2007 12:51:57 PM
Subject: [Homebrew_PCBs] Re: Toner Transfer System - order direct from your favourite supplier (e.g. Digikey)
shinny side.
good luck
--- In Homebrew_PCBs@ yahoogroups. com, "torinwalker" <torinwalker@ ...>
> shipping fee.
http://www.pulsar. gs/PCB/a_ Pages/3_Direct_ Etch/3c_How_ Fine_A_Line/ How_F
> ine_A_Line.html
> Torin...
2007-01-15 by David McNab
On Mon, 2007-01-15 at 18:42 +0100, Stefan Trethan wrote:
> On Mon, 15 Jan 2007 18:29:05 +0100, Herbert E. Plett <cachureos@...>
> Let's have a competition, who can do the finest lines with TT? ;-)
/me awaits people's pics of perfect 4mil traces
Seriously though - the best TT results I've had have been with inkjet
gloss card, 8 passes through laminator.
Press'n'peel film - no luck, the toner just doesn't transfer.
'Time Magazine' gloss paper - transfers ok, but with distortion that
could mess badly with fine close traces.
WashAway paper - transfers fine, but with similar distortion to magazine
gloss paper. Etching takes longer (since a fine layer of paper fibres
stays on board and won't wash away), however this is offset by the
convenience of instant wash-away of the bulk of the paper.
Cheers
David
2007-01-15 by Stefan Trethan
On Mon, 15 Jan 2007 20:13:59 +0100, Torin Walker <torinwalker@...>
> water?
> Torin...
Just use inkjet photo paper. It is the easiest, cheapest option people
have found.
Several coatings were tried, starch and stuff, i do not remember how those
turned out exactly (not spectacular or i would remember). I personally
have very good results with high temperature silicone, but there is a
problem, the result will "etch through" in places. I do not know why, but
one reason may be that the silicone does not add any paper residue, like
the papers do. It is great for component legend though because it leaves a
jet black toner image with no annoying grey residue, and of course you can
just pull it off the PCB without any water involved (you can even re-use
it if you like).
Anyway, the coatings are interesting and all, but nothing (i know of) was
found that delivers better results than inkjet papers.
ST
2007-01-16 by William Carr
I was thinking about sprayable silicone.   But then I wondered if it
would damage the printer and decided that printers cost more than paper.
William Carr
2007-01-16 by Roland Harriston
If I recall correctly, the finish on most "glossy" paper is a kind
of clay that is applied and then run through a series of "polishing"
rollers.
Roland F. Harriston
>> water?
>> Torin...
> have found.
> it if you like).
> ST
Re: [Homebrew_PCBs] Re: Clay Coated Paper (Various Grades)
The URL below gives a  lot of information on various grades of
clay coated paper. I think Time magazine and some catalogs are
printed on one of the lower (if not the lowest) grade of clay coated
paper.
Mostly, this "stock" in only available in very large sizes and
very large quantities for the printing industry.
Perhaps someone can find a printing house that is willing
to sell small quantities of the material for our experimentation.
http://www.conservatree.com/paper/PaperDesc.shtml
> rollers.
> Roland F. Harriston
2007-01-17 by Torin Walker
I've sent out a blanket email asking for help on sourcing a coated paper compatible with the transfer process (per the original thread post), starting with the site you provided. I have also sent it to places that provide specialty papers, printing transfer (injet, laser, copier, etc.) paper, and a number of other places. About fifteen companies in all. While searching for companies well suited to ponder my plea, I noticed a number of companies who feature transfer paper, many of which supply laser-printer transfer paper.
Transfer paper is actually pretty cheap when compared to the Toner Transfer Kit. By my calculations, the Toner Transfer Kit contains 10 sheets of paper, and probably as many (nearly equally sized) pieces of transfer film. If the film is $8.99 for 8" x 15' (yards), then 10 sheets of 8x10" costs roughly 45 cents. The remaining $14.55 is divided evenly between the 10 sheets of transfer paper, making them a $1.46 each.
I have seen ads for laser-toner transfer sheets costing $33 for 50 sheets. The only question that remains is whether that paper is equal to the paper in the kit. We shall soon have an answer from many authoritative and reputable paper companies. Let's hope the answers aren't all crap.
Torin...
Sent: Tuesday, January 16, 2007 3:46:32 PM
Subject: Re: [Homebrew_PCBs] Re: Clay Coated Paper (Various Grades)
paper.
> rollers.
> Roland F. Harriston
Yahoo! Groups Links
2007-01-17 by Stefan Trethan
On Wed, 17 Jan 2007 16:53:26 +0100, Torin Walker <torinwalker@...>
I don't understand why you don't simply go to the next office supply store
any buy clay coated paper _off the shelf_?
Many Inkjet papers are clay coated.
I'm sure the sheets sold at $1.46 each are no better than the inkjet paper
sold at $0.10 a sheet.
ST
2007-01-17 by Roland Harriston
I think what I would strive for would be a glossy, clay coated paper that
is not heavy stock like most inkjet papers.  Some inkjet papers a nearly
as thick as card stock.......tough  to dissolve, requiring scrubbing.
I think I would like to have a thinner stock, something like that used for
Time magazine, catalogs, and others. The reason for going to a thinner
stock is that
it would dissolve much faster and easier than the thicker stock used for
inkjet paper.
So, that's why I suggested trying to get some "Time magazine"
type paper from a local printing establishment.
Unfortunately, there are no big-scale printing houses in my
immediate area.  We once had a large Alpha Graphics operation
here, but they moved out due to lack of business.
NOTE: Sorry that my photos of the local Muriatic acid sources
was filtered out.  I should have realized that they would be.
My Bad.
Roland F. Harriston
> ST
My understanding is that the paper in the kit isn't arbitrary; it is supposedly a specially coated paper whose printing surface dissolves in water such that the toner is completely released from the film. I've tried using ordinary paper, but it always leaves a grey film on the toner.
I guess I'll find out when I finally receive the TT Kit. I'll be relieved it it does turn out to be ordinary paper, because then I'll buy it at $0.10 per sheet.
Torin...
Sent: Wednesday, January 17, 2007 12:40:00 PM
ST
Yahoo! Groups Links
On Wed, 17 Jan 2007 20:50:20 +0100, Torin Walker <torinwalker@...>
> toner.
> Torin...
My understanding is they just want your cash.
Some rubbing with a piece of foam rubber and the white residue goes away,
but it is not a problem unless you want to make component legend.
The etchant does not mind the looks.
ST
On Wed, 17 Jan 2007 20:43:17 +0100, Roland Harriston <rolohar@...>
> for
> stock is that
> inkjet paper.
Yes, thinner is better. But some photo papers are barely thicker than
regular copy paper (100g/sqm compared to 80g/sqm), and i'm not sure much
thinner paper is good with feeding and distortion and stuff. Taking the
bulk thickness of paper away takes only a few seconds if you roll it off.
You can speed up soaking by giving it a brush with a brass wire brush
(after transfer), that breaks the surface. It seems to me the surface is
what takes long to soak through. If you only make a few scratches and dunk
it you can see how the paper goes dark around the scratches.
Same here. I remember we got huge blocks of paper out of the dumpster when
we were children. Could've made a life's worth of TT with a single dive in
the dumpster i reckon, if it was the right paper, the cutoffs were more
than plenty large for PCBs.
Maybe if someone has a printer nearby he oughta check the dumpsters!
Can't hurt to try, but i wouldn't put too much effort into it, since the
paper store stuff is just fine. Cutting the sheets in half makes it a bit
cheaper.
ST
2007-01-17 by David McNab
Also, don't forget the option of putting clear packing tape over the
board, and peeling it off slowly and gently. Done right, it pulls off
all paper traces without disturbing the toner.
Cheers
David
Home depot sells muriatic acid. It's (nearly) as common as road salt. Why would your sources be filtered out?
Sent: Wednesday, January 17, 2007 2:43:17 PM
as thick as card stock....... tough to dissolve, requiring scrubbing.
stock is that
inkjet paper.
My Bad.
Roland F. Harriston
> On Wed, 17 Jan 2007 16:53:26 +0100, Torin Walker <torinwalker@ rogers.com>
> ST
> http://groups. yahoo.com/ group/Homebrew_ PCBs
> http://groups. yahoo.com/ group/Homebrew_ PCBs_Archives/
On Wed, 17 Jan 2007 21:34:58 +0100, David McNab <rebirth@...>
> Cheers
> David
I must try that some day, probably with a transfer gone wrong. Sounds
crazy, but if you say it works...
ST
2007-01-17 by Andrew
Sorry for being a late entry here.  I know
this argument has been done to death. I
know your probably all sick of it.
HOWEVER.
In OZ no one sells muriatic acid.
Hardware stores and Pool shops all sell
Hydrochloric acid.  If you ask a concreter
or pool cleaner about muruatic acid he
will look at you funny.
We also don't have lye or soda ash for
sale here.  About the only name people
have mentioned that are still sold under
old world names is Backing Soda (which
still has "Sodium Bicarbonate" on the
box as well.
NB - We don't have things called Sodium
Carbonate or Sodium Hydroxide for sale on
the shelves either.  They all have brand
names like "miracle burn" or "chemiclean"
but the ingredients list has the real
names.
Torin:
You are correct. But here on the Sonoran desert we don't use very
much road salt, but we do use a lot of chlorine and muriatic acid.
In a post to the PCB list, I enclosed a URL where I had uploaded two
photos I took yesterday.
One showed stacks of 2-gallon cartons of muriatic acid in
plastic jugs next to the stacks of dog chow in a local super market.
The other photo showed one and two gallon jugs of muriatic acid
at a local home improvement/garden supply emporium (Home Depot).
In order to view the photos, one would had have to click on the URL,
and I suspect that there is a possibility that a virus or some such
could be propagated in such a manner, thus the message was
screened out.
Some list members had mentioned that it was difficult for them to
obtain chemicals like muriatic acid, and I wanted to illustrate the
wide difference in bureaucratic mindsets in different venues.
Not bragging or boasting..........just a point of wonderment on my part.
What is so common in one area can be so uncommon in another.
Roland F. Harriston
> From: Roland Harriston <rolohar@...
> <mailto:rolohar%40comcast.net>>
> To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
> stock is that
> inkjet paper.
> My Bad.
> Roland F. Harriston
> rogers.com>
> sheets
> evenly
> store
> paper
> > ST
> Photos:
> > Yahoo! Groups Links
On Wed, 17 Jan 2007 22:35:58 +0100, Roland Harriston <rolohar@...>
How many % does that have?
While it is no problem to buy around here, it's usually not that openly
available on the shop floor (child safety etc.).
There are certainly not large stacks of it in any shop here.
I'd be curious about the photos, dunno why the url got eaten, perhaps try
to disguise it or something.
I thought you attached a picture.
ST
> > Cheers
> > David
Why not try it now with a bit of board off-cut?
The trick is to peel the tape off by not pulling it up away from the
board, but along the board towards the opposite end, and to keep the
pull force to a minimum at all times, and the pull rate to a couple of
mm per sec max. Any jerking with the pull will most definitely pull up
traces and pads, but a slow, gentle pull will leave the toner completely
undisturbed. You'll even see the paper on the removed tape showing the
artwork in fine detail.
Cheers
David
2007-01-18 by Russell Shaw
> HOWEVER.
Hardware shops here have sold HCl as
"spirits of salts".
> box as well.
> names.
2007-01-18 by fenrir_co
> store
> paper
> ST
I don't use inkjet paper because it's a very good way to wreck your
laser printer. I don't have one at the moment because I have three
inkjets (one office type printer modified for refills for massive
amounts of printing, a photo printer with OEM dyebased ink for photos,
and one photo printer that I'm experimenting with pigment ink refills)
and don't have room for it, so I run off my copies at Staples on a
copier. I don't really do enough etching to justify buying one when I
can get 2,000+ copies for the price of one printer (without buying
refills, too!) So the paper I buy has to say laser compatible, as most
inkjet paper will melt/buckle/otherwise jam up and I don't feel like
having to explain why a $50,000 machine just got damaged. Press'n'Peel
and the pulsar.gs paper are both designed specifically for laser tech
(but even Press'n'Peel Blue, which is home-laser compatible, will
completely melt in many color copiers).
Right now I use HP Glossy Photo Paper for LASER printers, which makes
a nice transfer, but is difficult to remove. Even if I had my own
laser printer, I doubt I'd run inkjet paper through it. I just don't
think it's a good idea - I've seen too many other people wind up
having their printers damaged because they used inkjet to try to print
a photo on a laser 'because it's photo paper!', though I believe the
issue is much more of a problem with color lasers than small consumer
grade black and white ones.
2007-01-18 by Stefan Trethan
On Thu, 18 Jan 2007 05:38:30 +0100, fenrir_co <fenrir@...>
Well, you must suit yourself.
I doubt a used laser printer for 10eur was much of an investment for me,
and i have never had any inkjet paper jam. I wouldn't use an inkjet for
printing if i can possibly avoid it, even with refills they are a
nightmare compared to lasers.
Anyway, you must do what seems best for you, it just may not make sense to
other people.
ST
