board house
2006-09-09 by adastra_2001
2006-09-09 by derekhawkins
>If not then I hope everyone that$2.50 a sq. inch is high IMO. You can get $.55 per sq. inch at the
>can use these guys give them a try.
>to
> link below for better standards on paper, but the catch is you have
> spend at least $33.00 if you're a student and $99.00 otherwise.If I am right, that price is with silk screen mask And they do allow
> Clearly not suitable depending on how much you have to spend.
> https://www.33each.com/!33each1.asp
> --- In Homebrew_PCBs@yahoogroups.com, "adastra_2001"
> <adastra_2001@> wrote:
2006-09-10 by David Brainerd
> to
> you odd shape boards. If the other guys are $0.33 with those options
> then they are a better deal. The main reason for this thread is to get
> board houses that others have used known to the world. I can make my
> own board but if it is a project I plan to make money with then I want
> the prototype done professionaly so I can determine any manufacturing
> issues.
2006-09-10 by derekhawkins
>The last 2 were 58 sq-in.Does KwickFit ring a bell? I was able to panelize 16 @ 2" X 1.6" on a
2006-09-10 by adastra_2001
> 8.5" X 7" board (59.5 sq-in). Got 48 boards for $99.00, that's justIt looks like KwickFit is a program to optimise yield. Who did your
> over $2.00 per board. No complaints and my good friend Lucy Lu from
> China does the cutting;
> http://www.pbase.com/eldata/image/66633405
>It looks like KwickFit is a program to optimise yield. Who did yourAdvanced Circuits, same place as the other fellow.
>boards?
2006-11-27 by adastra_2001
2006-11-27 by Ross McKenzie
> I will have a file done in Eagle for a board that I need for a
> prototype. I only need about two of them right now. I want it done by
> a pro so I can get a feel for the whole design, order, production
> process and get a board that will look like it was done by a
> professional, something I am not. Are their any recommendations of
> someone cheap but decent that will not mind a 2 of a kind order? If I
> am successful, I will need to order many more boards.
2006-11-27 by DJ Delorie
> Are their any recommendations of someone cheap but decent that willMy last board (one panel, 100 circuits[*]) was from pcb-pool.com. 6
> not mind a 2 of a kind order? If I am successful, I will need to
2006-11-28 by Leon Heller
Sent: Monday, November 27, 2006 11:15 PM
Subject: [Homebrew_PCBs] board house
I use PCB-Pool for prototypes. They can also supply production quantities.
Leon
2006-11-28 by Steve
2006-11-29 by Len Shelton
>LenCNC Stepper Motor Drive Systems
